Automated Menorah — Parallax Forums
Automated Menorah
JonnyMacJonnyMac Posts: 9,777
edited 2016-12-18 22:18 in Propeller 1
An EFX-TEK customer asked for code to run a fully-automated Menorah. Attached is the first crack for those who might be interested.
Note that the code is written for the EFX-TEK HC-8+ but will run on any Propeller board that has eight contiguous outputs for "wicks" and two pins for the I2C RTC (DS3231)
  • Did you feed the output of the LFSR to each of the wicks, to simulate a candle flame?
    That is how the commercial LED tea lights work.
  • JonnyMacJonnyMac Posts: 9,777
    edited 2016-12-19 15:04
    No; I have a PWM cog that drives the outputs, and a flame simulation cog that randomly ramps the "wick" levels up and own -- here's that code:
    pri flame_generator | ch                                        ' call only with cognew()
      repeat ch from 0 to 7
        target[ch] := (prng.random >> 1) // 33 + 223                ' pre-seed high value
      repeat
          if (flame[ch] < target[ch])
            if (++flame[ch] == target[ch])
              target[ch] := (prng.random >> 1) // 33 + 159          ' low (159..191)
          else
            if (--flame[ch] == target[ch])
              target[ch] := (prng.random >> 1) // 33 + 223          ' high (223..255)
        time.pause_us(3500)
    JonnyMac,
    ...eight contiguous outputs for "wicks"...
    I thought Menorah had 7 lamps.
    Heater. wrote: »
    JonnyMac,
    https://en.wikipedia.org/wiki/Menorah_(Hanukkah)
  • Heater. wrote: »
    JonnyMac,
    I've always wondered why "the menorah" had two names: menorah and hanukiah. Apparently The Menorah is the 7-candle holder used only in the temple (Talmudic law says though shalt not use outside the temple). Then the hanukiah is the special 9-candle holder used during Hannukah to celebrate the special event.
    Source
    Confusing.
    Just put up a tree and stick some lights on it.
    edited 2016-12-20 01:28
    I'm a guy who claims no religion, but is respectful of those who do. Every [home] Hanukkah event I've been to uses a Menorah (that's what they called it) with nine candles: the shamash (guide) and a candle for each day of Hanukkah (there are 8 days). The state of of CA even asked me for BASIC Stamp 1 code (for an EFX-TEK Prop-1 Controller) for a Menorah display on the capitol grounds (I don't know if they still use that).
    The code I shared was at the request of a customer; it was not intended to cause offense or controversy.
  • JonnyMac wrote: »
    Now that statement has me confused, as to why anyone would be even slightly offended or find a cause for controversy.
    I always like your posts Jon as they are exemplify the practical side of the Propeller chip and how easy and quick it is to implement a prototype at a moments notice or even to "fix" other poorly designed products. When you team up experience, good practical sense, some get-stuck-into-it'ness, and a Propeller chip, then wonderful things happen, and happen sooner than later.
  • Heater. wrote: »
    Confusing.
    It certainly isn't about religious beliefs, seven, eight or nine. That is for the ultimate user to decide. Isn't it about the flicker of a candle? Let the ultimate user have some work to do.
  • Jon, thanks for putting up the automated Menorah code. I remember the BS1 version and look forward to trying this out. I think I've seen some electric Menorahs in Bed Bath & Beyond that could use this to control them.
    Jeff
  • Isn't it about the flicker of a candle?
    Actually, the original request was how to automate with an RTC. That person suggested he was going to purchase the DS3231 so I picked up a couple inexpensive boards from Amazon and knocked out the program.
  • Very cool! This would be cool to expand to make a Parallax Yule Log fire place insert.
    Thanks for sharing.
    I do hope no one was offended by my "...put up a tree and stick some lights on it" comment. That was not intended as a slight on any ones traditions.
  • I'm not Jewish, but I found that comment insensitive, and at the very least, utterly unhelpful.
    Certainly it was unhelpful. My apologies for that.
    On the plus side, I learned something new of these ancient traditions along the way.
    edited 2016-12-20 18:06
    For those interested in the DS3231 used in the project, I've uploaded a tidied version of my object (with demo code) to ObEx. This also includes access to the temperature registers in the DS3231.
    -- http://obex.parallax.com/object/857
    I used this module in my test:
    -- https://www.amazon.com/gp/product/B014IYBGG0
    This include an AT24C32 EE on the board, too. Its address is preset to %111, so it doesn't conflict with the Propeller EEPROM if this board is connected to the Propeller EE buss.
  • I'm no expert but the ones I see have nine candles. Could be the difference of commercial versions and more Orthodox versions.
  • Or how about just a 8-9 candelabra to be used with seasonal events.
  • DigitalBob wrote: »
    DigitalBob wrote: »
    See this post above.
