Problem with getting Stamp homework Board to connect CPU.
in BASIC Stamp
I recently purchased 10 homework boards for a mentoring project at my local Tech High School.
I configured 5 boards with Leds, Beeper, A/D, basic stuff. All Linked to my laptop Wins 7.
However, I can not get linked to my laptop Wins 10. It does link to two older Stamp Board of Education,
one RS232 and one USB. I spoke with Megel in Support, He had received no problems with Win 10,
and suggested cable or CPU Port problem. I have same problem on different ports and cables.
I downloaded the latest FITI Driver Software. New battery,9.3V. Configured several ports.
I would appreciate any suggestions.
Thanks, redrover
Thanks, redrover
Thanks for the info...
I have 4 new Homework PCBs. No componets.
The first one I tied..linked. I rhought, voltage drop problem.
Bat = 9.4 on board. Regulator out 5.01V. good.
The next board and other 2 would not link.
They all had 5.02V
Looked at old Edu Board. Bat = 9.3, Regulator = 4,97, With componets.
It still links. Volts does not seem to be be a problem.
I am going by the school and downloading Stamp Editor and Driver on their computers.
I am sure that they do not have Wins 10. It should be OK.
Thanks.
I have installed the proper drivers (CDM21216) (three times) for the WIN 10 OS and even after changing the USB COM Port Latency to 1ms, the issue with no BASIC Stamps found still remains, although the Identify facility shows the port to be connected to the Homework Board with YES/YES for Loopback/Echo. I am using BS Editor Ver.253r2, which I have installed three times to be sure.
I replaced the batteries. Reloaded BS Editor for WIN 10, reloaded proper drivers, rechecked latency on every available USB port, and did this all for both of the two Homework boards that I have. Nothing allows the HW Boards to be recognized. However, I can successfully connect with my SumoBots, Scribbler 2, BOE, Propeller Activity Boards, and QuickStart boards. So I know my ports are working. Any assistance is appreciated.
Sorry, Redrover, for pretty much taking over your thread. Hopefully we will both get help from the expert folks here. Thank you.
So you have Homework Boards that will not link with Win 10, also..
Like I said, These were new boards and only one out of six would link.
Got to be compatibility problem with 10. I will not get a chance to go
by the school for a week or so. If they have Win 7 or previous, I will be OK.
I just will not be able to use my Win 10 laptop. If you find a cure be sure and post.
Sorry I did not respond sooner.
redrover
Do know what version of FTDI driver you have installed on your Windows 10 PC?
Is this a school PC or is this happening on your personal PC?
Miguel
That last post be me was meant for you. I've been testing the Homework boards here in the office and I have yet to hit a snag.
Do know what version of FTDI driver you have installed on your Windows 10 PC? This might help narrow it down
I am using the latest version FTDI Driver, 2.12.16(r2). Deleted older versions.
This is my personal PC, Dell latitude E5420. Windows 10 Pro.
I just downloaded Driver, too be sure,
same result. Connected to old usb Board of Education,
one of the Homework boards that has worked. Both connect.OK.
Will not connect to the other Homework pcbs. with and without componets.
The USB led lamps do blink at power on but go out when I
I go to edit port screen. Thanks,
redrover
Things here have taken a dive in my opinion the last few years. I really feel like an abandoned customer at times. I also miss Chris. Thank you for your continued assistance here on the forums.
http://www.ftdichip.com/Drivers/VCP.htm
Thanks for the suggestion. I have tried it several times, but I will try once again. It will not hurt! Thanks again.
It's possible that Windows 10 has managed to badly farble things rather badly. This presupposes that the OS can't grok things.
Matter fact there's a rumor that people are rejecting that release in favor of 8 or 8.1 or even a last known of 7.
Interesting the erco robots are off doing hurricane duty.
1. All boards connect via Windows 7.
2. Only one board connects via Windows 10.
3. The same USB cable was used.
It doesn't really add up. It's hard to say it's a driver or OS issue, and impossible to say it's a hardware (BS2) issue.
The only thing I could guess is the COM ports are conflicting with some other device, but that's a long shot as well. Maybe try forcing a different COM port in device manager?
Second to that, Dell does not officially support Windows 10 on your laptop. If you can figure out the chipset, try the manufacturer's site for Windows 10 chipset drivers. You probably have a bunch of "compatibility" drivers and chances are other things on the laptop might not work. Another solution could be to downgrade to an earlier version of Windows.
Whoa, I hope you get a second opinion on their health, I take a sick BS2 over the alien Arduino any day.
Have you talked to Miguel?
Sorry I have taken so long to update you on the Linking Homework PCB to Win 10.
I never did get linked to my Win10 Laptop...Gave up.
However, all are working OK with the Schools Win 10. Older tower models.
(Well, except for one PC. It appears that the driver software does not download.)
I have completed 3 classes, 7 students are really enjoying the Stamp.
Redrover
I have several BOE-Bots (two), a bunch of BOE Kits (USB and Parallel), SumoBots (two), Quickstarts (six), Scribbler 2 (two), and they all work fine. I have two older Propeller Activity Boards and they are also fine. I like that the Propeller can introduce my kids to "C" language and the Blockly experience is really nice for kids. But they can do all of this and more (JavaScript, MicroPython, graphical, etc.) with the other boards, albeit without the same level of help from the resident forum experts (thanks to all of you).
No hard feelings toward Parallax, and I will continue to seek solutions for various Parallax project needs from them. But not having someone reach out to me beyond one or two emails is not what Parallax used to be.
Call up Parallax Tech Support.
https://www.parallax.com/support
Your boards might be faulty so see if a new board works. Tech Support can examine your boards and send you replacements.
Parallax is great company and they have wonderful support so don't give up on them because of one issue.
Give me a call (916) 624-8333 I look more into what is happening with these boards.
Miguel
