Earthquake
Publison
As everybody has heard by now, the has been a significant earthquake in New Zealand.
I have been trying to email our friend, Hanno Sander, (creator of VeiwPort and 12 Blocks). My email to hannoware.com kicked back. Just tried onerobgot.org and it seemed to go throgh.
Hope everything is good down there. This is the third earthquake he has gone through.
That's right. He is NZ.
I'm only just finding out myself how bad it really was. On the night, I turned on the radio to find out any details and one thing that was notable even then was that there was no one calling the station from the affected area. It feels more scary now in hindsight.
7.5 is certainly getting up there! But it's also on one of the main fault lines so was always part of the predictions. I believe a mag 8+ along the alps is still due.
No damage.
Jm
http://sanfrancisco.cbslocal.com/2016/11/14/new-zealand-plans-rescue-of-tourists-stranded-by-earthquake/
There is some head scratching going on over the amount of high-rise damage in Wellington given there wasn't a single aftershock in the area. And it was meant to be NZ's most quake resistant City.
... an interesting side note, we have a fair amount of Earthquakes here in Oklahoma on a daily basis. A few things I have noticed that seem to be uncommon with a typical California earthquake is that you can sometime hear the earthquake before the ground shakes ... this sort of defies what I thought to be true in that the sound came after the ground moved... <-- Anyway it is what it is. Another observation which might apply to the high-rise is that many Earthquakes go undetected unless you are on the second floor or more of a house or building. I believe this might be caused when most of the ground motion is along the Z-axis and not so much along the X and Y axis. Just a theory. Fracking related quakes may cause more Z-motion in our particular case.
It's called the 'P' wave. The closer the epicentre the more you'll hear and feel the P wave. And the sharper the overall shake will be. It gives the first fright and often separates those that run from those that hide.
That's also proximity based. The further away the epicentre the more it's just a rolling sensation. The edgy violence is totally lost. This recent 7.8 quake was quite the ride in Chch, in that it felt just like an ocean liner on a gentle long wave rolling sensation. It grew and I could feel the acceleration then deceleration in each direction. The ground under Chch must have been moving quite a number of metres back and forth. That's why I decided to check the radio.
Here is the video of three cows caught on a small steep mesa from the landslide near Kaikoura NZ.
