TACHYON O/S V3.0 JUNO - Furiously Fast Forth, FAT32+LAN+VGA+RS485+OBEX ROMS+FP+LMM+++ - Page 105 — Parallax Forums
1103105107108109
  • D.P wrote: »
    Got the RX side of this esp8266 client working, need to breadboard a module to remove the FTDI conflict from the TX side.
    Great, let me know how it goes. You shouldn't need to do much if the FT232 chip is still connected, may just diode couple them with a pullup so they both can talk to the Prop.
    Now, if the transmit data from the ESP goes into a PPNET rxtx line through a resistor and back out again into the ESP rxd line we should be able to access a network of these devices.
  • Great, let me know how it goes. You shouldn't need to do much if the FT232 chip is still connected, may just diode couple them with a pullup so they both can talk to the Prop.
    Can you sketch what you mean by "diode couple them both" plz.
  • D.P wrote: »
    The TXD lines of the FT232 and ESP chip (their outputs) can be diode OR'd together since they are active low we then add a pullup on the Prop's RXD pin. That way one OR the other can be talking to the Prop, but obviously not at the exact same time.
    1156 x 570 - 19K
  • Well I have to say this is really cool. A 5$ olimex esp8266 module hooked to a prop with tachyon. https is included in the build for the olimex board. Thanks for the diagram Peter, works great!
    1788 x 962 - 73K
    1754 x 1304 - 110K
  • MJBMJB Posts: 1,235
    D.P wrote: »
    @D.P
    what do you run on the ESP?
    is the 'Microcontroller Console' a page / applet served by the ESP?
    Where can I get it?
    Will be great to run PPNET over ESP in addition to telnet / http ...
  • For the Olimex ESP8266 board I am using THIS
    It was difficult to determine (for me at least) the proper flashing and settings for the Olimex board and propeller to work.
    Flash with this command after installing the project.
    //flash the module, replace with your serial port
    esptool.py --port /dev/tty.usbserial-A700fKOV --baud 460800 write_flash -fs 16m -ff 80m  \
     0x00000 boot_v1.5.bin 0x1000 user1.bin  \
     0x1FC000 esp_init_data_default.bin 0x7E000 blank.bin
    If something goes bonkers or you want to erase bad settings erase the entire flash using this CLI
    //eraase entire flash, replace with your serial port setting
    esptool.py --port /dev/tty.usbserial-A700fKOV erase_flash
    I have included the esp_init_data_default.bin because for some reason it is not included in the project? Just drop in the same folder as the project. On the home page of the system after boot set the TX/RX lines for the uc (prop with tachyon loaded) to swapped, 13, 15 and hook them up to 30, 31 on the prop.
    I'm using MacTerm to telnet at 115200, for some reason the standard telnet client in OSX was causing the prop to reset on connect, MacTerm works absolutely great so far.
    Have fun
    edited 2017-02-08 21:04
    D.P wrote: »
    Have fun
    I have only used NodeMCU / Lua so far to write little applications.
    So you are using a predefined SW which just acts as a HTTP / Telnet?? to Serial Gateway ?
    EDIT: thanks, read the documentation - looks nice ...
    My idea was to implement the ppnet on ESP8266/NodeMCU/Lua to use the ESPs as additional sensor / actor nodes in a Tachyon-ppnet ...
  • Yes that project has pre-built bin files for "as is" use, handy for rapid prototyping i.e. not much accidental complexity.
    Complete source is in just plain C ( :) ) for those who can/want to modify (like me) and manage the build chain. Double fun.
  • Apologies if this has been posted before or if I'm using the wrong files. I'm a newbie to TACHYON and am working my way through the introduction. I've not read the whole of this giant thread.
    I've been using the PING sensor and found it would sometimes lock up. This seems to be due to the PING definition in EXTEND.FTH which generates the trigger pulse:
    DUP HIGH >R R> LOW --- 10us trigger (dummy cycles)
    On my (96 MHz) prop:
    LAP >R R> LAP .LAP 1.833us ok
    so perhaps the definition should be changed to:
    DUP HIGH 10 us LOW --- 10us trigger pulse
  • ceptimus wrote: »
    Hi,
    You are only measuring the push and pop instructions onto the R stack and not the DUP, HIGH, LOW and original pin number being pushed onto the stack to begin with.
    LAP 5 DUP  HIGH  >R R> LOW  LAP .LAP   6.500us ok
    Post up your code so we can help if there is another "problem" to find.
  • ceptimusceptimus Posts: 135
    edited 2017-02-09 22:19
    Yes, but 1) 6.5 uS is still too short to reliably trigger the PING sensor, and 2) it's wrong to include the time for both the HIGH and LOW instructions plus the DUP. The DUP happens before the pulse even starts and we're interested in the actual length of the pulse not the time from when HIGH starts till LOW finishes. I suppose it is fair to include either HIGH or LOW though - assuming they both execute in the same time.
    on my 96MHz prop:
    0 LAP >R R> LOW LAP .LAP 3.166us ok
    The code is just what's in Peter's Introduction and in the latest EXTEND.FTH
    PING sometimes locked up with it as written - because it's waiting for a 'Echo' from the sensor but the sensor never sends one because it missed the too-short 'Trig'. Once I replaced the >R R> with 10 us it's working fine. I suppose I could put multiple >R R> instructions in until LAP times it at 10us or more - but it's better to have a solution that will work regardless of the prop clock speed (within reason).
  • I didn't understand the context. Maybe it's legacy code from a different version in EXTEND. You got it working, great.
    ceptimus wrote: »
    on my 96MHz prop:
    with all the speedups Peter implemented recently (and maybe in the future)
    the
    10 us
    is definitely the save way to go.
    I used the old code in V2.7 and it worked OK
    edited 2017-02-10 02:50
    Yes, that is a good point about the PING sensor, I haven't worked with it in a while and the older software probably worked fine. But small values of microseconds delays will have some overhead anyway although I just checked this in V4 and 10us comes out as 10.5us so I could trim the overhead but I wouldn't try to to use delays less than 10us using the "us" word.
    DUP HIGH 10 us LOW will be slightly over 10us but as HIGH or LOW take 3us in V4 because they are coded in high level but OUTSET and OUTCLR and much faster if you need precise control.
    I've updated EXTEND with this line in PING
    MASK DUP OUTSET 9 us OUTCLR
    which I will check should deliver a 10.5us pulse.
    In fact if you time a single I/O operation plus the delay this will give you a better idea of the width of the pulse. In V4 I can do this:
    ( 0034 $33B2 PBJ )   0 LAP OUTSET 18 FOR NEXT LAP .LAP
    960 cycles at 96000000Hz  or 10.000us
    edited 2017-02-10 08:41
    I used it in V2.7 ...
    it definitely worked fine :-) !!
    and in this case the timing does not need to be exact anyhow - just loooong enough.
  • Thanks Peter and everyone else.
    I guessed it was the speed improvements made in updates to TACHYON that had 'broken' PING. Main reasons I posted were: 1) To make sure I wasn't doing something stupid, and 2) If I wasn't doing something stupid then it's a good idea to update the Introduction document so that newbies like me don't hit a hurdle really early on causing them to give up on TACHYON! :smile:
    edited 2017-02-10 11:25
    @ceptimus
    If we all gave up whenever we hit hurdles we would do the same with other hurdles. Anything worthwhile is worthwhile doing. I figure if I've made all this effort to come this far I'm certainly not going to let it go to waste but make it count.
    Know that if you persevere with this path then it will certainly be very rewarding and well worth the effort. You will be able to do simple things with ease, and you will be able to do complicated things with ease also. But like spoken languages you must learn to think in that language to become fluent rather than translating and comparing which will only hinder you.
    Talking about PING, I was thinking the other day that rather than calling my ping-pong network PPNET, which doesn't sound that good when spoken :) that I should call it PINGNET instead. as the word ping has a ring to it (pun). I want to formalize it and make it a standard object that can be included as needed into any Spin/PASM project, even a bitmap VGA object that I have used in the past that is a bit of a memory hog at over 24kB. This means I can hang a VGA Prop off the bus and do some remote graphics easily.
    sounds good
    "give me a PING ... just one PING ..."
    Ramius in 'Hunt for red october' ...
    does it ring ?? ;)
  • MJB wrote: »
    sounds good
    does it ring ?? ;)
    There's a song that I recall
    My mother sang to me
    It's a little muddled after all these years
    since I was ninety three
    "Ping pong iddle I po"
    edited 2017-02-11 02:59
    Looks like no one picked up the Goons influence in my last post then :)
    Please let me know if there is anything I can do to improve the Intro pages. There are some things I take for granted but I try to keep it simple.
  • proplemproplem Posts: 233
    edited 2017-02-11 10:24
    Hi all,
    as some of you remember I'm currently fighting with a tachyon parallel lcd graphics driver for the LameStation.
    I have the simple exercise of setting some bits in a long variable and it costs me much time to figure it out.
    I made a register with maybe the following value
    long lcd
    %1101_1011_1001 lcd !
    Later I want to manipulate maybe the upper two bits (but it could differ)
    %10XX_XXX_XXXX
    How do I solve this (efficiently) in FORTH? In C I would use a bit array.
    BTW I feel sick and maybe my brain isn't fully working (if the solution is too silly).
    I looked in the introduction and glossary but didn't find it - this could be a hint to add a bit manipulation paragraph to the introduction.
    Thanks in advance,
    proplem
  • proplem wrote: »
    Hi all,
    long lcd
    %10XX_XXX_XXXX
    I looked in the introduction and glossary but didn't find it - this could be a hint to add an bit manipulation paragraph to the introduction.
    Thanks in advance,
    proplem
    There is a clear and set operation in Tachyon but it is currently used for bytes, not longs. You could create the long equivalent:
    : LCLR ( mask addr -- )		DUP @ ROT ANDN SWAP ! ;
    : LSET ( mask addr -- )		DUP @ ROT OR SWAP ! ;
    But of course you could use the byte set and clear easily by referring to the offset of the variable, that is lcd+1. So to write to certain bits the idea is that you clear all the relevant bits and then set them with the data that you want. Writing directly to the byte in the long though is easier than trying to apply a mask.
    However I think you don't need these operations, the LCD driver is probably simpler than you think. I could write one "blind" in the sense that I can't try it out but you could try it out and debug and tweak it if you like.
    @Peter ... sure you can do it blind ;-) ...
    happened with me a few times in the past as well ...
    I ask here some thing I don't understand fully ..
    and when I check back Peter provided the full blown solution
    so maybe give @Problem a little bit of a chance to develop it himself ;-)
    @Proplem
    as for the bit in long ...
    to me sounds overcomplicating things.
    I don't think this will even be required to drive this little LCD.
    If you align the 8 data bits at a byte border 0..7, 8..15, 16..23 ...
    then there are only a few control lines to manipulate
    define a mask for each control pin
    9 MASK == yxPin
    then later
    yxPin OUTSET ... yxPin OUTCLR ...
    or a bit slower, but really nice to read
    9 == xyPin
    xyPin HIGH .... .... xyPin LOW ...
  • Hi together,
    my lamestation graphics driver is growing to a huge project. But it is in a state where nobody else can help - everything is already lying in front of me but the puzzle doesn't want to fit together. Grrrr. "No effort, no joy." I fully agree with this but sometimes ...
    A friend told me: "The way is going from dilletantic, to complicated to simplicity." I hope I'm advancing to the complicated phase, but still no joy.
    Nevertheless I'm looking forward when it's working. Good night,
    proplem(s) :-))
  • @proplem - those two routines I gave you are the heart of the driver. Use those and interactively bring the LCD to life which will help you understand just what you need, and what you don't need. Don't make the mistake of trying to convert code, just keep it simple and it will be simple.
  • The problem is the datasheet. If I knew what this LCD is waiting for I could go forward step by step and implement it in Forth. Because I'm lacking assembler know how, I can't understand the driver presented by LameStation (https://github.com/lamestation/lamestation-sdk/blob/master/library/LameLCD.spin). I don't want to over stress your help in this thread. Should I open a different thread asking for help with the LCD datasheet?
    despairing, proplem
    edited 2017-02-12 12:30
    proplem wrote: »
    despairing, proplem
    Don't read the assembly language driver and you won't despair. As I keep saying, these two words will allow you to interact with the hardware, the datasheet is useful as a guide but the interaction will confirm what it actually does. For example when you write data and the Y pointer increments you should be able to see it happening. Looking at the basic functions which I have shortened to DAT and CMD you can try these few things.
    I've just checked the lamestation schematics and RC2 seems to have D0..D7 on P2..P9, so I will make adjustments here. Is that the version you have?
    Using these functions after you have defined the pins *rs *E
    0 == *rs
    1 == *E
    10 == *CS1
    11 == *CS2
    --- Output a byte of data to the LCD
    pri DAT ( ch --  )
        *rs HIGH
    pri WRLCD ( data -- )
        --- shift data left two bits to P2..P9
        2* 2*
        --- write data (set after clear)
        $3FC OUTCLR OUTSET
       --- pulse chip enable
        *E HIGH *E LOW
    --- Output a byte to the LCD as an instruction
    pri CMD ( cmd -- )
        *rs LOW WRLCD
    try this interactively - one line at a time as if you are typing them in.
    *CS1 HIGH *CS2 HIGH --- why not
    $3F CMD --- enables display
    $FF DAT --- write some data, should be 8 pixels wide
    $55 DAT --- dots are written, should be next lot of 8 pixels down.
    $FF80 64 ADO I C@ DAT LOOP --- copy 64 bytes of data from ROM - just to see
    edit - just found a link discussing the geometry of the LCD - how the pixels are arranged and addressed. Typical datasheets from this region are absolute rubbish and the design of the controller is the same.
  • @Peter,
    that's what I wasn't able to do myself. Some pixels are switching on and off.
    I don't know what I can say.
    The journey to shake your hands would last about 23:10 hours and would be very expensive. So I just can write: thank you, you extaordinary person from the other side of the planet.
  • @Peter,
    hooray!!! This is fun again. LCDITER to write any byte to the display within minutes, and LCDCLS clears the screen.
    I want to implement some simple drawing methods PLOT, LINE, CIRCLE or make them usable if you already wrote some before. Any tips which way I should go?
    proplem
    edited 2017-02-13 09:55
    proplem wrote: »
    @Peter,
    proplem
    Yay!
    Looking at that information from that site seems to indicate that the not only do you have to deal with pages but you also have to decide which of the two LCD controllers to access via CS1 and CS2 that the pixels appear on. I would therefore dedicate a buffer to do all your drawing in, nice and simple but then have the screen updater picks out the pixels in the correct order to display it.
    You can have a look in extras and besides the various LCD drivers, some that write directly to the LCD etc, you will find VGA.FTH which of course writes to a buffer. So first however I would write the convoluted algorithm that reads the buffer in a linear XY fashion and works out how to write that to the screen.
    Eight pages of 64 bytes where each byte is represented as a vertical column but the next byte writes to the right of that via the "Y" counter (they don't even know X from Y axis). The other 64 pixels on the right hand side are via CS2 in the second controller chip inside the same kludgy chip.
    Funny thing is I have use similar displays but based on ST7920 controller and it is very easy to draw directly to the screen, but as I said I feel that having a 128bitx64bit buffer and updating the display from that might be easier.
