FLiP vs Propstick USB — Parallax Forums
The description of the new FLiP board sort of implies that it is pin and code compatible with the Propstick (with the exception of two 68K pull-downs). Is this true?
If so, great (if only for the power-over-USB feature). If not, what would I have to change?
  • You'd want to take a look at pins 30 and 31 on your PropStickUSB implementation.
    30 was XI (Xtal input), and with FLiP is NC (Not connected)
    31 was NC (Not connected), and with FLiP is USB 5Vout (assuming you are powering from usb!)
    If you handle those 2 pins, and also factor in the two 68K pull-downs you mentioned on P26/P27), then your good to drop the FLiP in place of the PropStickUSB.
  • One other slight improvement...
    The FLiP module I2C bus has both clock and data (P28 & P29) pulled up with 3.9K resistors.
    PropStickUSB didn't have the clock pin (P28) pullup, and used 10K on P29.
    This should be an improvement with FLiP that ought not impact external circuits, unless you've added an external pullup to either of those pins.
    Ie. if you previously have added external resistors for I2C, you likely won't need them anymore.
  • You could change your budget, in a favorable way. FLiPs are very low cost, but in my view far superior to the PropStick USB if they can work in your application. For Parallax, this volume is very high - ensuring a very long life span.
  • Hmmm...different connector I see...
  • Do you mean the USB connector?
  • VonSzarvas wrote: »
    Yes, it's gone from a mini to a micro. That may result in a bit of rewiring in some applications if I ever need to replace an existing Propstick with a FLip. But I have embedded Propsticks in dozens of projects over the last ten years and I haven't yet seen one fail. Although I have managed to blow a few up on the breadboard...
  • jmgjmg Posts: 15,200
    edited 2017-08-03 21:32
    Rumple wrote: »
    VonSzarvas wrote: »
    Yes, it's gone from a mini to a micro...
    I'm in two minds over this mini-micro thing....
    Micro is the new charging standard, so it's become more of a 'go to choice', but it is more fragile. Cables seem to fail first.
    I've seen Vendors choose to stick with mini over micro for that reason, and some I notice even use fully thru-hole Minis.
    I never use a pure-smd USB part, at the least the mounting pins (prefer 4 over 2) must have holes, and poured copper.
    edited 2017-08-03 22:26
    jmg wrote: »
    I thought about the USB connection, it would be a shame if it failed.
    With the module securely planted in the breadboard, a trip over the cable could rip the thing completely apart.
  • IMO, no pluggable connection should ever be SMT, unless it is rarely used. The through hole versions held up much better, and were a lot easier to replace.
    I've thrown out 2 Prop Plugs since starting the rover project. Both times I kicked the USB cable, or it got caught on something. The USB connector rips the pads off the PCB making it not worth the effort to repair. Now that I can program everything wirelessly, I don't have to deal with the issue.
    Wireless programming would solve so many issues, and certainly adds a lot of excitement to working with any mobile robot.
  • jmg wrote: »
    I think this is a really good reason to use Micro. AFAIK, that was also a design goal of the usb micro connector... that the cable would fail first.
    ie. much easier to change a cable, than the on-board connector.
    xanadu wrote: »
    One issue is that fully through hole versions add significant cost to a product- especially relevant when retail is <$50. Most customers want lower costs :)
    For higher end (higher cost) products, I don't disagree. A fully through-hole part will be stronger.
    That said, for most users the SMT version with 4 through-hole mounting pegs will be as robust as the product lifetime.
    Sure, there will always be edge cases. Although breaking these connectors is surely gonna need a lot of force? More than might be reasonably expected? .. Even in that respect, I like the strain relief shown by MikeDYur above. Neat and simple option for "tough" users.
    More generally, it's good to see Parallax has been using those robust 4-pegged TH/SMT connectors jmg mentions for a fair while across its product range. Both in Micro and Mini format. I guess the old PropPlug was designed just before the change, but I think Parallax has been careful to choose the most robust connectors.
    That said, Sure - Wireless is the future! And a wireless FLiP would be very cool!
  • Rumple wrote: »
    Yes, it's gone from a mini to a micro. That may result in a bit of rewiring in some applications...
    If it helps, there are adapters available (Micro USB to Mini USB) that would save replacing your existing usb cable. With regard the USB side, no other re-wiring needed.
    edited 2017-08-07 07:55
    Just for info, at work (a contract manufacturer), we place an average of 1200 SMT micro USB connectors every month. All of them have through hole mounting posts that are soldered with intrusive reflow (aka "pin in paste") meaning we apply paste into the holes during the solder paste printing process. The IO and power pins are SMT.
    After reflow, the holes will fill to 80-90% with solder (IPC-610 requires >75%). Of all the ones we place, I have yet to hear of a damaged connector from normal use. We place them on commercial and industrial products. As long as the posts are soldered at least 50%, they are not weaker than a full TH version.
    Full SMT micro USB connectors, the type with gull wing mounting pads, are notorious for ripping off, so you rarely see those on new designs. The DIY field still uses them though.
    edited 2017-08-06 04:51
    I agree totally with Andrew. I'm now using the Amphenol/FCI µUSB part number 10118194-0001LF that is staked down with intrusive reflow. The second photo below. Staked at 4 points. No problems with that. The FLIP according to its docs uses the exact same part.
    In some earlier boards I'd used a gull-wing SMD part, no end of problems, because these connectors get lots of use, in and out, twisting, or even hanging by the cable. I'd resorted to adding a strain relief wire on top of the connector, first photo below. Helped some, but takes a 2nd assembly pita. The problems have mostly gone away with the staked connector.
    Andrew, I didn't know that was called "intrusive reflow". Okay! One issue with shrouded connectors is that they are difficult to inspect with X-ray or optical. Do you have special tricks for inspection?
    µUSB is definitely the ubiquitous option these days.
    360 x 270 - 45K
    360 x 270 - 55K
    edited 2017-08-06 07:32
    Tracy, well for the longest time, I called it by it's non-technical term "pin-in-paste". Intrusive Reflow seems to be the more "professionally accepted" term, although pin-in-paste and paste-in-hole-reflow (or PIHR) is usually referenced anytime the Intrusive term is mentioned. While I can't share the docs I have due to licensing, IPC-7525 has the specifics governing formulas and design criteria for Intrusive Reflow. The toughest challenge with Intrusive Reflow is getting designers to include the concept at the design level. Many times, a designer will tighten up a hole (more of a slot really) for the TH posts on a µUSB connector thinking that it will make a more rigid solder joint. Unfortunately, that just means we have a greater challenge with stencil design. In one case, even though we utilize Intrusive Reflow for the connector, we still have to hit the posts with selective solder during TH soldering to bring the joints to spec per IPC-610.
    µUSB is definitely the correct choice nowadays, period. The only reason it won't be, is if the designer doesn't want to take the time to design the board correctly for manufacturing. Besides, nearly everyone has µUSB cables laying around. Mini USB are far less common now.
    edit: Here's a decent "cover it all" page for Intrusive Reflow: http://www.mtarr.co.uk/courses/topics/0226_pip/index.html
    Martin has some really good info on his site: http://www.mtarr.co.uk/courses/topics/index.asp
    edited 2017-08-06 21:05
    Thats' a nice reference Andrew.
    The FCI connector data sheet does suggest a pcb layout, attached, and it does in fact specify narrow slots for the the stakes as well as larger pad area toward the centerline. They aren't really pins, as they are only 0.6mm (26 mils) long, so they don't extend very deep into a 62mil circuit board. It looks like the FLIP adheres quite tightly to that layout. The slots are plated through, but no pads on the opposite (smooth) side of the board.
    I wasn't comfortable with plated slots, so in my boards I've used holes of 32mil and 40mil diameter for the two sizes of stakes, into which they fit snugly but with clearance at the sides. There is a lot of pad to the side with the notion that solder from the larger pads will wick by surface tension into the hole to help secure the stake. That is one of the suggestions in your mtarr reference. There has been no problem with solder dripping thru, which is good, because there is the entry for an SD card on the other side.
  • Thanks VonSzarvas. The thing is, I would happily pay an extra $10 per unit to save $100 over a few years. It's nice to hear the Flip is staked down. The connector might tear apart, but could be replaced with a normal desoldering process.
    I wasn't comfortable with plated slots, ...
    Why not slots ? they seem to work fine ?
    I use such PAD layouts and also copper-pour flood over pads both sides, to give the highest copper adhesion areas.
    Think of it as belts and braces.... :)
  • jmg, I'm just a little intimidated by plated slots that require such tiny bits. They seem to add checkboxes on quotations, added cost, and uncertainty in the outcome unless you are very familiar with how to specify them within the design flow of the fabricator. Round holes are so easy, for me, for the relatively small quantities of boards that I have to do. I've done boards with generic 0.1" slots and plenty of odd board outlines.
    Good point about highest copper adhesion areas. It doesn't do any good to have a part soldered to a pad if the pad itself lifts off the board. But about USB connectors, I believe the shell is not supposed connect to the end circuit ground. It is supposed to connect only to the cable shield. I see it is connected to Vss on the FLIP, no big deal.
