LED POV Globe with Prop
Hi,
i just want to show you my new propeller project, a POV globe with 64 RGB LEDs.
I use the APA102 that are cascaded and can be switched very fast via SPI.
The LEDs are firing by two cogs with clusos CpuBlade !!!
The 120x64 bitmap with 24bit color is load into the propeller via sd card.
Complete instructable
Regards
Christian
Regards
Christian
No, the arduino only generates the pwm for ESC/Motor
ÄÄhhhmmm. Yes of course. But the Prop rotates 40 times/second and i've enough problems to get power to the ring ;-)
Edit: Ahh! I see. The Prop is on the rotating part!
Edit edit: well, there's a way around that! Put the motor and ESC in the rotating part too!
Ok, that's the next challange, who's first ?
@ all : Thanks !
One note, the link for the "microSD Breakout" appears to be broken.
Thanks for sharing.
the rotation is only a feature, i thought the video looks better !!!
the link for the "microSD Breakout" is repaired !!!!
Many thanks to Jon and also Seairth
Could you have used a BASIC Stamp instead of an Arduino?
