( 0079 $3628 ok ) BLINKEM
( 0080 $3628 ok ) STOPEM <-- some LEDs still on although blinling stop
( 0081 $3628 ok ) BLINKEM
( 0082 $3628 ok ) STOPEM <-- some LEDs still on although blinling stop
( 0083 $3628 ok ) BLINKEM
( 0084 $3628 ok ) ' STOPEM TIMERJOB <-- some LEDs still on although blinling stop
( 0085 $3628 ok ) BLINKEM
( 0086 $3628 ok ) ' STOPEM TIMERJOB <-- some LEDs still on although blinling stop
( 0087 $3628 ok )
@frida - I've read and reread your request a few times but I'm still not sure what you are asking. There are multiple ways of setting pins high and low all of which automatically set the dir register. In fact there is never any need to directly access the dir register. Do you have a code example of how you intend to use the instructions?
These are a list of the direct I/O instructions.
OUTSET ( mask -- ) Set the pins to high (also sets dir)
OUTCLR ( mask -- ) Clear the pins to low (also sets dir)
LOW ( pin -- ) Output a low on pin (also sets dir)
HIGH ( pin -- ) Output a high on pin (also sets dir)
FLOAT ( pin -- ) Float the pin back to an input (clears dir)
H ( pin -- pin ) Output a high on pin (sets dir, fast i/o, stack intact)
L ( pin -- pin ) Output a low on pin (sets dir, fast i/o, stack intact)
F ( pin -- pin ) Float the pin to an input (clears dir, fast i/o, stack intact)
P ( pin -- pin ) Pulse the pin (sets dir, fast i/o, stack intact)
PIN@ ( pin -- flg ) Read the state of the pin and return with a boolean flag
IN ( mask -- flg ) Read the state of the pins and return with a boolean flag
These operations are available but not normally used
OUTPUTS ( mask -- ) Set pins to outputs (does not write to OUTA)
INPUTS ( mask -- ) Set pins to inputs
Just paste this file and run the commands
BLINKEM
STOPEM
Read the source to see the changes, don't directly run ' STOPEM TIMERJOB
See the new STOPEM word which calls ' STOP-all TIMERJOB
I just now recompiled this and tested again.
IFDEF timer.fth
@rest org
FORGET timer.fth
pub ." timer 2017/06/17 11:49:45 " ;
@org W@ == @rest --- remember
\ * SIMPLE ROUTINE TO EXERCISE ALL 8 LEDS WITH TACHYON TIMERS
\ * AND ALARMS ON THE PROP QUICKSTART BOARD
\ * USE THE WORD "BLINKEM" TO START THE LIGHTS
\ * AND "STOPEM" TO STOP THE LIGHTS
TIMER mt0
TIMER mt1
TIMER mt2
TIMER mt3
TIMER mt4
TIMER mt5
TIMER mt6
TIMER mt7
: blink0 #16 PIN@ IF #16 LOW #500 ELSE #16 HIGH #50 THEN mt0 TIMEOUT ; --- timer alarm rountine and reset
: B0 ' blink0 mt0 ALARM ; --- assign blink0 as mt0 alarm vector
: blink1 #17 PIN@ IF #17 LOW #300 ELSE #17 HIGH #50 THEN mt1 TIMEOUT ;
: B1 ' blink1 mt1 ALARM ;
: blink2 #18 PIN@ IF #18 LOW #150 ELSE #18 HIGH #50 THEN mt2 TIMEOUT ;
: B2 ' blink2 mt2 ALARM ;
: blink3 #19 PIN@ IF #19 LOW #285 ELSE #19 HIGH #50 THEN mt3 TIMEOUT ;
: B3 ' blink3 mt3 ALARM ;
: blink4 #20 PIN@ IF #20 LOW #175 ELSE #20 HIGH #50 THEN mt4 TIMEOUT ;
: B4 ' blink4 mt4 ALARM ;
: blink5 #21 PIN@ IF #21 LOW #335 ELSE #21 HIGH #50 THEN mt5 TIMEOUT ;
: B5 ' blink5 mt5 ALARM ;
: blink6 #22 PIN@ IF #22 LOW #100 ELSE #22 HIGH #50 THEN mt6 TIMEOUT ;
: B6 ' blink6 mt6 ALARM ;
: blink7 #23 PIN@ IF #23 LOW #195 ELSE #23 HIGH #50 THEN mt7 TIMEOUT ;
: B7 ' blink7 mt7 ALARM ;
: clrpin $FF0000 OUTCLR ;
: BLINKEM
B0 B1 B2 B3 B4 B5 B6 B7 --- assign the alarm vector to timers
#10 mt0 TIMEOUT --- start all the timers
#20 mt1 TIMEOUT
#30 mt2 TIMEOUT
#40 mt3 TIMEOUT
#50 mt4 TIMEOUT
#60 mt5 TIMEOUT
#70 mt6 TIMEOUT
#80 mt7 TIMEOUT
: STOP-all
0 mt0 ALARM --- assign the alarm vectors to null, they will stop after the last timeout.
0 mt1 ALARM
0 mt2 ALARM
0 mt3 ALARM
0 mt4 ALARM
0 mt5 ALARM
0 mt6 ALARM
0 mt7 ALARM
$FF0000 OUTCLR --- clear all pins
: STOPEM ' STOP-all TIMERJOB ;
END
\ ?BACKUP
V4.5 status
I'm still fixing a few things and the main problem with getting EASYNET to work properly turned out to be a matter of case sensitivity. After a COMPACT operation the TACHYON and END words are redefined and they didn't reenable case sensitivity. However I renamed all those conflicting duplicates anyway.
If you are checking I/O states I used to have an "lsio" command but there is a lean and mean in V4.5 that pretty much tells me everything I need to know in one line.
Here's a Telnet session and a dictionary list etc over that session. It still amazes me how much code and dictionary we can squeeze into a standard Prop system without running out of memory or lacking in speed.
I usually code MYTASK as an infinite loop. A simple way is to control the loop (MYTASK) behavior is to check the status of a word in the loop and continue or stop. You could also use the word to either do work in the loop or just NOP. The word can be changed from the console cog or another cog. I have only used two cogs in Tachyon ever so far, one to run an async serial receive buffer and the main console cog. In the main console cog I would just use timers and KEYPOLL to run everything else.
I'm doing i2c with clockstreching in Tachyon.
And need to keep sda and scl low while i change DIRA.
Your SHROUT toggles OUTA, so I can not use it.
CLOCK also uses OUTA, where I need to CLOCK DIRA.
Oh, the rare clock stretch. I suppose that could be handled ok. I will have a look at it shortly.
\ * SIMPLE ROUTINE TO EXERCISE A TASK
\ * AND LEDS ON THE PROP QUICKSTART BOARD
\ * USE THE WORD "STASK" TO START THE TASK
\ * AND "TASKS" TO STOP THE TASK
LONG RFLAG --- is the task to run
LONG CNTR1 --- something to hold a count
OFF RFLAG ! --- task not running
: MYTASK
16 longs mystk --- give task some stack space, not needed here but for more complex tasks
mystk LP!
BEGIN
RFLAG @ IF --- check the flag
CNTR1 ++ --- increment the CNTR1
--- do more sutf
ELSE
NOP --- don't do anything
THEN
AGAIN
: STOPT OFF RFLAG ! ; --- stop the tasks
: STARTT --- start the task, don't start twice so STOPT first
ON RFLAG !
: RCNTR1 CR CNTR1 @ . ; --- read the counter
STOPT --- start task in stopped state
' MYTASK TASK? RUN --- load the task when this module loads
END
I would like to get an integration "channel" with a tachyon cog to support the ESP8266 asynchronous webserver/wifi.
Currently I'm submitted Tachyon words via the CONsole RX cog and having the Tachyon words return JSON results.
Looking for a better integration methodology, sanity check.
what are you running on the ESP8266?
When you run Lua, then you have a Read-Eval-Print loop like in Tachyon.
So depending if you want to set up a very generig interface or something more specific
the approach might differ.
I used it a year ago to send ping - water level measurements from Prop via ESP to ThingSpeak.
I just defined the sending function on the ESP and send the function call with parameters from the Tachyon/Prop.
@MJB I'm running a standard C++ build that has an asynchronous web server and tcp stack, not Lua. I have JS webpages served from this resource. AJAX calls in the webpages get serviced on the ESP and the handler sends TACHYON words via the CONsole RX port. Tachyon responds with JSON via the CONsole TX to the ESP handler which then propagates the JSON back to the originating AJAX call from the web page.
I am able to handle gauge data..., update stuff such as time date, configurations .... this way. Works pretty good right now. The build even has a HTML TERMinal built in that connects to the Tachyon CONsole while at the same time the AJAX calls are being handled. This was created by me with much "tech debt" and is not ideal. It would be grand to have a Tachyon COG dedicated to the AJAX channel.
The build also has a complete 4 Mb file system with file browser (CRUD too) and ACE Editor instance that is HTML, CSS, JS and FORTH aware, it's all actually very cool and what it does on that little $5 chip is amazing, much like Tachyon on the P1. Together they are really nice so far.
To get TACHYON to load on my Propeller with 32K I have
Changed the following in EXTEND.FTH:
All "1 I2C@" to "-1 I2C@" because CLKOUT makes a shift to the left so that
there shall many shift to until we get one 1 so the DIRA can be added to input, so
sda will be 1 at the last reading.
'I2C support
'CLKOUT (iomask dat - iomask dat2) REG6 = iomask) Shift msb bit out, clock high, clock low
CLKOUT andn OUTA, tos + 1 'ensure output will be active low
Breath OUTA, clockpins
Shl tos, # 1 wc
Muxnc DIRA, tos + 1 'make it an output if it is a low else float
'CLOCK (REG6 = iomask) Toggle multiple bits on the output)
CLOCK xor OUTA, clockpins
Tjz clkdly, unext
Mov x, clkdly
Djnz x, $
Jmp unext
There are also changes in "@EEWAIT" and "@EE"
In "BOOT" I have changed so 32K does not spend time on anything that does not fit.
pub BOOT
' TIMER.TASK 2 RUN
!POLLS
PLAIN .MODULES CR .AUTO .FREQ lsini CR
ep 128 = IF
f32cmd 3 " F32 " LOADCOG ( start up F32 )
THEN
The last thing I've moved and changed is for 64K
I have made so my 64k RTC is activated at startup.
pri ~I
SWITCH
$DE CASE " MCP79410" BREAK
$AE CASE " RTC EEPROM" BREAK
SWITCH@ 4 >> SWITCH
$4 CASE " I/O EXPANDER" BREAK
$7 CASE " DISPLAY I/O" BREAK
$A CASE " EEPROM" BREAK
$D CASE " RTC" I =rtc BREAK
" unknown"
pub lsi2c CR PRINT" *** I2C ***" 2 BY 128 FOR <I2C I 1+ I2C!? 0= IF CR I .BYTE SPACE I ~I PRINT$ THEN I2C> NEXT ;
Hope there is some of what you can use!
Now I'm going to play with my RTC.
Attached a zip file with my changes and the original as well as a diff file
@frida - The 1 I2C@ is not data, it is simply a flag, true or false, so the actual true doesn't matter.
What is "Breath"? This is the only change I see in this section, normally this is an "andn".
Skipping F32 during BOOT on a 32k system doesn't really make a big difference to the boot time anyway, however I recommend upgrading any 32k EEPROMs you have to 64k to gain many benefits with Tachyon. My interactive shell I'm testing uses upper EEPROM for the interactive line history and editing which is really useful during testing. Of course the upper 32k can store the dictionary after COMPACT and also the ROMs and other configuration parameters that can persist after a Prop tool load which wipes the first 32k.
That's a good idea to add that "I =rtc" to the lsi2c to automatically enable any RTC device it finds. However I just realized that this will also override other types of RTC at other addresses, so perhaps I will make it skip the setting if it is already set.
@rtc NOT IF I =rtc THEN
I try to make these extensions general rather than tied to specific hardware.
I will try to look at adding the I2C clock stretching which btw only occurs during the ack clock as per the I2C specs.
' I2C support
' CLKOUT ( iomask dat -- iomask dat2 ) REG6=iomask ) Shift msb bit out, clock high, clock low
CLKOUT andn OUTA,tos+1 ' ensure output will be active low
andn OUTA,clockpins
shl tos,#1 wc
muxnc DIRA,tos+1 ' make it an output if it is a low else float
' CLOCK ( REG6=iomask ) Toggle multiple bits on the output)
CLOCK xor OUTA,clockpins
tjz clkdly,unext
mov X,clkdly
djnz X,$
jmp unext
Sorry I didn'n see what
google translate was doing.
pub ackI2C@ 0
--- 25.5us @96MHz
pub I2C@ ( ack -- data \ Fetch a byte from the I2C bus - mirror ack signal 0 in = 0 out ) \ 36.6us
*SDA DUP FLOAT MASK 0 ( ack iomask dat )
8 FOR CLKIN CLOCK NEXT
OVER OUTSET --- make SDA an output
-ROT SWAP CLKOUT DROP CLOCK INPUTS
You can call ackI2C@ which is
0 I2C@
and
1 I2C@
when it sent its flag 0 or 1
As I understand it:
if sending a 0 or a 1 to CLKOUT
it is shifting 1 left
so bit 31 is in carry which is 0 and write a 1 to DIRA which set SDA low.
but if I use
-1 I2C@
it sent -1 bit 31 is 1, shiftet 1 left, then carry is 1,
which sent a 0 to DIRA which set SDA high.
' I2C support
andn OUTA,clockpins
shl tos,#1 wc
tjz clkdly,unext
mov X,clkdly
djnz X,$
jmp unext
As I understand the last read from I2C shall set SDA high = nack.
I've just had an idea for implementing a help file. If I assign a file for every word and place them inside a help folder it becomes easier to maintain and easy for a HELP function to find and display.
Now here's the thing, I have to create all these little files but it would be helpful if I had some help. If I create a Dropbox folder we could all edit then this would be helpful.
Sorry, I can't help myself. Oh, there I go again....
BTW - since I stick to 8.3 names for files I would have a lookup file that had the real name and the 8.3 name. The HELP command could lookup this file first and then know which file to open.
Frida - I think I see what you mean, so the change that you made was to use a -1 TRUE flag instead of 1 since CLKOUT shifts the MSB. That looks like that small bug was introduced when I added those CLKIN and CLKOUT instructions in V4 although I haven't noticed any side effects yet
I see that I have 1 I2C@ in quite a number of places so I may as well define a nakI2C@ etc. When I have some time I will test it out properly and implement the clock stretch at the same time.
As always, a good way to formulate a specification is to try various approaches. Well I found that what I really needed was an index file that had a list of all the words and which file to use. A lot of these words have a common help file, so all I do is find the word in the index and open up its help file while highlighting the word in bold with the simple rule that the first word on a new line that matches is close enough
Index file entries are simple enough, the first word on a line is the help file name and then after tabs or spaces are a list of words on that same line. There is no real size limit for a line but the help system works well enough too to have lines split up so that they are easier to maintain.
An index file is just a normal text file and looks a bit like this:
LOOPS.TXT FOR NEXT FROM BY FOR! FOR@ BY! LP! I J ADO LOOP+ LEAVE
PINIO.TXT LOW HIGH FLOAT OUTCLR OUTSET OUTPUTS H L N P F PIN@ IN
MATHS.TXT 1+ 1- + - 2+ 4+ 2- MIN MAX * UM* U/ U/MOD / UM/MOD64 UM/MOD32 */ UM*/ ABS ?NEGATE NEGATE
I2C.TXT I2C400 I2C100 ~D I2CFAST FI2C@ nakI2C@ I2C@ ackI2C@ I2C! I2C!? I2CSTOP I2CSTART I2C> <I2C> <I2C ?I2C i2cflg
SERIAL.TXT SHROUT SHRINP SPIWRB SPIWR16 SPIWR SPIRD SPICE
MEMORY.TXT IC! IC@ C@ W@ @ C+! C! C@++ W+! W! +! ! C~ W~ ~ BIT? SET? SET CLR BIT! CMOVE ERASE FILL <CMOVE
If you type HELP SHROUT it will search the index file for that keyword and when found it will use the file name found at the start of the line to open up the file and display that with the highlighted keyword. ANSI terminals respond to color and character attributes so it would be fairly easy to at least place the keyword in BOLD or some color.
Now, back to the original question, can anyone help with the help? If so I will look to upgrade my Dropbox account so I can add permissions if that will work but what I want is like a Tachyon folder that automatically synchs across users. Ideas?
I would contribute to HELP just so I can HELP myself with all the words I need HELP with.
Also the Intro needs HELP since 4x5 is the kernel we should be all developing upon.
Hey, less grumble, more go bro!
If you yourself incur some Tachyon "tech debt" doing what you can rather than balking at what you can't and then we have that multiplied by X contributors doing the same then we all reap the benefits collectively. I can fill in all the bits that can't be done by anyone else and of course provide inside information into how best to use it and why or have myself shown a better way.
On another thread there was a discussion about teaching and learning which shows that if handled properly by the teacher that student teaching student is the best way of learning - "Qui docet discit"
BTW, I am adding HINT to HELP just for one-liner extractions which may also be useful for embedding into EEPROM.
BTW, I will change the title of the intro to indicate V3 and save that as a copy so that the original link will point to the latest version.
I try to rite code for SHT31.
This is first i2c-device with ClockStreching although I have 50pcs for i2c-device.
But I cannot detect SCL-low at ClockStreching enable mode.
Do you have any idea?
Hi Peter,
just took some time to have a look at the proposed help system.
And I was wondering. Quite some time ago we started some help system
for EXTEND, which was to take the help documentation (onliner, help, examples) directly from the source code and maybe create the files via a little script (or even Tachyon itself during load ??, and writing the SD files ??)
Usually this way source & doc do stay in sync better.
Also I like having the descriptions close by when studying your source ;-).
Otoh I see that big doc/and especially examples blow up the source size.
So I am not exactly sure which approach really is the better.
Definitely ANY documentation will beat NO documentation ;-)
I haven't looked into using Dropbox for collaboration since it does not run on my old XP-Box
any more. But I might be able to use the Win7 Laptop after I find out how to set up 2 different drop box accounts on one single PC.
Notes: GETWORD is being deprecated in V4.5 in favor of deferred words causing unknown words to be converted to strings.
This preserves the flow of the input stream rather than diverting to GETWORD.
Example: FOPEN myfile --- FOPEN is deferred to execute at the end of the line so myfile is converted to a string which
the deferred FOPEN can then use without interrupt the input stream.
will this imply I can only have one of those on one line?
Or can I have multiple deferred actions?
GETWORD wsa quite handy some times, so I will need to study how to acomplish those tasks the new way ...
@mjb - what we need is something that is in one place and easy to maintain and just works as is. Having help information embedded in the source is handy but awkward too. There is no reason though that I can't also place the source files in the help folder so that the source code can be shown along with the help. So we have HELP and HINT and maybe SOURCE to access these files etc.
As to this new deferred action it is something I wanted to implement for quite a while as it is also useful for parsing non-Forth style text. Besides GETWORD really needs all the editing functions in it to work properly and although that could be tied in with other common functions it was not the way I wanted to go as I was reducing it down to single character processing. You may have noticed that if you typed something in interactively that it didn't really support and kind of editing and I would make mistakes all the time. The new interactive shell which is optional allows line by line processing even though the kernel processes characters plus it also feels more like a traditional Forth interaction:
.. 12 34 + . 46 ok
The .. is a handy but non intrusive line prompt and I may combine some of these elements into the kernel itself. My experiment with having the line number and code pointer etc as a prompt is fine I think, but as an option and as the default mode during a TACHYON END block load.
@caskaz - this clock-stretching thing is starting to get my attention although I have never ever had to use it myself but I can see that this is the approach that some sensor manufacturers have taken. Personally I would not want a device to stall, I'd prefer to read what it's got from the previous and still current reading without stalling. However, there are sometimes good reasons why a manufacturer would do it the way they do, and sometimes...
I will have a closer look at what you've done and try out a few things.
It's boot message.
BLINKEM
STOPEM
How does MYTASK stop?
If you are checking I/O states I used to have an "lsio" command but there is a lean and mean in V4.5 that pretty much tells me everything I need to know in one line. U means pulled-up, D for down, F for float.
btw - I had to snip some extra stuff off into the next post, the forum code complained that the body was way too big.
A9C0 1B3E 0 CLKFREQ A9D0 1B00 0 EXTEND.fth A9E0 0040 0 NOP A9F0 0013 0 DUP AA00 034A 0 2DUP AA10 004B 0 OVER AA20 0049 0 DROP AA30 0048 0 2DROP AA40 0051 0 SWAP AA50 0055 0 ROT AA60 0350 0 -ROT AA70 08CA 0 NIP AA80 0047 0 3DROP AA90 0012 0 ?DUP AAA0 004D 0 3RD AAB0 004F 0 4TH AAC0 0180 0 >R AAD0 0183 0 R> AAE0 017D 0 !RP AAF0 0202 0 !SP AB00 0082 0 AND AB10 0084 0 ANDN AB20 0086 0 OR AB30 0088 0 XOR AB40 02AA 0 ROL AB50 02BA 0 ROR AB60 008A 0 SHR AB70 008A 0 >> AB80 008E 0 8>> AB90 008C 0 SHL ABA0 008C 0 << ABB0 0092 0 8<< ABC0 008F 0 2/ ABD0 0094 0 2* ABE0 0093 0 4* ABF0 0214 0 SAR AC00 009D 0 SPLIT9 AC10 0096 0 REV AC20 0098 0 MASK AC30 009A 0 >N AC40 009B 0 >B AC50 00A3 0 0= AC60 00A3 0 NOT AC70 005F 0 1+ AC80 005E 0 1- AC90 005C 0 + ACA0 005B 0 - ACB0 0059 0 2+ ACC0 0058 0 4+ ACD0 181A 0 2- ACE0 0872 0 MIN ACF0 0876 0 MAX AD00 08DE 0 * AD10 0065 0 UM* AD20 08C8 0 U/ AD30 08BE 0 U/MOD AD40 08E4 0 / AD50 0074 0 UM/MOD64 AD60 0075 0 UM/MOD32 AD70 08D0 0 */ AD80 08FC 0 UM*/ AD90 0090 0 ABS ADA0 0061 0 ?NEGATE ADB0 0063 0 NEGATE ADC0 0125 0 FROM ADD0 0127 0 BY ADE0 0129 0 ADO ADF0 012C 0 FOR AE00 013F 0 NEXT AE10 013F 0 LOOP AE20 013D 0 +LOOP AE30 0123 0 I AE40 0344 0 J AE50 0330 0 LEAVE AE60 0338 0 FOR@ AE70 0332 0 FOR! AE80 033E 0 BY! AE90 032A 0 LP! AEA0 17B6 0 IF AEB0 17BE 0 ELSE AEC0 17D2 0 THEN AED0 17D2 0 ENDIF AEE0 1770 0 BEGIN AEF0 1774 0 UNTIL AF00 179A 0 AGAIN AF10 17B6 0 WHILE AF20 178C 0 REPEAT AF30 00B6 0 IC! AF40 00AF 0 IC@ AF50 00B0 0 C@ AF60 00B2 0 W@ AF70 00B4 0 @ AF80 00B8 0 C+! AF90 00BA 0 C! AFA0 00AC 0 C@++ AFB0 00BC 0 W+! AFC0 00BE 0 W! AFD0 00C0 0 +! AFE0 00C2 0 ! AFF0 0826 0 C~ B000 082E 0 W~ B010 0836 0 ~ B020 029A 0 BIT? B030 0890 0 SET? B040 087A 0 SET B050 0886 0 CLR B060 1A1C 0 BIT! B070 0042 0 CMOVE B080 08AC 0 ERASE B090 08AE 0 FILL B0A0 0896 0 <CMOVE B0B0 0000 0 RESET B0C0 003C 0 0EXIT B0D0 003E 0 EXIT B0E0 0356 0 ?EXIT B0F0 014F 0 CALL B100 0150 0 JUMP B110 00EE 0 (WAITPNE) B120 01D9 0 RUNMOD B130 00EB 0 (WAITPEQ) B140 0152 0 (EMIT) B150 0154 0 (EMITX) B160 015C 0 LOADMOD B170 016B 0 COG@ B180 016F 0 COG! B190 023C 0 COGSTOP B1A0 024A 0 pCOGINIT B1B0 0254 0 COGID B1C0 0260 0 REBOOT B1D0 0268 0 CLK B1E0 0276 0 CLKSET B1F0 0222 0 DELTA B200 0162 0 WAITCNT B210 0286 0 LAP B220 04A0 0 .LAP B230 046E 0 LAP@ B240 00FB 0 CLOCK B250 0100 0 CLKIN B260 00F7 0 CLKOUT B270 00CF 0 H B280 00D3 0 L B290 00D2 0 P B2A0 00D5 0 F B2B0 00F4 0 SHROUT B2C0 00F1 0 SHRINP B2D0 00DF 0 OUTSET B2E0 00DC 0 OUTCLR B2F0 00E0 0 OUTPUTS B300 00E3 0 INPUTS B310 00DE 0 HIGH B320 00DB 0 LOW B330 00E2 0 FLOAT B340 00E5 0 PIN@ B350 00E6 0 IN B360 0106 0 SPIWRB B370 0104 0 SPIWR16 B380 0107 0 SPIWR B390 0111 0 SPIRD B3A0 0119 0 SPICE B3B0 0842 0 0<> B3C0 0848 0 <> B3D0 085A 0 WITHIN B3E0 084E 0 U> B3F0 00A1 0 = B400 00A6 0 > B410 0854 0 < B420 00A9 0 U< B430 083E 0 0< B440 0366 0 HEX B450 0362 0 DECIMAL B460 035E 0 BINARY B470 090A 0 READBUF B480 096A 0 KEY B490 09B8 0 WKEY B4A0 0984 0 (KEY) B4B0 0966 0 KEY! B4C0 1334 0 doKEY B4D0 078E 0 EMIT B4E0 0676 0 CLS B4F0 067A 0 SPACE B500 07FA 0 SPACES B510 07FE 0 EMITS B520 067E 0 BELL B530 0686 0 CR B540 0682 0 <CR> B550 07DC 0 TAB B560 07DA 0 TABS B570 07EC 0 XTAB B580 0690 0 SPINNER B590 0512 0 .HEX B5A0 0526 0 .BYTE B5B0 0534 0 .WORD B5C0 053C 0 .LONG B5D0 036E 0 @PAD B5E0 0376 0 HOLD B5F0 0380 0 >CHAR B600 03D8 0 #> B610 03A0 0 <# B620 03AA 0 # B630 03CE 0 #S B640 03E4 0 <D> B650 0408 0 PRINT$ B660 041C 0 CTYPE B670 0164 0 LEN$ B680 0402 0 U. B690 04FE 0 .DP B6A0 03F6 0 PRINT B6B0 03F6 0 . B6C0 042C 0 ZPRINT B6D0 0DB4 0 CREATE B6E0 0DB8 0 CREATE$ B6F0 0D96 0 GETWORD B700 09C6 0 SEARCH B710 09E8 0 FINDSTR B720 0A72 0 NFA>BFA B730 0A8C 0 CFA>NFA B740 0AAC 0 NFA>NFA B750 0C72 0 @NAMES B760 809A 0 names B770 0AB4 0 WORDS B780 0EF4 0 UNSMUDGE B790 0C68 0 ALLOT B7A0 0C6C 0 ALLOCATED B7B0 09C2 0 HERE B7C0 0C4E 0 , B7D0 0C48 0 || B7E0 0C2C 0 | B7F0 0BD6 0 W, B800 0BC4 0 EXECUTE B810 8018 0 VER B820 0B02 0 .VER B830 1AAE 0 TACHYON B840 1A22 0 END B850 199A 0 CONSOLE B860 1A16 0 ECHO B870 031C 0 us B880 0308 0 ms B890 0304 0 seconds B8A0 0304 0 second B8B0 0F1E 0 DISCARD B8C0 02F6 0 TASK B8D0 02FE 0 REG B8E0 F800 0 BUFFERS B8F0 198E 0 COLD B900 0562 0 RAM B910 0564 0 SETDUMP B920 0590 0 DUMPX B930 058C 0 DUMP B940 0660 0 DUMPW B950 0666 0 DUMPL B960 0670 0 DUMPC B970 0654 0 DUMPA B980 065A 0 DUMPAW B990 0588 0 QD B9A0 081A 0 DEPTH B9B0 071C 0 .S B9C0 0FAC 0 DEBUG B9D0 0F44 0 .FREE B9E0 0F56 0 .STATS B9F0 02C8 0 IDLE BA00 1218 0 NOOP BA10 0B48 0 --- BA20 0B48 0 \ BA30 0B48 0 '' BA40 0B5E 0 ( BA50 0B72 0 { BA60 1218 0 } BA70 0B68 0 IFDEF BA80 0B6E 0 IFNDEF BA90 0C8C 0 " BAA0 03E8 0 (") BAB0 0C92 0 ." BAC0 0C92 0 PRINT" BAD0 0704 0 (.") BAE0 0E5C 0 == BAF0 0E2E 0 org BB00 80B8 0 @org BB10 0E4E 0 byte BB20 0E36 0 word BB30 0E42 0 long BB40 0E32 0 bytes BB50 0E38 0 words BB60 0E44 0 longs BB70 0E26 0 ALIGNORG BB80 0E18 0 ALIGN BB90 0E82 0 : BBA0 0EAA 0 pre BBB0 0EA2 0 pub BBC0 0EFE 0 pri BBD0 0EEA 0 ; BBE0 0EB2 0 RETURN BBF0 0F06 0 [C] BC00 0C88 0 ' BC10 0C7E 0 ['] BC20 0C76 0 NFA' BC30 8000 0 OFF BC40 00CC 0 ON BC50 00CC 0 0-1 BC60 19DE 0 ALIAS BC70 0BAC 0 GRAB BC80 13AC 0 [WS2812] BC90 14B8 0 [SDRDF] BCA0 1458 0 [SDRD] BCB0 14F0 0 [SDWR] BCC0 152C 0 [SDIO] BCD0 1594 0 [SSD!] BCE0 159C 0 [PWM32] BCF0 15E0 0 [PWM32!] BD00 1640 0 [PLOT] BD10 1670 0 [ROL3] BD20 16A0 0 [CAP] BD30 16F8 0 [WAV] BD40 1750 0 [MCP32] BD50 80BA 0 dmm BD60 80A8 0 errors BD70 80A0 0 uhere BD80 80A2 0 uthere BD90 80B0 0 flags BDA0 808C 0 prompt BDB0 80A6 0 uauto BDC0 80B2 0 keypoll BDD0 80C4 0 lastkey BDE0 1A02 0 rxpars BDF0 8092 0 rx BE00 8716 0 id BE10 9234 0 keytable BE20 7E35 0 @WORD BE30 7E18 0 uemit BE40 7E1A 0 ukey BE50 7E1E 0 base BE60 7E24 0 num BE70 7E14 0 uswitch BE80 0040 0 V4 BE90 0040 0 *end*I usually code MYTASK as an infinite loop. A simple way is to control the loop (MYTASK) behavior is to check the status of a word in the loop and continue or stop. You could also use the word to either do work in the loop or just NOP. The word can be changed from the console cog or another cog. I have only used two cogs in Tachyon ever so far, one to run an async serial receive buffer and the main console cog. In the main console cog I would just use timers and KEYPOLL to run everything else.
Here is simple code to exercise a task example
@org W@ == @rest --- remember \ * SIMPLE ROUTINE TO EXERCISE A TASK \ * AND LEDS ON THE PROP QUICKSTART BOARD \ * \ * USE THE WORD "STASK" TO START THE TASK \ * AND "TASKS" TO STOP THE TASK LONG RFLAG --- is the task to run LONG CNTR1 --- something to hold a count OFF RFLAG ! --- task not running : MYTASK 16 longs mystk --- give task some stack space, not needed here but for more complex tasks mystk LP! BEGIN RFLAG @ IF --- check the flag CNTR1 ++ --- increment the CNTR1 --- do more sutf ELSE NOP --- don't do anything THEN AGAIN ; : STOPT OFF RFLAG ! ; --- stop the tasks : STARTT --- start the task, don't start twice so STOPT first ON RFLAG ! ; : RCNTR1 CR CNTR1 @ . ; --- read the counter STOPT --- start task in stopped state ' MYTASK TASK? RUN --- load the task when this module loads ENDSample run
( 0048 $3938 ok ) rcntr1 0 ( 0049 $3938 ok ) startt ( 0050 $3938 ok ) rcntr1 405394 ( 0051 $3938 ok ) 649904 709895 729898 746051stopt ( 0052 $3938 ok ) rcntr1 1006126 ( 0053 $3938 ok ) 1006126 1006126 1006126 1006126 ( 0054 $3938 ok ) .TASKS 00: CONSOLE 0000 00 00 00 00 00 00 02: ? 2EA2 01 00 00 00 00 00 04: IDLE 0000 01 00 00 00 00 00 05: IDLE 0000 01 00 00 00 00 00 06: IDLE 0000 01 00 00 00 00 00 07: MYTASK 390A 01 00 00 00 00 00 ( 0055 $3938 ok )what are you running on the ESP8266?
I have made a couple of changes.
I have made so my 64k RTC is activated at startup. Hope there is some of what you can use!
That's a good idea to add that "I =rtc" to the lsi2c to automatically enable any RTC device it finds. However I just realized that this will also override other types of RTC at other addresses, so perhaps I will make it skip the setting if it is already set. I try to make these extensions general rather than tied to specific hardware.
' I2C support ' CLKOUT ( iomask dat -- iomask dat2 ) REG6=iomask ) Shift msb bit out, clock high, clock low CLKOUT andn OUTA,tos+1 ' ensure output will be active low andn OUTA,clockpins shl tos,#1 wc muxnc DIRA,tos+1 ' make it an output if it is a low else float ' CLOCK ( REG6=iomask ) Toggle multiple bits on the output) CLOCK xor OUTA,clockpins tjz clkdly,unext mov X,clkdly djnz X,$ jmp unextSorry I didn'n see what
0 I2C@
and
1 I2C@
As I understand it:
if sending a 0 or a 1 to CLKOUT it is shifting 1 left
but if I use
-1 I2C@
' I2C support ' CLKOUT ( iomask dat -- iomask dat2 ) REG6=iomask ) Shift msb bit out, clock high, clock low CLKOUT andn OUTA,tos+1 ' ensure output will be active low andn OUTA,clockpins shl tos,#1 wc muxnc DIRA,tos+1 ' make it an output if it is a low else float ' CLOCK ( REG6=iomask ) Toggle multiple bits on the output) CLOCK xor OUTA,clockpins tjz clkdly,unext mov X,clkdly djnz X,$ jmp unextAs I understand the last read from I2C shall set SDA high = nack.
Is my understanding correct?
( 0158 $39D6 ok ) i2cscan 0 1 2 3 4 5 6 7 8 9 A B C D E F 00 00 -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- <-- SHT31 10 -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 20 -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 30 -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 40 -- -- -- -- -- 45 -- -- -- -- -- -- -- -- -- -- <-- SHT31 50 50 -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- <-- eeprom 60 -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 70 -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- I2C devices:2 ( 0159 $39D6 ok ) 3 1shot <--Repeatability:High ClockStreching disable 81.80% 28.7degreeC ( 0160 $39D6 ok ) 1 1shot <--Repeatability:HighMedium ClockStreching enable -1-1-1-1-1-1-1-1-1-1-1-1-1-1-1-1-1-1-1-1-1-1-1-1-1-1-1-1-1-1-1-1-1-1-1-1-1-1-1Peter, I checked i2c word.
These use [*SCL HIGH *SDA HIGH].
Some i2c-device might not operate well.
I modified them because PropForth was same as.
https://github.com/caskaz/PropForth5.5/tree/master/HW_Extensions/i2c_device
Hi Peter,
As to this new deferred action it is something I wanted to implement for quite a while as it is also useful for parsing non-Forth style text. Besides GETWORD really needs all the editing functions in it to work properly and although that could be tied in with other common functions it was not the way I wanted to go as I was reducing it down to single character processing. You may have noticed that if you typed something in interactively that it didn't really support and kind of editing and I would make mistakes all the time. The new interactive shell which is optional allows line by line processing even though the kernel processes characters plus it also feels more like a traditional Forth interaction: The .. is a handy but non intrusive line prompt and I may combine some of these elements into the kernel itself. My experiment with having the line number and code pointer etc as a prompt is fine I think, but as an option and as the default mode during a TACHYON END block load.
