Writing to SD card problem (solved)
I'm running the "SD Datalogger.c" that comes with Simple IDE, unmodified. The pic attached shows the expected input, and reads it back correctly.
The problem I have is using my PC/notepad to read the contents of test.txt file on the SD card -
I tried a couple of cards, formatting them fat32. Is there something I need to change to show dec values?
( 2
