BlocklyProp S3 - reset to demos
John Kauffman
When a student is done the tutorials then the S3 is passed to the next student to begin. I want new student to start with factory-default program of the 8 demos. I assume the first student program that went into EEPROM over-wrote the factory program.
This link describes a future feature to do just that:
learn.parallax.com/support/reference/scribbler-3-robot-block-reference/actions/factory-reset
But I don't see that block implemented in my IDE.
Is there a link to the demo program so I can open and install on EEPROM manually?
Thanks.
Thanks.
https://www.parallax.com/downloads/scribbler-s3-open-source-files
Also, BlocklyProp will be receiving an update shortly that adds a block to restore demo programs.
https://www.parallax.com/downloads/scribbler-s3-gui-software
Just as an update: BlocklyProp received its update and should now include the factory reset block under the ACTIONS > RESET block category.
OK, I did not see a mention of Mac.
Might be worth a note in help for that block that it has to be run as download to EEPROM. Might save some confusion for new teachers.
There is also a block under development that will do this - It is being tested on the DEMO BlocklyProp site (not the live BlocklyProp site) right now! It is used by itself and when run will reset the default demonstration program on the S3.
Right now, it looks like this...
New block showed up on my IDE about Thur and I used it on Friday for three machines in class - works great.
I'll make note of the Load to EEPROM requirement in the block help.
Thank you.
