Looking for 64K EEPROM at Mouser
in Propeller 1
I'm looking for a 64KByte EEPROM to use with the Propeller.
I tend not to be very adventurous when it comes to EEPROMs and just use the same chips I see fellow forum members list in their BOM.
I was just trying to find a surface mount 64KB (512kbit) chip on Mouser and found my old standbys weren't listed.
If I remember correctly the important things when considering which EEPROM to purchase is to make sure the EEPROM is an I2C device with the "normal" EEPROM I2C address.
IIRC, the EEPROM's page size is also important. Am I remembering correctly the page size should be at lest 64 bytes?
Here's one EEPROM chip I think looks like it should work with the Prop. Am I correct?
The datasheet lists the page size as 128 bytes.
Do any of you have favorite EEPROMs at Mouser? I'm mainly interested in a 64KByte chip but if the price of a 32KByte where low enough, it might be worth considering a 32KByte chip.
I'm looking for a surface mount chip but the exact footprint isn't important.
https://www.parallax.com/product/602-10001
All the current SPIN programs should fit.
Thanks Publison. That's the one of the chips I tried to find on Mouser (it would have been my first choice). I couldn't find any Atmel EEPROMs in stock at Mouser right now.
Hope that helps.
-Mike R....
The addressing scheme for i2c eeproms is consistent up to and including 64kbytes. It is 128kbyte (1 megabit) devices where you have to watch out for variations in the way they merge the high order bit into the device ID.
I have 100 from Digikey myself but the guy I'm working with prefers Mouser. I have a feeling many of us prefer the distributor we first used. I tend to look at DigiKey first myself but I know lots of people prefer Mouser.
Thanks, I know I've looked at your BOM many times to see which sort of parts to use.
Very good! That's a much better price than the one I found.
I've run in the 128KByte issue myself several times.
Thanks for the help everyone.
