Another LiDAR option? — Parallax Forums
This just popped up on my G+ feed and figured a few people here might be interested.
https://sensordots.org/mappydot
    edited 2017-08-17 16:16
    Looks like an affordable sensor. Might work on the ELEV8 for landing. Two meter would not work well for a forward pointing obstacle avoidance for that craft.
    I do like the new Mini Laser Range finder that Parallax has:
    https://www.parallax.com/product/28055
    100 meters and water proof. Can be mounted on a servo for 2d scanning.
  • Publison wrote: »
    I like it too, but the price puts it out of my comfort range as a hobbyist. Of course, those two products are a bit of an apples-to-oranges comparison. I wonder if there's a combination where the two could be complimentary (maybe one of the LW20s and several of the mappydots).
  • Nice find, I signed up for one.
  • Looks like the Parallax LD20 produces an X-Y map (in which a 3D depth can be derived for the mapped area), which is going to add to cost. Adafruit has a breakout board based on the VL53L0X , and is $10 cheaper. Both they and and Sparkfun have <$15 versions of this sensor with the shorter range. Depending on the speed you need, the cheaper 1D sensors could be used to create an X-Y table, and from there, a 3D depth map.
    For close range, a laser-based vision system employing diffraction gratings could provide a coarse 2D map. It would cost maybe $10 in parts (but heavy investment in software).
  • DaveJensonDaveJenson Posts: 396
    edited 2017-08-17 22:06
    And another LiDAR. 2 meter range.
    https://microed.co/tinylidar/
