Forum Glitch: Files Won't Attach
Mods: I couldn't attach a file to a post in Robotics just now. What's up?
Retried here again, same dealio. Upload goes to 100% then stalls, "waiting for Parallax.com"
Testing, but like from inside Parallax so maybe that's also an issue.
I assume you tried just before posting this message?
What size is this file, type of file, etc?
erco: Can you help us with a few details on this issue? The things that could cause problems with an upload are file size and the file extension. Also, if you can provide a date and time (including your time zone) when this happened, we can review logs to see what the servers are seeing when the upload attempt was made.
Status bar goes up to 100%, then "waiting for parallax.com" and the blue upload bar animates for a while. I let it go for 30-40 seconds, nothing.
I'll try again and let it go longer.
Edit: Tried uploading here, blue bar still animating 4 minutes later. Problem remains.
Both files had an ampersand (B&N) in the name, which apparently your system doesn't accept. I renamed them sans the '&' and they uploaded here fine.
Phew!
