ZiCog a Zilog Z80 emulator in 1 Cog - Page 41 — Parallax Forums
1353637383941»
    Yes indeed, SPI RAM might be a nice simple way to provide memory for ZiCog to run CP/M. If ultimately a bit slower than the parallel RAM solutions we have.
    ZiCog is written in Spin/PASM. It can use a cached memory driver like Bill Henning's VMCOG. There was no C for the Propeller at the time. That came later with ZOG/ZPU then Catalina then prop-gcc. I see no point in rewriting ZiCog in C.
    Upshot is that I'm not about to adopt SPI RAM for ZiCog unless someone has a cached driver in Spin/PASM that can be more or less dropped in.
    edited 2016-10-28 22:14
    Heater. wrote: »
    Well, I'm pretty sure the sources for Bill's VMCOG still exist. Also, all of the "cache drivers" in propgcc are written in PASM.
    (I was going to add a cache driver as an attachment but I don't see how to add an attachment in the editor)
  • Here is the current SPI SRAM external memory driver from PropGCC.
    OK, cool, thanks.
  • I still haven't removed the yearnings to put on a old DRAM - directly onto the Prop (256K x16 (but only 8 bits used ... to start with)).
    Why not just use Cluso's RamBlade module. It has onboard SRAM. Should work well.
  • Yeah ...but ...
    That would remove all of the perversity in wanting to do something backwards stepping ;-) Working on the premise that everything should be removed until something really horrible happens - electronic Buckeroo (in reverse).
    I wonder about using the internal /RAS, /Cas latches and so allow for at least two chips to be removed from the usual Dracblade design.
    Toby,
    ...electronic Buckeroo (in reverse)...
    Believe it or not there is a technical term for that: "Muntzing".
    After Earl "Madman" Muntz.
    https://en.wikipedia.org/wiki/Muntzing
  • I wonder about using the internal /RAS, /Cas latches and so allow for at least two chips to be removed from the usual Dracblade design.
    https://spritesmods.com/?art=avrcpm ... interfaces a single DRAM directly to an ATmega8. Perhaps this can hint to a similar Propeller solution?
  • I saw that one, and a few similar ones. We are still nursing along some kit that was EOL years ago so that is a source of ancient bits (even if they are really a bit too modern for a Z80). I am experiencing that adage that "time goes faster as you get older", now I do not have half the time to do the stuff I used to.
    I chuckled at a sit-com that used the phrase "Cockpit Buckeroo" - you switch off stuff, hoping nothing unpleasant occurs ...
  • jmgjmg Posts: 15,200
    You can go backwards-stepping anf forwards at the same time, if you connect HyperRAM :)
    That comes in 8b wide, and needs far fewer pins, but still has some timing rules that need to be hard coded.
