BS2p with v1.3 firmware
in BASIC Stamp
Hello friends,
I resumed an old BS2p that I purchased more than 10 years ago. I ask you if with the BS Setup Stamp Editor v2.5.3 it is still usable, and if I have to use any specific setting.
Once connected to my PC with the Super Carrier Board, the BS2p was detected, with firmware version 1.3.
Thank you in advance.
A lot of time elapsed from when I played with the BS and I forgot some practice...
I checked the wiring more times and the voltages at the LCD connector, the BS2p seems to work. The display is simply blank, like it was unconnected. Same trial and result with another display.
Any idea why and where to find the trouble?
It would be helpful for us if you could post a picture of your hookup CLEARLY showing all the connections.
