Download Failed on Propeller Board (Windows 8.1)
Hi,
Downloading Programs to my Propeller Demo Board (2008, Revision G) with the Propeller IDE (Version 0.33.3) does not work. The IDE responds with "Download Failed".
Here is what I tried so far:
1. Prior to connecting the board to my computer, I installed the Parallax Drivers (www.parallax.com/usbdrivers). I connected the board and Windows installed the FTDI Driver (Version 2.12.24.0, Date 28.09.2016 ; apparently, not the Parallax Drivers. Subsequently, Windows created a COM4 Port and the device appeared as "FT232R USB UART" in "Devices and Printers".
2. In the IDE, after selecting COM4, I started the download, I saw the blue TXLED on my board flashing up once, and the error "Download Failed" was reported.
3. I changed the Serial USB drivers to "Propeller Demo Brd". I restarted, re-connected the board, again COM4 Port was created, with the Parallax signed driver (Version 2.12.16.0). Again, the download failed with the blue LED flashing up once.
Any suggestions?
Thanks!
Edit:
Do I have to change the port settings for the driver? Currently, it is configured with 9600 bits per second, 8 Data Bits, No Partiy, 1 Stop bit and no flow control.
Any suggestions?
Thanks!
Edit:
Thank you. I just took a look at the schematics and noticed that the board is not usb powered. What a stupid mistake.
I'll try to find a power supply and report back.
