FLiP Try It Kit
in Propeller 1
Looks like an interesting start off point, if you want to get involved with the Propeller chip. But the big question is, can you use the Parallax WiFi SIP module with this kit?
At one point I did try to connect my WiFi SIP to the QuickStart board, but did not have any success. Has anybody successfully connected a WiFi SIP to the FLiP module, without having to add too much extra wiring, or doing soldering/de-soldering?
Ray
Ray
Ray
EDIT: The options are DTR, RTS and CFG. It doesn't seem to have an option for CTS.
EDIT2: I looked at the Prop Tools and it's options are DTR, RTS and DTR & RTS. It doesn't have CTS either.
EDIT3: From what I can tell, the DTE controls DTR and RTS, and the DCE controls CTS.
Ray
My PropBSC module used the FT230X which doesn't have DTR, so the Prop Tool has to be set to DTR&RTS so it works. Unfortunately, you can't do the same with Blockly, so I can't use Blockly with my module.
(It may look like the two red wires in the pic are one and the same - they aren't...one is Vdd and the other, "bodgy" looking one hanging down is the one I refer to above)
Cheers,
Jesse
Edit: By 'software changes' above, I mean changing which handshaking lines are used to signal the Prop reset.
