Tachyon V4 "DAWN" - exploring new worlds - Page 12 — Parallax Forums
191012141530
  • proplem wrote: »
    Hi there - shouldn't this
    ( 0003 $589E  ok )   -100 25 100 */ .
    1073741799
    give -25 ?
    ( 0011 $1A80  ok )   -100 25 * 100 / .
    -25
    Well I guess I should rename */ to U*/ but do you need a signed */ or other operations? There are probably a few areas I need to check for correct naming and operation.
  • I saw the */ operator in "Starting Forth" and thought - that fits.
    No need for a hurry - thanks for the quick response
    edited 2017-05-15 00:48
    Re: Revising DO and +LOOP practice - replacing with DOFOR
    Now that I've thrown DO and +LOOP into the trash even though they have never changed in all of Forth history, I find that I have a lot of code that has this practice of "end start" parameters locked into it. However I am testing this and even though it is "better" I still find that I'm getting my poor head around it. One of the main features of the new DOFOR LOOP method is that DOFOR takes a start parameter, a actual loop count, and a index increment that gets added to the start value each loop where normally this is simply the value of one.
    DOFOR doesn't run any faster than the previous loops I had since I use a rather fast branch stack but you really notice the difference in speed when the old +LOOP method is used.
    Here is the old method which times the loop for 1,000,000 (2000000/2) (80MHz)
    ( 0076 $4F0A  ok )   0 2000000 LAP ADO 2 +LOOP LAP .LAP
    176000336 cycles at 80MHz = 2.200sec
    So that is 2.2us/loop which is really slow.
    The equivalent DOFOR code (at 96MHz)
    ( 1619 $42BA  ok )   0 1000000 2 LAP DOFOR LOOP LAP .LAP
    48000432 cycles at 96MHz = 500.004ms
    Now each loop executes at 500ns regardless of the loop increment and always executes times the loop count regardless of the increment value.
    Since the loop count controls how times the DOFOR loop executes independently of the increment value it means we can do reverse loops which were very awkward with the conventional DO LOOP arrangement:
    ( 1641 $42BA  ok )   $7F 96 -1 DOFOR I EMIT LOOP
    ~}|{zyxwvutsrqponmlkjihgfedcba`_^]\[ZYXWVUTSRQPONMLKJIHGFEDCBA@?>=<;:9876543210/.-,+*)('&%$#"!
    ( 1642 $42BA  ok )
  • This doesn't append very far with that EXIT as the first word?
    .VER
      Propeller .:.:--TACHYON--:.:. Forth V4.3 DAWN 430170514.0076
    ( 0019 $4198  ok )   .MODULES
    MODULES LOADED:
    3304: EASYFILE.fth        SDHC card + FAT32 Virtual Memory Access File System Layer V1.2 170506-0000
    1A40: EXTEND.fth          Primary extensions to TACHYON+ kernel  - 170427-2200
    ( 0020 $4198  ok )
    pub APPEND ( eof -- fsptr )
    	EXIT
    \ reimplement - DO NOT ASSUME eof = 0 as in LEN$
         eof C!
         FSECT@ DUP 0EXIT DROP				--- exit with false if there is no file opened
         APPEND.BLK ( -- relblk )				--- find the active block to use
         8<< 2* sdbuf LEN$ BLKSIZ MIN +			--- add in offset allowing for a full block as well
    \     FILE@ FSIZE@ + OVER = IF DROP FALSE THEN
         DUP fwrite !
  • @D.P - Ahh, you saw that stub. Yes, I may get around to it tonight and put the scanning SDRD back in and all should be good again for 4.3.
    edited 2017-05-19 06:05
    V4.4 UPDATES
    V4.4 which introduced DOFOR in place of DO, ADO, and +LOOP seems to be working well. The only problem I've had so far is wrestling with some old code that complicated the stack to suit the old DO LOOP arrangement. After conversion it is not so complicated anymore. I wonder why Forth used this arrangement in the first place since I find that I almost invariably use the start index and count method but looping with +LOOP complicated this still.
    Because the loop stack is a separate stack in COG memory it had been implemented as fixed position registers with brute force ripple moves for push and pop. However there is one extra element on the stack for each DOFOR now and the ripple move was becoming too unwieldy so I made it a hybrid stack with the top four elements as fixed registers much the same as the data stack is implemented. The top four elements are: index (I); count (IY); and increment with the next element being the previous index (J). A count of 0 for either FOR or DOFOR will terminate the loop after the first iteration rather than for over 4 billion times which I am pretty sure would not be the intention.
    Also added is 16-bit literals since 15-bit were encoded as a single wordcode but anything was always encoded as three words (PUSH32,highword,lowword).
    There are lots of little enhancements and I still have room left in the cog after all this to enhance it some more.
    For fast I/O work there are the pin mask operators H L and F which will set pins High Low or Float (back to input) by reading a mask off the top of the stack without discarding. This is different from the P2 version that may have been used since the P2 version used PIN to set the mask internally whereas 4.4 just borrows the mask from the stack.
    EASYFILE is also working well on 4.4 so I will fix the APPEND operation in this version first since I am testing it.
    If you are still stuck with V3 just remember that even V4.0 is very old now and V4.4 is the goto version to use IMO. Wordcode being more compact and faster "overall" than bytecode, who woulda thunk it?
  • V4.4 UPDATES
    V4.4 which introduced DOFOR in place of DO, ADO, and +LOOP seems to be working well. ...
    Hi Peter - congratulations ro the new minor version!
    As I'm always curious to stay on the bleesing edge but I don't know if that is always welcome to you. You solved a few issues recently which took time on your side.
    Additionaly it could be of advantage to branch v44 into a new folder.
    Best regards,
    Proplem
  • V4 is looking better every day but as an added measure I have introduced an auxiliary stack for those times when you need to push stuff out of the way. Traditionally the return stack was used but in my embedded 24/7 reliability view this should never ever be as this could lead to uncontrolled execution <crash!> if values other than return addresses are left there. So I have used the loop stack with >L and L> but this stack is limited in cog memory so hence the auxiliary stack using >A A> and A@ which should be used for shuffling and even temporary constants via A@.
    The doNEXT address interpreter has been tweaked as well just to give some priority to calls to wordcode so they run a bit faster again. Just remember too that for fast I/O you can use H L and F to control outputs with sub-microsecond resolution, good enough even to bit-bash serial RGB LEDs or 1-wire etc.
    A moment ago I was just fixing up some little bug I had introduced in the filesystem in creating files. Anyway I normally preallocate contiguous sectors when creating a file and so I specify the maximum file size with a number. Just to make it easier I created two small words KB and MB which are nothing more than a left shift operation but very useful. To create a 16MB file just:
    16 MB mk NETLOG.TXT
    or to ASCII wide dump the 1 KB of a file offset 1 MB from the start of the file:
    1 MB 1 KB FS DUMPAW
    ( 0060 $4202  ok )   FOPEN WARPEACE.TXT
    ...opened at 0000.48C0 for 3226652
    ( 0061 $4202  ok )   1 MB 1 KB FS DUMPAW
    0010.0000:  .down his back..."Why, this one seems..." he began, turning to the assistant..."And how we've been begging, your honor," said th
    0010.0080:  e old soldier, his jaw.quivering. "He's been dead since morning. After all we're men, not.dogs.".."I'll send someone at once. He
    0010.0100:   shall be taken away--taken away at once,".said the assistant hurriedly. "Let us go, your honor.".."Yes, yes, let us go," said R
    0010.0180:  ostov hastily, and lowering his eyes and.shrinking, he tried to pass unnoticed between the rows of reproachful.envious eyes that
    0010.0200:   were fixed upon him, and went out of the room......CHAPTER XVIII..Going along the corridor, the assistant led Rostov to the off
    0010.0280:  icers'.wards, consisting of three rooms, the doors of which stood open. There.were beds in these rooms and the sick and wounded
    0010.0300:  officers were lying or.sitting on them. Some were walking about the rooms in hospital dressing.gowns. The first person Rostov me
    0010.0380:  t in the officers' ward was a thin.little man with one arm, who was walking about the first room in a.nightcap and hospital dres
    ( 0062 $4202  ok )   16 MB mk NETLOG.TXT
    ( 0063 $4202  ok )   ls-l
    -rwxrwxrwx 1 502     500        65536 Aug  4  18:01 SCR.ROM
    -rwxrwxrwx 1 502     500      1048576 Dec  2  15:56 SYSLOG.TXT
    -rwxrwxrwx 1 502     500      3226652 Aug 30  07:27 WARPEACE.TXT
    -rwxrwxrwx 1 502     500         1895 Apr 15  15:09 SEE-V4.FTH
    -rwxrwxrwx 1 502     500         7229 Apr 26  23:24 LIFE.FTH
    -rwxrwxrwx 1 502     500        18944 Mar  9  12:30 SPLAT-V4.FTH
    -rwxrwxrwx 1 502     500      1048576 Jan  1  00:02 TEMP.TXT
    -rwxrwxrwx 1 502     500     16777216 Jan  1  00:07 NETLOG.TXT
  • Hi @Peter - couldn't resist and tried v4r4
    - DOFOR is looking good
    - IoT5500 builds successful up to EASYFILE, EASYNET is not yet ready.
    - separating the new version into a new folder is fine - thank you - maybe others with more Forth code will appreciate too
    - EASYFILE: I tried to use a Transcend 16 GB micro SDHC without success. Should it work or is is there still a SANDISK dependency? It could be that mine is "mis-formatted" because of many trial end errors. I ask to be sure whether I should try to reformat it which can eat up spare tachyon time :-(
    - COMPACT4r4.FTH should be renamed to COMPACT-v4r4.FTH :-)
    Again thank you for sharing and holding up the Tachyon flag so high!
    Best regards,
    proplem
  • proplem wrote: »
    Best regards,
    proplem
    I'll get down to the bottom of why some cards don't work but it should be a very minor thing I'm sure, I have cards other than Sandisk that work. I'm doing quite a bit of work on EASYFILE in 4.4 at present,
    I haven't quite gotten onto EASYNET yet but it should be straightforward enough.
    Now that the files are in their own folders I can probably remove the version from the name and leave that information in the file itself.
    V4.4 starts up in non-case sensitive mode although fast block mode load via TACHYON END is still always case sensitive. Use OFF ANYCASE to enforce case sensitivity.
    I've been using 4.3 for my projects but with these improvements and stability testing I see I can easily start using 4.4. With an SD card in I can also fast load FL to a temporary or specified file which buffers everything into the file and then loads it automatically. If you want to update a text file on the card over the console you can SAVETEXT <myfile>, paste/send the text file as you would normally and use esc to finalize. This will also update the file size in the directory. Using FL or SAVETEXT without a filename will cause it to use TEMP.TXT.
    Since the minimum cluster size is 32k bytes it doesn't matter if the file only had 4kB but the new text has 6kB etc. I like to preallocate at least 64kB though and there is no reason why you couldn't preallocate 1MB per file anyway, unless you have 8,000 of them. The cluster chain for a file is contiguous and the number of clusters allocated has to be scanned to determine the maximum but it is just as easy to preallocate anyway.
    Here is a scan of clusters of sectors with sector address header where each * represents a cluster with data (non-zero) plus I've inserted labels for id.
    Each line represents 4MB so it is interesting to see all that unused space after the MBR (really just partition info) and before the FAT tables, that's around 4MB you can hide files and config in.
    PART
    0000.0000 *...............................................................................................................................
    BOOT       FAT1
    0000.2000 **..............................................................................................................................
        FAT2
    0000.4000 ............................................................................................................**..................
    0000.6000 ................................................................................................................................
    												   ROOT
    0000.8000 .........................................................................................***************************************
    0000.A000 ********************************************************************************************************************************
    0000.C000 ********************************************************************************************************************************
    0000.E000 ********************************************************************************************************************************
    0001.0000 ****************************************************************************************************************************...*
    0001.2000 ................................................................................................................................
    0001.8000 .................................
    ( 0014 $441E  ok )   @ROOT .LONG
    0000.9646
    ( 0015 $441E  ok )   @BOOT .LONG
    0000.2000
    ( 0013 $441E  ok )   DIR
    SCR1.5
    COMPACT .FTH .....a 0000.964E    May 21  2017 15:23   3,156
    LIFE    .FTH .....a 0000.9656    May 22  2017 04:29   7,609
    PTZ485  .FTH .....a 0000.9666    May 21  2017 01:00   875
    SEE     .FTH .....a 0000.966E    May 19  2017 13:34   1,998
    WARPEACE.TXT .....a 0000.9676    Aug 30  2015 07:27   3,226,652
    SPLAT-V4.FTH .....a 0000.AF16    Mar  9  2017 12:30   18,944
    LOVE    .WAV .....a 0000.AF3E    Feb 16  2015 08:06   14,630,692
    POPCORN .WAV .....a 0001.1EDE    Jun 17  2014 06:15   117,804
    FRED    .TXT .....a 0001.1FC6    Oct 13  2005 22:43   2,474
    ( 0014 $441E  ok )
    [/quote]
    Well if you are using 4.3 for production are you logging data? If so how since APPEND is still a stub.
    I keep looking for the stub to be implemented.
    I did quite a lot of testing of various SD Cards. I found some quirks that were not completely explained from the flowchart of commands. With that code I didn't find any that I couldn't read/write to. Some of the cards I tried were cheapie eBay 8GB and 32GB cards.
    I won't be back in Oz for 3 weeks. When I get back I will look up my notes as I don't think I have all the info on my laptop I have with me. IIRC I posted the info on a P2 thread, so I'll also look for that.
  • D.P wrote: »
    [/quote]
    I'm actually working on the 4.4 version, I started checking it the other day, so with all my file system work at present I will be able to sort it out. I didn't actually use APPEND for some of these files. It's easier sometimes to create a new file each time it starts up if the old file has already been used but I might make it a point right at the moment to get APPEND working ASAP as I had already started doing so in V4.3.
  • Hi Peter,
    The last time I downloaded and built 4.4 (17 05 30) with easyfile and issued mount on a non sandisk card the system went into constant reboot mode. I then cycled power and the easyfile.fth module was gone. Hum, I will wait for another minor update and try again.
    edited 2017-05-30 22:57
    D.P wrote: »
    Hi Peter,
    Wow! are you able to repeat that?
    I am actively using V4.4 easyfile and some non Sandisk cards work but the worst that should happen is that they fail to mount, not wipe easyfile. There is no mechanism for that to happen so if it is repeatable then if you don't mind trying it out again and maybe copy your terminal screen from the initial compile to when it gets corrupted. I'd like to get to the bottom of this but is there any reason why you can't just the Ultras?
    btw, that version number doesn't sound right, typo?
    DAT { *** VERSION *** }
    version       long 440_170528
    vertime       word 1600
    vername       byte "4.4 DAWN"                   ' fixed 8 character version name
  • Dang, I was probably mixing versions of extend and easyfile, again!
    Using >FILE does cause a restart.
    This is using a brand new 16GB SanDisk Ultra.
      Propeller .:.:--TACHYON--:.:. Forth V4.4 DAWN 440170528.1600
    MODULES LOADED:
    33F0: EASYFILE.fth        SDHC card + FAT32 Virtual Memory Access File System Layer V1.2 170521-0000
    1B00: EXTEND.fth          Primary extensions to TACHYON V4.4 kernel  - 170521-0000
    AUTORUN BOOT
    FREQ = 96.0MHz
    *** INITS ***
    INIT#0 3988 MOUNT
    Loading cog 3 E50A F32
    *** ROMS ***
    0,848 VGA32x15
    0,392 HSUART
    1,900 F32
    0,196 MONO16
    1,900 F32
    *** I2C ***
    A0 EEPROM
    PPNET: &00.00.00.00 @2,000,000
     CODE:$4442 =16962 bytes   NAME:$52F4 =8460 bytes   DATA:$792A =794 bytes    =3762 bytes free    Data Stack (0)
    --------------------------------------------------------------------------------r)
    ( 0001 $4442  ok )   .FILES
    #0 *CLOSED*
    #1 *CLOSED*
    #2 *CLOSED*
    #3 *CLOSED*
    ( 0003 $4442  ok )   DIR
    NO NAME
    SPOTLI~1.    .h..d. 0000.BD00    May 14  2017 22:23   0
    RUNTIME0.TXT .....a 0000.B440    May 14  2017 22:23   262,144
    RUNTIME1.TXT .....a 0000.C380    May 14  2017 22:23   262,144
    RUNTIME2.TXT .....a 0000.D2C0    May 14  2017 22:23   262,144
    ( 0005 $4442  ok )   FOPEN RUNTIME0.TXT
    ...opened at 0000.B440 for 262144
    .FILES
    #0 *CLOSED*
    #1 *CLOSED*
    #2 *CLOSED*
    #3 RUNTIME0.TXT .....a 0000.B440    May 14  2017 22:23   262,144
    ( 0006 $4442  ok )   RW
    ( 0007 $4442  ok )   0 APPEND
    ( 0008 $4442  ok )   .S
     Data Stack (2)
    $0168.8000 - 23625728
    $0000.B440 - 46144
    ( 0009 $4442  ok )   >FILE
    MODULES LOADED:
    AUTORUN BOOT
    FREQ = 96.0MHz
    *** INITS ***
    INIT#0 3988 MOUNT
    *** ROMS ***
    0,848 VGA32x15
    0,392 HSUART
    1,900 F32
    0,196 MONO16
    1,900 F32
    *** I2C ***
    A0 EEPROM
    ( 0001 $4442  ok )
  • @D.P - The append operation has not been fully checked out, I know there is something more I need to look at. I'll see if I can fit half an hour in and fix it.
  • MJBMJB Posts: 1,235
    Hi Peter,
    loaded up 4.4 2017-06-04 on PropBOE
    My old 4GB SD-HC is not properly handled (worked well with Tachyon before)
      Propeller .:.:--TACHYON--:.:. Forth V4.4 DAWN 440170604.1130
    MODULES LOADED:
    336C: EASYFILE.fth        SDHC card + FAT32 Virtual Memory Access File System Layer V1.2 170521-0000
    1A80: EXTEND.fth          Primary extensions to TACHYON V4.4 kernel  - 170521-0000
    AUTORUN BOOT
    FREQ = 80.0MHz
    *** INITS ***
    INIT#0 38F0 MOUNT
    Loading cog 3 E506 F32
    *** ROMS ***
    0,848 VGA32x15
    0,388 HSUART
    1,900 F32
    *** I2C ***
    42 I/O EXPANDER
    A0 EEPROM
     CODE:$43AA =16810 bytes   NAME:$52D0 =8496 bytes   DATA:$792A =794 bytes    =3878 bytes free    Data Stack (0)
    ( 0001 $43AA  ok )   MOUNT
    Mounted 5957.3321-0000.0000 TXX  TXT  0MB (0/cluster)
    ( 0002 $43AA  ok )   ls
    [OJ”mºð]     [°Þ
                      žÓ.}3õ   IŒE@¤ìn.³å   [CJ÷ñ•áƒ]
    ( 0003 $43AA  ok )
    ( 0013 $43AA  ok )    0 $200 SD DUMP
    0000.0000:   54 45 53 54  58 58 20 20  54 58 54 20  00 00 4A 78    TESTXX  TXT ..Jx
    0000.0010:   CD 77 00 00  00 00 00 00  00 00 00 00  00 00 00 00    .w..............
    0000.0020:   00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00    ................
    0000.0030:   00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00    ................
    0000.0040:   00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00    ................
    0000.0050:   00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00    ................
    0000.0060:   00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00    ................
    0000.0070:   00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00    ................
    0000.0080:   00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00    ................
    0000.0090:   00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00    ................
    0000.00A0:   00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00    ................
    0000.00B0:   00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00    ................
    0000.00C0:   00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00    ................
    0000.00D0:   00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00    ................
    0000.00E0:   00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00    ................
    0000.00F0:   00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00    ................
    0000.0100:   00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00    ................
    0000.0110:   00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00    ................
    0000.0120:   00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00    ................
    0000.0130:   00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00    ................
    0000.0140:   00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00    ................
    0000.0150:   00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00    ................
    0000.0160:   00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00    ................
    0000.0170:   00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00    ................
    0000.0180:   00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00    ................
    0000.0190:   00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00    ................
    0000.01A0:   00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00    ................
    0000.01B0:   00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 02    ................
    0000.01C0:   03 01 0B 38  F8 CC 00 20  00 00 00 88  77 00 00 00    ...8... ....w...
    0000.01D0:   00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00    ................
    0000.01E0:   00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00    ................
    0000.01F0:   00 00 00 00  00 00 00 00  00 00 00 00  00 00 55 AA    ..............U.
    ( 0014 $43AA  ok )   $200 $200 SD DUMP
    0000.0200:   54 45 53 54  58 58 20 20  54 58 54 20  00 00 4A 78    TESTXX  TXT ..Jx
    0000.0210:   CD 77 00 00  00 00 00 00  00 00 00 00  00 00 00 00    .w..............
    0000.0220:   00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00    ................
    0000.0230:   00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00    ................
    0000.0240:   00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00    ................
    0000.0250:   00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00    ................
    0000.0260:   00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00    ................
    0000.0270:   00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00    ................
  • D.PD.P Posts: 790
    edited 2017-06-05 23:05
    MJB wrote: »
    Hi Peter,
    There is a known problem with "other" cards, SanDisk cards work well. Hoping for a update to EasyFile.fth that restores other cards to usable and also fixes APPEND. I'm still using V3 for "production".
  • Hi
    I start to learn Tacyon.
    I loaded TachyonV4.4.spin(Xtal:5MHz) to eeprom.
    And loaded EXTEND-V4r4.fth.
    I try to understand CHARLCD.fth because I don't know Tachyon manner at all.
    I copy/paste it to TeraTerm.
    But error occured.
    Code-loading is wrong?
      Propeller .:.:--TACHYON--:.:. Forth V4r4 DAWN 440170522.0000
    MODULES LOADED:
    1AC0: EXTEND.fth          Primary extensions to TACHYON V4.4 kernel  - 170521-0000
    AUTORUN BOOT
    FREQ = 80.0MHz
    *** INITS ***
    NO ROMS
    *** I2C ***
    A0 EEPROM
     CODE:$33B0 =12720 bytes   NAME:$5B66 =6298 bytes   DATA:$76E8 =216 bytes    =10166 bytes free    Data Stack (1)
    $0000.76D8 - 30424
    ( 0001 $33B0  ok )   TACHYON
    ( 0131 $3474  ?? )    ??? in
    ?? at MASKS
    ( 0133 $3474  ?? )    ??? in
    ?? at 16>>
    ( 0176 $350E  ?? )    ??? in 56789 at lcdlm
                                                 ??? in 56789 at xpos
    ( 0178 $3512  ?? )    ??? in +,-./ at ypos
    ( 0179 $3512  ?? )    ??? in +,-./ at xpos
     ??? in 3528  ?? )
     at ypos
    ( 0189 $3530  ?? )    ??? in
     at xpos
    ( 0195 $353C  ?? )    ??? in ・巐 﨟t ypos
    ( 0196 $353C  ?? )    ??? in ・巐 﨟t ypos
                                                ??? in ・巐 﨟t ypos
    ( 0235 $358C  ?? )    ??? in 烙痰邃繙 at ADO
    ( 0296 $3644  ?? )    ??? in 兎波品北 at bigptr
    ( 0301 $3652  ?? )    ??? in 杭纂従神 at BL
    ( 0306 $3660  ?? )    ??? in ⑭・渦 梶t bigptr
    ( 0307 $3660  ?? )    ??? in ⑭・渦 梶t ypos
    ( 0308 $3660  ?? )    ??? in ⑭・渦 梶t ypos
    ( 0309 $3660  ?? )    ??? in ⑭・渦 梶t xpos
    ( 0313 $367C  ?? )    ??? in 、・ウ пt lch
    ( 0315 $367E  ?? )    ??? in t lcdmode
    ( 0320 $367E  ?? )    ??? in t xpos
    ( 0321 $367E  ?? )    ??? in t xpos
    ( 0329 $36A4  ok )    ??? in
    ?? at BL
              ??? in
    ?? at xpos
    ( 0330 $36B2  ok )    ??? in  at xpos
                                           ??? in  at xpos
    ( 0334 $36CE  ok )    ??? in QRSTU at dpy
    ( 0335 $36CE  ?? )    ??? in GHIJK at dpy
    ( 0336 $36D6  ok )    ??? in =>?@AB at dpy
    ( 0337 $36DC  ok )    ??? in 1234567 at dpy
    ( 0338 $36E2  ok )    ??? in '()*+ at dpy
                                               ??? in '()*+ at dpy
    ( 0339 $36EC  ok )    ??? in t dpy
    ( 0344 $370C  ok )    ??? in 邃繙艾 at lcdmode
    ( 0345 $3710  ok )    ??? in 忤掣桀毳 at lcdmode
    ( 0349 $372A  ok )    ??? in ・⑭・ 堰t lcdlm
    ( 0358 $3738  ?? )    ??? in t dpy
    ( 0359 $3738  ?? )    ??? in t xpos
                                         ??? in t ypos
    ( 0360 $3738  ?? )    ??? in t lcdlm
                                          ??? in t lcdmode
    ( 0376 $3798  ?? )    ??? in }~ at lch
    ( 0378 $37BE  ?? )    ??? in qrstuvwx at BL
                                                 ??? in qrstuvwx at LOOKUP
    ( 0384 $37BE  ?? )    ??? in qrstuvwx at LCDchar
     ??? in 12345678 at SP! ?
    ( 0528 $383E  ok )    ???
       End of source code, 0097  errors found  Load time = 680578160 cycles at 80MHz = 8.507sec
    Code bytes used = 1166
     CODE:$383E =13886 bytes   NAME:$5830 =7120 bytes   DATA:$7714 =260 bytes    =8178 bytes free    Data Stack (0)
    ( 0529 $383E  ok )
    ( 0530 $383E  ok )   \
    ( 0531 $383E  ok )
    ( 0532 $383E  ok )
  • caskazcaskaz Posts: 957
    edited 2017-06-07 08:41
    I have qustion.
    ( 0001 $33B0  ok )   1 0
    ( 0002 $33B0  ok )   .
    0
    ( 0003 $33B0  ok )   .
    1
    ( 0004 $33B0  ok )   .
    30424
    ( 0005 $33B0  ok )   .
    12844
    ( 0006 $33B0  ok )   .
    0
    ( 0007 $33B0  ok )   .
    0
    Executed '.' under stack-empty, 30424 and 12844 ouput.
    What is this [30424][12844]?
    And more '.' , '0' output.
    Why error ocurr?
    ( 0001 $33B0 ok ) LAP LAP LAP LAP LAP LAP LAP LAP LAP LAP LAP LAP LAP LAP .LAP
    0 cycles at 80MHz = 0.000us
    ( 0001 $33B0 ok )
    Why 0.000us?
    This is abnormal?
    edited 2017-06-07 20:20
    @caskaz - good to see you are ok, we missed you from the forum for a while there.
    I just made a copy of CHARLCD.FTH in the V4r4 folder and modified an ADO to the newer DOFOR format which simplifies the normal DO LOOP arrangement. Since it has a few tables in there it can sometimes require a bit more compile time so I slowed minicom down to 10ms line delay (no character delay) @921600 baud. TeraTerm works fine at this baud rate too.
    ( 1772 $3374  ok )   TACHYON V4
    ( 0441 $37AE  ok )
       End of source code, 0000  errors found  Load time = 546758448 cycles at 96MHz = 5.695sec
    Code bytes used = 1082
     CODE:$37AE =13742 bytes   NAME:$580E =7154 bytes   DATA:$76F4 =228 bytes    =8288 bytes free    Data Stack (0)
    ( 0442 $37AE  ok )
    ( 0443 $37AE  ok )   ?BACKUP
    BACKUP /
    ( 0444 $37AE  ok )
    ( 0445 $37AE  ok )   ??
    MODULES LOADED:
    3374: CHARLCD.fth         Character LCD - 8-bit parallel interface  V1.2 170607.0000
    AUTORUN BOOT
    FREQ = 96.0MHz CODE:$37AE =13742 bytes   NAME:$580E =7154 bytes   DATA:$76F4 =228 bytes    =8288 bytes free    Data Stack (0)
    As regards stack operations you will not find any warnings on stack underflow as that only slows down any runtime system but there is protection built in so what you are seeing is simply the "top of stack" register since the top four items are maintained in fixed registers to suit the Prop's lack of indexed addressing. That's how a fetch from memory is something as simple as:
    ' @  ( addr -- long ) Fetch a long from hub memory
    FETCH                   rdlong  tos,tos
                            jmp     unext
    which is only one of the reasons why Tachyon is so fast. You can check the stacks at any time with a simple ^? (control key + ?) or zero the stack with ^S. Most Forths will automatically clear the stack on encountering an error but I Tachyon does not act so presumptuously, it's my data, don't touch it and certainly means we don't have to keep typing in the same stuff every time we get an error.
    To measure how fast that operation is we take laps which capture the timing difference between the last two laps. Here we try it on @:
    ( 0466 $37AE  ok )   0 LAP @ LAP .LAP
    48 cycles at 96MHz = 0.500us
    ( 0467 $37AE  ok )
    It doesn't matter how many laps we do beforehand:
    ( 0467 $37AE  ok )   0 LAP LAP LAP LAP @ LAP .LAP
    and in fact LAP LAP is used by .LAP to calculate the lap overhead which is subtracted from the reading which is why LAP LAP .LAP will always report 0us.
    LAP can be used in many situations but it is always important to LAP only that section that you are interested in, so say for instance you want to time a FOR NEXT loop you won't get an accurate overhead by reading one but if we do 1 million of them we can easily divide the reading from milliseconds to nanoseconds.
    ( 0469 $37AE  ok )   1,000,000 lap for next lap .lap
    48000176 cycles at 96MHz = 500.001ms
    I didn't want to add the 1,000,000 to the reading although we can't help including the overhead of FOR itself but each NEXT takes 500ns to count and loop. Notice too that in interactive mode lower case can also be used as can standard numeric separators too.
  • Hi Peter.
    Thank you for your reply.
    I placed 1 2 3 4 on stack.
    After ctrlKey+S, I checked stack by [ctrlKey+?].
    There is 4 on stack although Data Stack is 0.
    Why?
     ( 0477 $37EA  ok )   1 2 3 4
                        ctrlKey+?
    ( 0478 $37EA  ok )    CODE:$37EA =13802 bytes   NAME:$5848 =7096 bytes   DATA:$76F4 =228 bytes    =8286 bytes free    Data Stack (4)
    $0000.0004 - 4
    $0000.0003 - 3
    $0000.0002 - 2
    $0000.0001 - 1
                             ctrlKey+S  (same as [ctrlKey+s])
                             ctrlKey+?
    ( 0479 $37EA  ok )    CODE:$37EA =13802 bytes   NAME:$5848 =7096 bytes   DATA:$76F4 =228 bytes    =8286 bytes free    Data Stack (0)
    ( 0480 $37EA  ok )   .
    4
    ( 0481 $37EA  ok )   .
    0
    ( 0482 $37EA  ok )   .
    0
    ( 0483 $37EA  ok )
    edited 2017-06-08 05:46
    caskaz,
    Yes, you had 4 values on the stack and then you initialized the stack but this does not change the top 4 values that are held in registers.
    InitSP  word      LMM
                            movs    stkpop,#datastk
                            movd    stkpsh,#datastk
                            mov     udepth,#0
                            jmp     #EXIT
    The !SP function is actually implemented as LMM code in hub since it doesn't have to be fast but it can't really be high level code since it would use the very stack it is trying to initialize.
    When you print the top value it is read from the tos register which still holds 4 however the print operation itself uses the stack of course and the residual value is 0 which is dropped at the end but is still present in the tos register, hence the zero values thereafter.
    Btw, DROP calls POPX where you can see it detects a depth of zero and skips popping the stack.
    POPX                    mov     X,tos                   ' copy old tos into X
                            tjz     udepth,#POPX_ret        ' do not allow ext stack to pop past bottom
                            sub     udepth,#1 wz
                            mov     tos,tos+1
                            mov     tos+1,tos+2
                            mov     tos+2,tos+3
                            sub     stkpop,#1
                            sub     stkpsh,dstinc
    stkpop                  mov     tos+3,datastk
  • Hi Peter.
    I'm reading CHARLCD.fth.
    I don't understant below;
    IFDEF CHARLCD.fth
    @rest	org              <--- What this mean?
    FORGET CHARLCD.fth
    pub CHARLCD.fth        ." Character LCD - 8-bit parallel interface  V1.2 170607.0000 " ;
    @org W@	== @rest	<--- What this mean?      --- remember
    I try to input [#lcdpins 8 MASKS == #lcdbus].
    After entered [#lcdpins 8 MASKS ], [???] is printed.
    [???] indicate error?
    [MASKS] don't exist?
    How to use [WORDS]?
    edited 2017-06-08 13:17
    caskaz
    @rest org simply restores the data memory that was used by CHARLCD if it already exists as is the case when this code is reloaded over an older version. When CHARLCD is compiled it will create a restore marker to data memory using "@org W@ == @rest" which reads the contents of the data pointer @org and assigns that value to the constant @reset.
    Tachyon separates the dictionary and data space from code space so that the hub RAM can be utilized more effectively. V3 would mix data in with code which was not always a good thing since code could be corrupted by overwriting.
    You can define your own LCD pins and hopefully if you do this before you load CHARLCD then it will detect this and not use its own default. If you change the default in CHARLCD itself rather than predefine them then you should rename it so that you know since CHARLCD could be upgraded anytime. Predefining these constants will allow you to load the current version of CHARLCD without having to maintain the patch. However I will probably update CHARLCD so that it can be loaded without having to specify pins beforehand in much the same way EASYFILE and EASYNET and other drivers now accept a parameter at runtime to specify the pins and settings to use. CHARLCD is intended to be used as an output device as if it were a remote serial display rather than have an application call the various internal methods. If you type in LCD from the console then all output will be redirected and handled correctly on the LCD display for instance.
    Some traditional Forth words are replaced with more familiar symbols so that rather than CONSTANT I end up using == instead. One reason for this is readability as I have found over the years that the word itself tends to overshadow the value and name we are creating. Then there is the opposite also in traditional Forth such as the print number symbol . which seems to disappear into the source code and can easily be skipped over. Although I retain these traditional symbols I favor using PRINT instead of . just as I also favor using pub and pri and even pre instead of a plain : but then again that is also to convey information for the compiler so that all pri defined words have a tag set in the header so that a RECLAIM operation can remove those headers from the dictionary and reclaim memory.
    There's a lot of very good reasons for why Tachyon does things differently just as there are very good reasons why the Propeller chip does things differently from traditional CPUs.
  • Hi.
    Please teach me how to get string.
    Incase of PropForth c" abcde" lcd_str
    I can get length and address for string[abcde] by c" ".
    How to do same in Tachyon?
    edited 2017-06-09 10:45
    caskaz
    All strings in Tachyon are passed as an pointer to a null terminated string. They are defined simply as a leading quote as such:
    " Hello World"
    Here's how we use it:
    ( 0001 $33AA  ok )   " Hello World" 16 DUMP
    0000.33AC:   48 65 6C 6C  6F 20 57 6F  72 6C 64 00  10 80 8A 05    Hello World.....
    ( 0002 $33AA  ok )   " Hello World" LEN$ .
    11
    ( 0003 $33AA  ok )    " Hello World" PRINT$
    Hello World
    ( 0004 $33AA  ok )    " Hello World" BUFFERS OVER LEN$ 1+ CMOVE
    ( 0005 $33AA  ok )   BUFFERS 16 DUMP
    0000.7800:   48 65 6C 6C  6F 20 57 6F  72 6C 64 00  00 00 00 00    Hello World.....
    ( 0006 $33AA  ok )   BUFFERS PRINT$
    Hello World
    ( 0007 $33AA  ok )   BUFFERS 5 LEFT$ PRINT$
    Hello
    ( 0015 $33AA  ok )   " Hello World" $7E00 $!
    ( 0016 $33AA  ok )   $7E00 PRINT$
    Hello World
    In those examples we are working interactively but strings are exactly the same whether compiled into a definition or typed in at the console. There are no special forms since Tachyon is always compiling, which is why you can run loops without putting them in a definition first. Strings may also be terminated by any byte with the msb bit as well.
    This here may be the smallest hello world program, just one line that executes immediately.
    ( 0013 $33AA  ok )   PRINT" Hello World"
    Hello World
    Btw, as you type in the console Tachyon will compile each word immediately upon a space or enter, and automatically execute the temporary compilation on an enter. There are some immediate words that execute as soon as you type them too of course.
    Also, try WWORDS which prints out a formatted color-coded dictionary list otherwise you can always do the simpler WORDS or even hit ^W
    .VARS will list all the variable and constants it tries to find.
    lsi2c will list all I2C devices it finds etc.
  • HI.
    I try to write code.
    But error occur at code's top.
    Tachyon freeze.
    What is wrong?
    TACHYON V4
    IFDEF 2wire_charLCD.fth
    @rest	org
    FORGET 2wire_charLCD.fth
    pub 2wire_charLCD.fth        ." 2-wire Character LCD  2017/06/09 21:22:20 " ;
    @org W@	== @rest	--- remember
  • First Tacyon code.
    Cannot load at all.
    What part is wrong?
