Where to find wheels of the right size
DavidZemon
in Robotics
I'm trying to find two wheels that will fit a motor with the following dimensions:
Shaft is a D shaft
D shaft is 8mm diameter with the cutout being 7mm wide
The cutout runs 12mm down the length of the shaft
The shaft protrudes 19mm from the base of the motor
I'd like something on the order of 100mm or 4" in diameter, but I'm not real picky (nor do I have any idea what would be the "right" size for my application). The motors are 12V, 3.5A/5A+ geared for 1:131 and I'll be using them to power a balancing robot. The chassis for the robot isn't built yet (and I'd like to have the wheels in my hands before next weekend when I build the chassis), but I'm looking at between 18-24" tall made of steel. battery pack will be 8 AAs. I'm not really sure what that will mean in terms of weight, but I would bet anything on the order of 4" in diameter with an 8mm shaft will not have any problems supporting the weight.
Shaft is a D shaft
http://shop.eaglecreek.com/70-mm-wheel-set-w-8mm-bearings/d/1192
Just gum up the bearings with some suitable glue and stick then on your shaft with loctite or some such.
Or perhaps http://www.ebay.co.uk/itm/300397444752 bit pricey.
Google 4" plastic wheel, lots of hits.
Here's a $1.71 plastic 5" wheel with rubber tread: https://hardwareonlinestore.com/index.php?option=com_virtuemart&view=productdetails&virtuemart_product_id=65077&virtuemart_category_id=67702&gclid=Cj0KCQjwn6DMBRC0ARIsAHZtCeMDL9AiULHtsgEyw2iMcwNzEHvqeV7DWuVlti984Mt5VCULT_-a6JUaAi0EEALw_wcB&ppcsclkid=IY7ThV0jCWcb&ppcstrkid=1332290283&ppcsu=xhg7f5djqitnahs
Edit add ebay link: http://www.ebay.com/itm/RC-1-10-8MM-Brass-Shaft-Couplings-Coupler-Motor-12MM-Hex-connector-DIY-Screws-/322639462176?hash=item4b1ecf7f20:g:6C8AAOSwdU1W~MkD
Oh yea.... I guess there is that.... how bad could it be!?!?
Perhaps eccentric wheels would be a good test for a balancing robot!
1) The wheels' mass and moment of inertia (flywheel effect) will affect your tuning. I initially presumed that lightweight disk wheels would be superior, but that's not necessarily the case. In fact, if you want your bot to self-right, your wheels need some weight, and you need fast motors.
2) Soft tires (like pneumatic) add damping which adds stability and makes tuning the controller easier. Similarly, operating on thick carpet adds stability.
