Simple math help (spin)
TC
in Propeller 1
Hello all,
I could be getting burned out, but I cant for the life of me how to figure this out.
The project I am working on that can have up to 125, 8 channel touch chips(1000 inputs total). The chips have one register each with the touch flags, 1-bit for each input. I am trying to figure a way to know what input was touched. for example---- say I touch sensor number 20, the prop would scan through the first 2 chips, and not see a touch. But when it got to the third chip it would see input number 4 was flagged. The prop would then know that sensor number 20 was touched.
currently, the touch chips are on a parallel buss. I am using a 74HC138, 3 to 8 decoder. I am only doing 8 chips right now, as proof of concept. Then it will start getting bigger.
Is there an easy way to figure what sensor input was touched from knowing what the <byte> sized address is, and what the <byte> sized register value is?
TC
TC
I'd think you could use something like this;
This only checks for a single button press but it wouldn't be hard to detect multiple buttons.
Here's an example.
CON MAX_ADDRESS = 124 MIN_ADDRESS = 0 VAR long buttonId PUB Main | registerValue, address address := MIN_ADDRESS repeat if address > MAX_ADDRESS address := MIN_ADDRESS registerValue := GetSingleChipRegister(address++) registerValue &= $FF ' make sure only lowest 8-bits are set repeat while registerValue registerValue := FindNextButton(address, registerValue) ' do something with buttonId address++ PUB FindNextButton(address, registerValue) buttonId := (>|registerValue) - 1 result := |< buttonId buttonId += 8 * address result := registerValue & !result PUB GetSingleChipRegister(address) ' Read register from chip and assign this value to the "result" variable.I made "buttonId" a global value since the method "FindNextButton" was returning the value of "registerValue" but with the highest set bit cleared.
repeat device from 0 to 124 scan := scan_device(device) ' select and read device if (scan > %00000000) ' anything active? scan ><= 32 ' flip for >| sensor := (device << 3) + (32 - >|scan) ' calculate sensor # quitThe scan_device() method takes care of the chip selects and then reading the device.
I have to get this done by tomorrow(friend wants to show the "tech" working this weekend) and I am behind because of issues like this. Stupid issues, that I don't want to ask for help, until I try to figure it out my self. I don't feel it is right to ask people "how do you do A + B = C" when I can spend some time with the prop manual, the forum search bar, and google to figure out the answer. I need to decide, when is it a good time to quit wasting time trying to figure it out, and ask for help.
I do apologize if I start asking questions with out doing the research. I would not be doing it if I had more time
That is one option I was somewhat thinking of. But I just could not rap my head around the order I needed. But now I do. Thanks
Right now I am only worried about single touch, but later on I am thinking of doing multi-touch for a hidden random Easter egg. I thought it would be a fun idea to get the people playing with the project.
I will save your idea for when I do the multi-touch. Thanks
I dont know how you do it Jon. You can post code that "to me" looks like it would not work. Then I try it, and works exactly the way it should. Then I have to open the manual, and dissect whats going on.
I just cant take someone else code, and not try to figure out what is going on. That my main downside when I'm in a hurry, I can try and figure out what is going on in the code.
Thanks for everything
TC
pub scan_device(d) if (d == 2) return %0000_0001I changed the target for d and the bits returned a couple times until I was satisfied the above code was okay to post.The more you do that, the easier dissecting becomes. We all get stuck sometimes. For a long time I simply shrugged my shoulders at the "fast" SPI routines (PASM code, using both counters) that were obvious to others. Last week I looked again and that code finally made sense. The good news is that "Aha!" moments like this tend to lead to more of them, and the duration between gets shorter.
I'm glad I could help -- which, by the way, helps me get better. On more than one occasion I have suggested to my N&V readers that helping others here in the forums is a great way to improve. Those of us helping you don't have the stress of the project weighing on us, hence may see things a little more clearly. Stress sucks!
