Elev 8 V2 Step 37
Hello, I am working with the Elev 8 v2, and I am stuck on step 37, where I have to sync the ESCs and perform a range test. I'm using a Spektrum DX6i transmitter, and a Spektrum AR610 receiver. Gear mode is on (from what I could make out through the online manual of the transmitter I have it on by having the Gear switch in the top left to the 0 mode), the trim is at 0, and I always have my throttle stick up before attempting to sync the ESCs, but after hearing the two beeps I think I hear another beep, which i'm not sure if it is the long beep the instructions refer to.
Anyways, assuming that the long beep is correct and I did the first part right, the Range Check doesn't work. The area where I have built the drone is roughly 40 ft and I have been doing this step at roughly that range. If it is necessary to be 90 ft away, I can fix that. Apart from that I follow the instructions by going to Range Check and holding the Trainer/Bind button, I am supposed to be able to control the drone, but the motors just continue to beep, sometimes very fast, sometimes at pattern of a beep per second, sometimes not in unison. Any ideas or help would be much appreciated.
Usually, this beeping meant that the receiver ranges were outside of what the Hoverfly OPEN board viewed as acceptable.
