The new Parallax USB to Serial (RS-232) Adapter
                                  in Accessories
        Need to know if the new Parallax USB to Serial (RS-232) Adapter
is different to the old one.
It seems the size is different but what about electronic/firmware/drivers
differences ?
Old one means= a version that Parallax sold for many years (green color) :
https://solarbotics.com/product/21197/
Help please,
Here's the FTDI webpage with drivers for most computer operating systems:
www.ftdichip.com/Drivers/D2XX.htm
Included in the page (table about half-page down) is this setup file for Windows: www.ftdichip.com/Drivers/CDM/CDM21218_Setup.zip
You wrotte that I have to add old drivers to recognize the new
Parallax USB to Serial Adapter ?
( Im ausing win 8 )
Hello Angela-Curti,
I think you mis-understood what Chris wrote.
I'd like to suggest you try the adapter, as there is a big chance it will work automatically.
And if not, then use the download link to download and install the driver.
The one I posted is compatible with Windows 8.
Here again for Windows: www.ftdichip.com/Drivers/CDM/CDM21218_Setup.zip
Download, unzip, then run the setup.exe
When finished, plug in the Parallax USB to Serial Adapter again- and it should automatically work.
Hope this helps.
http://www.ftdichip.com/Drivers/VCP.htm
The install file for Windows mentioned above actually includes both driver types. So installing that will still be a good solution.
I am confused.
Is the new one full compatible with the old one ?
I usually use it to work with some PLCs and I am afraid that the new one will not work as well as the old one.
Do you mean the drivers are already installed, or do you mean recent version of windows have the capability or either getting the driver straight from the chip or automatically downloading without user intervention.
I ask because I recently read somewhere the opposite situation- that windows XP already had them, and that it was more recent versions of windows where you had to deal with installing drivers.
When you are downloading any of Parallax's tools, you have the option to install the new FTDI drivers.
