How to simulate 600lbs
T Chap
I want to test a method to move an object up and down that weighs 600lb. This includes not only getting the motor and drive train right but also a method to hold it at any point with a brake. I am looking for options to simulate the object (I don't have the object) without having to stack up gym weights. I only need a few inches travel to test the concept. Any ideas on this ? A spring would be ideal but a spring does not have constant pressure over a distance.
As I finished this the idea of a fulcrum came to mind where a lower weight could be used out on a boom so I could maybe get by with 100lb of weights.
I remember bringing a 500lbs safe home in the back of my pickup, and having to get it in my basement by myself. A ramp from the bed to the basement floor, sliding the safe down on blankets with come alongs. 600 pounds is a lot of weight, be carefull.
EDIT: A scale connected to an immovable object would be even easier.
Do you have a job to do, or are you proving mechanical advantage?
And a good start.
Or a spherical cow.
If the distance is relatively small you may be able to use a pneumatic system for testing. A 4-6 foot pipe with a piston could provide several inches of travel with only a small change of the load. For instance a 4" id pipe would require ~ 50PSI of pressure to produce 600 lbs of force.
Yep. Good thing about a pneumatic system like that is that you can move the piston a few inches and the load only increases a small amount.
A piston in a 4 inch pipe about a 12.6 inch surface area across the pipe. 50 pounds of air pressure on each square inch of piston is a total of 628 pounds.
Given your truck weighs 4000 pounds and the tire pressure is 40psi I we can estimate the area of the contact patches between tire and road. 100 square inches.
The "over unity" thing can happen if you have that piston in your pipe pushing on a 1 inch square area "piston rod". That piston rod can now exert 628 pounds pressure on a square inch!
Yes that is what I meant.
https://www.mcmaster.com/#6491k431/=16jdwmw
4.5 bore @50psi = 795 force!
I need to make some estimates on the range of force over a certain distance that is easy. Thanks for the idea.
The fulcrum seems to give the most consistent load but due to the lever length, it's working travel at the load will be restricted. So I will have to compare the consistent load of air versus lever and find what gives the most travel for testing purposes.
The scale idea is good but allows for no travel at a near consistent load.
Excellent idea! Actually, you could probably go even cheaper. It look like there are some 200lb hanging scales for less than $50. Combine that with your class 3 lever above (the load arm can be shorter).
https://en.wikipedia.org/wiki/Block_and_tackle
And don't forget the load cell to measure the force. (S-beam type)
That would be a block and tackle. Two blocks of pulleys connected by a rope looped through the high and low pulleys to multiply the force.
