Help with USB to RS232 converter
in Propeller 1
I'm using the Parallax USB to RS232 converter (P/N 28030) on my Prop 1 board.
It works great, but the DB-9 connector is too big for the board I'm building.
Does anyone have the schematic for this converter? So I can just mount the components on my board.
I was unable to find the schematic in the product info.
Thank you for your help.
Jim
Jim
The Propeller chip normally uses the Prop Plug, not the USB to 232 for programming. May I ask why you need RS-232 levels in your interface?
I use the USB to 232 to comm with a RobotBASIC program on the PC. I combine this with a MAX3232 chip.
Jim
