Friday Quiz #5 (REAL PRIZE!)
Okay boyz 'n' girlz, this is a tough one, so fasten your seat belts!
I've given laser-cut wooden sliding tile puzzles as gifts recently. One, in particular, involves sliding letter tiles in a 4x4 grid to form eight common English words: 4 across (left-to-right), with 4 down (top-to-bottom), simultaneously. There are 15 tiles and a grid of 16 letters that they slide over. So there's always a blank space over the grid of letters, whose revealed letter is part of the answer. (Only one person has solved it, so far.)
But I'm going to make it easy on you guys. Rather than requiring the tiles to slide, you can just place them atop the grid, however you wish, to solve the puzzle.
Whoever posts the first correct solution as a 4x4 grid of common English words will receive an original wooden version of the sliding tile puzzle, sent for free by postal mail anywhere in the world (except to countries that the U.S. government prohibits me to send stuff).
Here are the tiles and the underlying grid:
Unlike with the other Friday puzzles, I will not be posting an answer if no one gets it after a certain amount of time. It's up to one of you to do that and to reap the reward.
Knock yourselves out!
ecru [adjective] very light brown in colour, as raw silk, unbleached linen, etc.
PM me your mailing address, and I'll send you your prize.
I had expected it to be programming exercise.
While we're on word puzzles, I'll mention a favorite of mine. Heard it from a radio station and I won concert tickets many moons ago. Take the word:
SPARKLING
and remove one letter to leave a legit word intact. No rearranging letters. Keep removing one letter, leaving a legit word, all the way down to one letter.
Go forth and multiply subtract.
Oops. Didn't read the posts above! This was a search with a bigger dictionary that includes abbreviations like hgwy for 'highway'.
Leave it to me to do it the hard way.
Also I had a ready made list of words for my online word ladder (doublets) solver.
So I quickly hacked a program together in C# and let it do the hard work.
Here's the output:
Amazing how fast computers are. Less than two seconds run time, and that on a fairly lowly AMD A8-5500 @ 3.2 GHz. With the bigger 6759-word dictionary, it took 10.8 seconds to find and display the 5 solutions.
I've attached the fourLetterWords.txt file if anyone wants to try it out for themselves - you need to put that file in the same folder where you compile your program. It should work okay with most versions of Visual Studio - you just need to start a new project as a c# console application and paste the above listing in - I'm using the (free) Visual Studio Community 2015 edition on this PC - I suppose I should really update it to a newer free version.
SPARKLING
SPARLING (fish)
SPARING
SPRING
PRING (vertical movement)
RING
RIN (Japanese money)
IN
I
Dave
sparkling
sparking
sparing
paring
pring - sound made by a bell
ping
pig
pi
i
Thanks for sharing your code! 'Tis truly a tour de force -- in short order, too!
For all of you lexophiles out there, this puzzle's solution is a heterogram, which means that no letter is used more than once. 4x4 English heterograms are quite rare. A 5x5 is reputed to be impossible. But think about it: 26 letters in the alphabet, and you'd have to use all but one of them. Plus, with six possible vowels, almost every one would have to be shared between two words.
RIN?
Dunno nuttin' 'bout doze. Here's what I did...
Sparkling
Sparking
Sparing
Spring
Sprig
Prig
Pig
Pi
I
much nicer
dave
Sparkling (a way of describing a decent gin and tonic)
Parkling (one of those very small cars that you can't see when you think there's a space available)
Arkling (a small ark, able to hold two of only few species)
Arking (how Noah is said to have spent the rainy season once)
Aking (what city folks are after a strenuous workout)
Akin (what country folks are after a strenuous workout)
Kin (thos'ns that convention says you have to include in your will, even if you don't want to)
Ki (prefix to "yi yippy ki yay")
K (what you text when you mean "yes")
By that logic, Fo is also a real word...
As in Fee fi fo fum, mods...
It's beautifully made with interlocking pieces that can't fall out. Instructions and additional information are laser engraved on the back.
It would be an interesting exercise to write a program to search for similar puzzles with unique solutions. If no one else wishes to tackle it, I may have a go myself after a couple of weeks (I'm deep into a different programming project right now).
With a sliding block puzzle like this there is parity involved - exactly half of the positions that can be obtained by freely swapping blocks can be obtained by sliding the blocks, and the remaining half of the 'free swap' positions can't be reached. The classic example is the '15 puzzle' with fifteen sliding blocks numbered 1 to 15: by taking out and swapping, say, the '14' and '15' blocks, the conventional solution arrangement becomes unreachable. When computer searching for solutions then any odd number of block swaps gives an unreachable position and any even number of swaps generates a position that can be reached.
With Phil's letter version of the puzzle, this opens up the possibility of using two sliding blocks with the same letter - that would mean that there would never be any tantalizing solutions that could be reached by freely placing the blocks but not by sliding them.
Regarding the parity issue, I made sure to assemble the puzzle originally with the solution in view, then to slide the blocks in order to scramble them. If I had placed the blocks in the puzzle at random, there would have been a 50% chance that it be unsolvable.
Also, I had to redo the first of these puzzles I constructed. I had made the mistake of laying out the blocks to be laser cut in solution-order. Then I realized that the woodgrain pattern would be a dead giveaway to someone paying attention. So I had to scramble the blocks in CorelDraw before cutting them out.
