Issues with 2 new Propeller 1-2-3 A9 Boards
in Propeller 2
Hi All,
I recently purchased 2 of the Propeller 1-2-3 A9 boards. I seem to be having some issues with both of them. I’m using the 12volt 5A power supplies from amazon that were linked in the Prop 2 thread.(TNTE 12 Volt Power Supply - 5 Amp Standard (12V 5A DC) Adapter)
Board 1 issues:
Red LED’s 0 - 7 are dimly lit when powered up. (Is this normal?)
Configuration LED not on.
Occasionally the RGB-3 turns on bright green.
Cannot connect to Propeller 2 with PNut or PX.exe
Cannot connect to Propeller 1 with Propeller Tool. It seems like the Propeller 1 or the FPGA is sending data through the USB port but it is not the correct response for the Propeller tool causing it to hang. The Propeller tool trys to connect for about 1 minute while the USB TX light flashes. It’s possible the Prop is not resetting for some reason.
Board 2 issues:
Configuration LED turns on about 1 second after power on and turns off after about 20 seconds. (Is this normal?)
Cannot connect to Propeller 2 with PNut.
I am able to download to the Propeller 1 and run PX.exe on board 2. Can someone point me to the latest Prop 1 program that works with the latest PX.exe? I could only find the PX.spin version 1 that is in the A7 folder.
Thanks in advance,
Chuck
Board 1 issues:
Board 2 issues:
Thanks in advance,
Chuck
Power supply only works when warm.
If you either wait 5 minutes or get the power supply section (where all the silver caps are) warm with your hands, maybe it will work...
Your board#2 sounds like it's normal. Just remember to flip the PGM/RUN switch to RUN when using PNut. Use Ctrl-G in PNut to check the Prop2 is active in the FPGA. You should get popup saying:
It looks like board 2 might be Ok.
What comm port does the A9 board show up as?
Px and Pnut only support com1 to com9
But maybe board #1 needs to warm up....
http://forums.parallax.com/discussion/comment/1394340/#Comment_1394340
and here's a test for the P1 on the A9 board.
'P123-A7/A9 Propeller 1 Test 'Switch to PGM from RUN 'Jumper to P8X32A PGM (Right side) ' F10 from Propeller Tool 'Conf. status led should blink con _clkmode = xtal1 + pll16x _xinfreq = 5_000_000 led = 27 pub main dira[led] := 1 repeat waitcnt(cnt+clkfreq >> 3) !outa[led]Set P8x32A jumper to left side (not PGM)
Switch PGM/RUN switch to PGM and from command line type the following (i.e for COM6) When PX finishes wait for FPGA to boot (~20 secs) and Cog0 red led should light.
Switch PGM/RUN back to RUN
Start Pnut.exe
Ctrl-G from Pnut should identify Propeller 2...
it's a 12V 2A supply and running "spinning fozzie demo" with 16 cogs works fine.
Here's the DE2-115 supply (left) and the 12V 5A supply I also use for the A9 board.
Hey! I'm using my DE2-115 power supply, too. That's what I was going to check tonight.
I tried 3 different power supplies on board 2 including the one for the DE2-115. I don't think that is the problem.
Can someone verify or point me to the latest Propeller 1 program used to run with PX.exe.
I tried the new "Prop123_A9_Prop2_v14a.rbf" file on board2. I get the small dialog box with the progress bar. The box disappears when the download is finished. Is there supposed to be a message indicating the download completed successfully? It seems like the .rbf file is downloading but i don't get any cog 0 led turn on and PNut v13 cannot connect and get hardware version.
My boards are using Com1 and Com4.
Rayman, Did you order one of those new boards that Chip recently found? If so, any issues?
#66054 is a A7 board (has 48 pin expansion header above RGB led's)
#60065 is a A9 board (no 48 pin expansion header)
I'm pretty sure that Px.spin version 1 is used in both A7 & A9 boards.
There is no completed message, window just disappears.
Then, the red LED by the beanie hat comes on 20 seconds and then "red0" led comes on for a while and then turns off.
The "Get Hardware Version" function in PNUT doesn't work until you move the jumper from "PGM" to "RUN".
BTW: I do have 2 new P123s but haven't tried them yet...
If I remember right, the top.rbf is the one you want.
The other thing is the source files that made it...
BTW: Don't forget to include the "/p" option with px or it won't work right...
Yes, I can't do anything with board 1 and I can't connect to PNut with board 2.
Maybe you only have the one though...
Anyway, somewhere around V11 the serial interface mechanism changed.
It used to identify in Prop Tool also, but doesn't anymore.
If you flash the top.rbf image, you should be able to identify with the Prop Tool... (but not PNut)
First thing I noticed is that it has that cold power supply issue...
Could tell because the blue power led was dim and flashing at high speed.
But, holding bottom of board with my hand (where all the metal capacitors are) and breathing on the top fixed it. It's 73 degrees in this room.
Then, I was able to flash it with rbf file and px just fine.
But, when I did "get hardware version" it said it couldn't find it!
When, I then did "Change from port" to the actual port being used, then it worked!
Very strange. Now, it recognizes it all the time even if I set the port to something else...
Came on perfectly.
Programmed perfectly.
But, "Get Hardware Version" failed at first.
This time, I just kept on trying, without doing "Change from port".
Failed first 2 attempts and then worked every time after that.
One thing I did different that with my other boards is that I didn't cycle power after programming with the rbf file. Recent comments in this forum made me think I didn't have to. So, all I did was flip the switch from PGM to RUN.
Maybe that's why I didn't see this behavior before?
Your board#1 sounded like it might have this issue...
Did you try the top.rbf with board#2 and then try to recognize with Prop Tool?
Have you installed Prop Tool and connected with a Prop1 chip before with that computer?
I can connect to Prop1 chips in fact, I can connect to the Prop1 chip that is on this board (board#2). PX.exe seems to download to it as well. I just cant connect with PNut. I wonder if it is a FPGA clock issue or a grounding issue. I thought the board had a clock input. Anyone think an external clock would work?
rayman, are you using a laptop or a desktop?
Just to be clear, you aren't doing anything with the "P8X32A PGM" jumper are you?
If you did something with that jumper closed, you may have reprogrammed the P1?
If that were true though, I don't think PX would work...
I used to know where the P1 code is to reprogram the P1, but I think I've forgotten...
I guess I'd recommend trying that top.rbf or an earlier version of P2V.
Here's the V9 version, would be interesting to hear if that works.
If you're not tired of messing with it anyway...
https://drive.google.com/file/d/0B9NbgkdrupkHSThLdkFVZVA3ZWc/view?usp=sharing
In case the PX program got overwritten on the Propeller chip on the Prop123-FPGA boards, here is the source code. You'd move the P8X32A PGM jumper to the right and use F11 in the Propeller Tool to program the EEPROM of the P8X32A. Then, move the jumper back to the left. If nothing is wrong, you should be able to download FPGA images with the PGM/RUN slider switch in the PGM position.
If you'd like, PM me with your phone number or Skype name and I will give you a call when it's convenient for you. Thanks. -Chip
