virus auto download attempt via forum postings ?
jmg
I get this popup when I go into one thread - seems to automatic launch download, and tries to save a suspect file to my hard drive ?
Mods may like to see which posting triggers that ?
Screen grab attached, shows forum and auto-download messages...
Actually, FF on my Android phone always wants to download youtube attachements automatically as well.
Strange it automatically tries to do that ? - the message claims the forum is the one that wants to download the file ?
I see this under Safari as well, so it's not just Chrome.
Just say fuggetaboutit to the download, and mark the thread for a moderator, who will hopefully fix the embed code (or ask the original poster to do it).
I'm cruising here all the time with Chrome on Windows or Linux and have yet to see it.
See posts #1 and #2 above.
It seems a fixable forum issue.
Manually it can be fixed as Gordon suggests: "mark the thread for a moderator, who will hopefully fix the embed code (or ask the original poster to do it)."
but it seems the forum should be able to either automate that, or prevent the occurrence.
That guy is always posting questionable stuff...
Post #2 does.
When I hit that link my Chrome warns against a swf download. Even if i accept it nothing happens.
Except I have now have a .swf file in my downloads directory which this Win 10 machine does not know how to open.
But what forum thread/post did that come from?
Only the download thing that normally appears at the bottom left of the screen contained a warning and asked if I wanted to continue.
Chrome on Win 10.
[you tube ]RjjW dMiIGcc [/ you tube]
My Chrome on Win 10 tries to download a file called "RjjWd MiIGcc&rel= 0. swf"
Except for some arcane video sites that still deliver only Flash content, or running some Flash-based software like MIT's Scratch (but not Blockly, which rightly doesn't use Flash), there is ZERO reason to keep Flash installed. Everyone who's smart provides their videos in MP4, OGG, or other format, delivered to you based on your system.
You would never want to open an unknown SWF file. Depending on the version of Flash installed, you could open the Horrors of Hades upon yourself.
Just paste the URL without any tags.
This is supposed to be the better way so there are fewer files to download for people on mobile devices.
I edit my old posts with videos to use this new method whenever I see them.
FWIW, I see the SWF file warning frequently myself.
I think I only get the pop-up if there are multiple such links in a thread.
And I think I only get the auto-downloads after I have read that thread once before. Or at least there's some kind of correlation there.
Hi Xanadu,
To test out this situation I've edited your posts on that page containing the tubetags. Sure thing as Duane noted- by replacing them with url's (not in url tags, just plain-text urls), then the preview function works in the browser I'm using, and the enforced-download-error is gone.
In this case the solution seems to be:
2. If possible have [you tube ] tags auto convert to https://youtu.be/RjjWdMiIGcc format, OR else have the forum ignore tube tags.
I'll report this back to Bump along with this thread, so he can check any other replies/ideas anyone might wish to add.
caveat: As always, this task may not be so simple to implement and will join a queue of priorities which the mods are not aware of. If we notice and can edit new posts as an interim solution, then mods might do that to help- as time allows!
Tell Chrome not to do that. You have the option to be prompted, which is a far, far better thing to do.
I will fix that post.
In any case, the modification that was done to the thread fixed the problem.
This setting gives you the option of not downloading content you don't want.
