Writing to SD card problem (solved)
xanadu
I'm running the "SD Datalogger.c" that comes with Simple IDE, unmodified. The pic attached shows the expected input, and reads it back correctly.
The problem I have is using my PC/notepad to read the contents of test.txt file on the SD card -
I tried a couple of cards, formatting them fat32. Is there something I need to change to show dec values?
( 2
/* SD Datalogger.side Application prompts you to type numbers into SimpleIDE Terminal, and records to SD. Plays back all numbers after you type q and press Enter. http://learn.parallax.com/propeller-c-simple-devices/sd-card-data */ #include "simpletools.h" // Include simpletools header . int DO = 22, CLK = 23, DI = 24, CS = 25; // SD card pins on Propeller BOE int main(void) // main function { print("Enter several values.\n\n"); // User instructions print("To see logged values, press\n"); print("Enter a second time.\n\n"); sd_mount(DO, CLK, DI, CS); // Mount SD card FILE* fp = fopen("test.txt", "w"); // Open a file for writing int n, status; // Number & status variables while(1) // Endless loop { print("> "); // User prompt status = scan("%d", &n); // Get number & status if(!status) break; // Status 0? Break out of loop fwrite(&n, 4, 1, fp); // Write number to SD card } fclose(fp); // Close the file print("\nYou entered:\n"); // List heading fp = fopen("test.txt", "r"); // Open a file for writing while(1) { status = fread(&n, 4, 1, fp); // Read from SD & get status if(!status) break; // If no more, break loop print("n = %d\n", n); // Display value } fclose(fp); // Close the file }
