Smart Golf Balls
Hello!
I am a graduate student from the Illinois Institute of Technology (IIT).
I am a Mechanical Engineer and I am a little bit lost with embedded systems...
I am working on the final project of my studies and I am trying to develop a trackable golf ball. I was thinking about using a Bluetooth LE device which would be allocated on the core of the ball. It should be as small and light as possible and I was wondering if it would be possible to be a cubic, spheric, cylindrical or other shape instead of flat like the regular ones, so the surface could be reduced and it would affect less to the dynamics of the ball.
Which would be the approximated minimum surface of a bluetooth LE device?
if it is possible to do it in a cubic shape what could be approximately the size of each surface?
And do you know an approximately minimum weight that could be reached for the device?
Thank you so much for your time and help.
Would RFID work in your application? If so, I'm thinking you could go to Top Golf and get some of their balls, do a bit of research on the internet about how they work, and maybe read them yourself.
Do you know when they applied the score ?
RFID usually have quite limited range, especially when a lot want to chatter at the same time.
I could see a read-at-collect system working on a driving range, where the person collecting has GPS + RFID
or maybe, a reasonable number of buried readers, within the point-score-zones could work.
You could even use the changing shape of the ball at impact to generate energy and design the electronics so they are not as rigid as on a PCB.
jmg, I found this article that helps to explain when the rfid is is read. There are 500 target segments out in the play field. At each target there's a net that collects the balls. The balls pass through a box that reads the rfid and updates a computer which tells the player which target the ball hit. The article states that the manufacturer tests the durability of the ball by firing it out of a canon, into steel plates. Yikes!
Ken, they actually opened up a new Topgolf close to Parallax headquarters, in Roseville, I believe last year! I have some family in the area and noticed it as I was driving on hwy 65. It looks like a fun way to play golf.
Yes, that could be a problem. Thats the reason why I am thinking about the possible minimum size, because if it is too big the electronics would not resist the impact for sure.
That sounds pretty well actually. I will investigate more about it.
Thank you so much
Is your intention to track the ball's movement or locate it should the player lose track of it?
Also be aware that balls commonly end up in water hazards.
I don't know exactly how many balls we collected one year when the water level dropped so low that you could see all the balls just sitting there in the muck.
