Sabertooth Motor Controller Experience
MacGeek117
Hey all!
Does anyone here have experience with the Sabertooth line of motor controllers from https://www.dimensionengineering.com/ ? (2x5 is what I'm looking at, but experience with any of them would help)
If any of you have used them with SLA batteries, did you notice a difference in battery charge life due to the regenerative braking?
The chassis I'll be using is tank-drive, so I'm curious whether the regen system justifies the added expense over a cheaper, more simple H-bridge.
Thanks!
Thanks!
Have used several Sabretooths ( 2 x 25A), IIR. Great units to work with. They were non-regens but could do dynamic braking, I think.
For what its worth, I don't think the tank tread will coast sufficiently to do much for battery charging.
Cheers
Do you want current feedback? Do you plan to use encoders?
I haven't used a Sabertooth motor controller but I've used other Dimension Engineering products. I think they make good stuff but it's often at a higher price than many of the other options.
You're probably already aware of the options from Parallax but here are a couple of links anyway. I've used both these h-bridges myself. The MC33926 dual h-bridge can supply two motors with 3A continuous with 5A burst. The MC33926 provides current feedback. The DHB-10 can control two 10A motors with encoder feedback.
If you're looking for more options you should check out Pololu. They have lots of motor control options.
Edit: About 1/3 of the way down is a good explanation and sample formula. Small robots don't have much inertia, especially if you're using gear motors. You won't see much of a return.
https://www.roboteq.com/index.php/applications/100-how-to/160-understanding-regeneration
https://www.amazon.com/33GB-520-Motor-Control-170RPM-350RPM-Torque/dp/B01J1TE8L2 are the motors coming with the tank chassis.
I doubt I'll be able to mount encoders on the chassis, but I may be wrong.
I've used the MC33926 before, pretty solid driver.
I'll most likely end up going with the MC33926, thank you for reminding me of that, Duane.
Building this project with a friend, so most likely won't be posting anything specific about it until May or June.
Thank you all for your comments!
I use them in my tank track projects
Wheel chair motors with snowblower tracks
The new ones have some new features.
Like a separate circuit for the motor brakes and the ability to switch from RC mode to serial mode
This was the last one I built
