$6 OEM prop plug alternative
in Propeller 1
Though you could probably build-in to the board for $3-4, sometimes that is cost prohibited or to small parts for a DIY.
And by using FTDI pin-out standard, there will be multi-use.
http://www.mouser.com/search/refine.aspx?Ntk=P_MarCom&Ntt=197655408
It is not a PropPlug without it!
If you need to invert the signal the fdti chip can be reprogrammed to do that.
I recommend that if anyone build a new P1 board, put dual rows of pins holes so it will be compatible with both Prop plug and LC234X.
For $14.99 on other mcu's platforms you get a full fledge debugger with energy trace and not just a uart-port,
so a don't make new buyer balk at having to spend more money that can not be used anywhere else.
With a few more handshake line choices, there is also this :
CP2102N-MINIEK
eBay seller alice1101983
ebay.com/itm/6Pin-USB-2-0-to-TTL-UART-Module-Serial-Converter-CP2102-STC-Replace-Ft232-Module-/400565980256?hash=item5d4397cc60
Discussion here
forums.parallax.com/discussion/comment/1358434/#Comment_1358434
