Prop 2 Fuse conundrum - Vpp ?! - Page 3 — Parallax Forums
13»
  • evanhevanh Posts: 16,974
    I should point out there is already 16 symmetrical Streamers that can provide burst data in this very fashion. But obviously can quickly become pin count limited.
    Just requires a little management to suit a particular interface.
  • jmgjmg Posts: 15,194
    .. and another company offers NV memory... this one targets the higher voltage/automotive nodes, and so is on 0.18um
    https://www10.edacafe.com/nbc/articles/1/1542783/eMemory-Unveils-Auto-Grade-EEPROM-IP-with-over-500K-Cycle-Endurance
    "The enhanced NeoEE is fully compatible with standard logic and Bipolar-CMOS-DMOS (BCD) process without the need for additional masks and process steps. The IP has been silicon verified at 0.18um/5V process, and technology development is underway for other 5V platforms."
    http://www.ememory.com.tw/html/products_neoee.php
    They also show
    http://www.ememory.com.tw/html/products_neomtp.php
    "NeoMTP is fully compatible with logic process, needing zero additional masks for 3.3V IO devices and 5V IO devices. Both types use a standard logic process without the need for any additional thermal budget. NeoMTP technology can deliver NVM block in system/in field programmability, maintaining high reliability, endurance and data retention over 10 years at 85° C 3.3V gate oxide) and over 10 years at 125° C (5V gate oxide) without any extra manufacturing costs"
    and this for Flash, which does need more masks...
    http://www.ememory.com.tw/html/products_neoflash.php
    "NeoFlash can be embedded in CMOS logic processes with only 2–3 additional non-critical masks. While floating gate flash technology requires a complex and expensive double poly process (needing up to 11 additional mask layers), NeoFlash’s single poly architecture and stripped-down manufacturing give it powerful advantages in the embedded flash category, especially in advanced nodes"
