Assembly Command Clarification — Parallax Forums
While reading through the assembly command list I noticed the REP command and got curious about its limitations.
Specifically, can one REP command contain another like in this example code for driving a neopixel:
rep     #12,          %[pixel_cnt]
rdlong  %[thisPixel], %[hubPtr]
add     %[hubPtr],    #4
mov     %[bit],       #8
rep     #8,           #24
drvh    %[pixel_pin]
testb   %[thisPixel], %[bit]       WC
incmod  %[bit],       #32
waitx   %[tickH]
drvc    %[pixel_pin]
waitx   %[tickC]
drvl    %[pixel_pin]
waitx   %[tickL]
  • Reps are linked to a circuit that does the rep. Only one at a time.
    The second one should just cancel the first one.
    There is no internal stack, or storage for multiple reps.
  • I see. So the best option in this example would be to replace the first REP with a For loop right?
  • yes, the outer loop with djnz.
    I am overwhelmed with P2 PASM. I still find goodies in P1 PASM, squeezing another 1-4 longs out of something.
