DEBUGIN multiple values
in BASIC Stamp
Hello all,
It has been a while since I had gotten a chance to play with my stamp.
As usual I find myself searching and finding no direct answer to my question.
I am trying to find out if you can set multiple values in one go using DEBUGIN command.
Example:
Time1 VAR NIB
Time2 VAR NIB
DEBUG "Set Time1 and Time2"
DEBUGIN DEC1 Time1
This would only write data to the "Time1" variable. Is it possible to write a statement that could write data to both "Time1" and "Time2" variables?
Like when you set a date using the following format MM/DD/YY it would set three variables
Thank you
Dr. Vetter
Example:
Time1 VAR NIB
Time2 VAR NIB
DEBUGIN DEC1 Time1
Thank you
Dr. Vetter
You could write: DEBUGIN DEC Mon,DEC Day,DEC Year
Note that there has to be some non-numeric delimiter following each value. This could be "/" so
05/10/2017<cr> would be acceptable for the values 5, 10, and 2017. The delimiter itself is discarded.
Even after all these years you are still my #1 when it comes to getting me back on track. You are very knowledgeable
Dr. Vetter
