Macro Assembler for P1, P2
                                  in Propeller 2
                    From another thread .. musings on Macro Assemblers, for P1 and P2 ...
I'm just now digging into fasmg , which continues to impress, the more I find out..
fasmg is the generic any-mcu macro version of fasm.
fasmg is part script engine, part assembler, and it is truly powerful.
It is coded in fasm, and comes in at a stunning 48k exe
Seems to have multi pass, and a means for automatic dead code removal.
HEX and LST are created via more scripts....
Download fasmg with examples, is a compact 236k
https://flatassembler.net/docs.php?article=fasmg_manual
https://flatassembler.net/fasmg.zip
Parallax P8X32A thread I started, to get some tips on how to best drive fasmg.
https://board.flatassembler.net/topic.php?p=190617#190617
                            Peter Jakacki wrote: »Re assembler - I would love to see a macro-assembler for the Prop!
Some web-help, and now Updated to include both IF_ Prefix and W Suffix handling.
; ~~~~~~~~~~~~~~ Now Expanded to support Suffix too.. ~~~~~~~~~~~~~~~~~ ;web suggestion define NR SUFF -001b define WC SUFF 010b define WZ SUFF 100b define SUFF gParC = 1111b ; default, globalV init macro F_ZCDS? ParD*,S_Suffix*& ; & for ParS and any suffix controls gZCR = 001b ; default match S =SUFF suffix, S_Suffix ;splits S, ParS = S local flags iterate flag,suffix ; comma delimited list if flag >= 0 gZCR = gZCR or flag else ;NR gZCR = gZCR and not -flag end if end iterate else ParS = S_Suffix end match gZCDS = (gZCR shl 23) + gParC shl 18 + (ParD and 0x1ff) shl 9 + ParS and 0x1ff gParC = 1111b ; restore global default, after use end macro ; ZCRi ;XOR 011011 001i cccc ddddddddd sssssssss ; 109876 5432 1098 765432109 876543210 macro qXOR? ParD*,ParS*& ; ParC now global, ZCR via any suffix F_ZCDS ParD,ParS match #data, ParS dd (011011_000_1b shl 22) + gZCDS else dd (011011_000_0b shl 22) + gZCDS end match end macro ; ~~~~~~~~~ Build 32 IF_ variants ~~~~~~~~~~~~ iterate <Cond,wxyz>,\ ALWAYS,1111b,NEVER,0000b,E,1010b,NE,0101b,A,0001b,B,1100b,AE,0011b,BE,1110b,C,1100b,NC,0011b,\ Z,1010b,NZ,0101b,C_EQ_Z,1001b,C_NE_Z,0110b,C_AND_Z,1000b,C_AND_NZ,0100b,NC_AND_Z,0010b,NC_AND_NZ,0001b,\ C_OR_Z,1110b,C_OR_NZ,1101b,NC_OR_Z,1011b,NC_OR_NZ,0111b,Z_EQ_C,1001b,Z_NE_C,0110b,Z_AND_C,1000b,\ Z_AND_NC,0010b,NZ_AND_C,0100b,NZ_AND_NC,0001b,Z_OR_C,1110b,Z_OR_NC,1011b,NZ_OR_C,1101b,NZ_OR_NC,0111b macro qIF_#Cond? instruction& gParC = wxyz ; apply CC value, now global instruction end macro end iterate ; ~~~~~~~~~ Test coverage ~~~~~~~~~~~~ qIF_Z qXOR 0AH,#05H WC ;C field set 011 qIF_Z qXOR 0AH,#05H WZ ;Z field set 101 qIF_Z qXOR 0AH,#05H WZ,WC ;ZC field set 111 qIF_Z qXOR 0AH,#05H WC,WZ ;ZC field set 111 qIF_Z qXOR 0AH,#05H NR ;R field clr 000 qXOR 0AH,#05H qXOR 0AH,#05H WC ; Fixed with push iterate flag,suffix into G_CDS? qIF_ALWAYS qXOR 0AH,#05H qIF_ALWAYS qXOR 0AH,#05H WZ qIF_ALWAYS qXOR 0AH,#05H WZ,WC qIF_ALWAYS qXOR 0AH,#05H WZ,WC,NR ; field checks dd (001b shl 23) ; default dd (101b shl 23) ; wz dd (111b shl 23) ; wz wc dd (000b shl 23) ; nrSo far it looks promising, the idea is to find a good Macro Assembler, so you can focus on other, more critical things instead...
I would like to see a short program using just a couple of P1 instructions, and the results of the compilation to get a better feel for it.
If the preliminaries look good, then there are probably enough of us to write macros for each instruction once we have a complete macro for one instruction (ie including labels, condcodes, etc).
The code above covers Immediate, and the condition code IF_ prefix, and ADD and SUB and will produce a binary file.
Not sure about any endian issues yet ?
I'm looking at suffix handling for WC,WZ,NR, and have a limited version of that working.
Need some tips from a fasmg expert to merge the prefix & suffix code ...
Speed checks :
; Listing ON -> 2 passes, 2.4 seconds, 16547 bytes, 266k LST
; Listing OFF -> 2 passes, 0.4 seconds, 16547 bytes, 80 byte LST
fasmg can export .hex via hex.inc macros, but that's slow, and seems to interact with other macros.
addit: New versions of Listing.inc and hex.inc followed this slow/interact report, and they are now (much) faster & interaction is fixed.
see: https://board.flatassembler.net/topic.php?p=191119#191119
Alternative HEX and DB outputs :
Some web searching finds srec_cat
Download https://sourceforge.net/projects/srecord/files/srecord-win32/
then run as and srec_cat can also do this, which is an ASM syntax DB list variant.
srec_cat P8X32_PropMacros.bin -binary -o P8X32_PropMacros.DB -ASM (strangely, -ASM options seems to fail, but default decimal is tolerable.) creates ; http://srecord.sourceforge.net/ DB 251,247,35,246,253,251,35,246,37,38,128,255,40,128,102,253 ... DB 111,3,14,60,111,3,14,60,111,3,14,60,111 ; upper bound = 0x4088 ; lower bound = 0x0000 ; length = 0x4088which can be INCLUDED into OnePin MCU ASM source, and it will auto-append the P2 code, to the small loader stub.
but I think we already have 'GAS does not match PASM' problems ?
This is more an opportunity to bring PASM more into line with other assemblers ?
