Propeller ASC+
makarcz
Hi,
What do you guys think of the Propeller ASC+ board?
It is a bit intriguing to me.
Parallax still carries it, but the price seems steep.
I think the more cost effective solution is to buy QuickStart board and make your own adapter to interface Arduino shields.
Any particular reason why one would like to front $50 to have such a board on the bench?
Is there a good Propeller library equivalent that covers popular Arduino shields?
I am curious what is your opinion on this topic.
Marek
Marek
The main point is the work Martin did to provide a C library with very useful C functions to use Arduino C examples on a propeller. Something like proparduino.lib or so.
And you can use that code with a ASC+ board or your own creation.
As for the $50 and the value of it, I think it depends on what you want to do with it. I personally like the Propeller because of the unusual concept behind it. It is different from 'normal' micro controllers, no interrupts but 8 cores running in parallel. I had hours of fun with it just using a breadboard and a PE kit.
Unfortunately I got hooked on it and have spend way more then just $50 over the last years. But for the fun I had and the chance to do some unconventional thinking and programming I do not regret any cent spend.
Enjoy!
ASC+ seems to make sense if: 1) you like the shield concept; 2) you like the Propeller concept; and 3) you want a known-good solution that is supported.
For the comparison that you presented:
ASC+ = $50 ready to go, right out of the box. Includes MCP3208 ADC.
Quickstart = $35 + adapter that you design and build. Includes basic HMI (touch pads and LEDs).
It looks like there are shields available that have screw terminal breakouts ... for about $15. So, nothing gained there in terms of value.
