File-loading use "fl" using hubram.
In case of Development kernel, free area is 15kbyte.
Big file cannot load in free area.
So, I made RAMDISK(512kbyte).
Loading sample.f(size:33kbyte) by "fl"
sample.f combined from i2c_utility_0.4.2.f and SSD1306(128x32)_0.1 and demo_0.1.f.
9224 characters overflowed
Prop0 Cog6 ok
CON:Prop0 Cog5 RESET - last status: 0 ok
I always thought a variable speed clock with a week-long rotation period (weekends being 50% of the dial) would be a cool novelty item. Good to see caskaz !
Trying to work HD66732.
This LCD controler has JIS Level-1 and Level-2 Kanji ROM.
This also has character RAM(4line 20digit) and graphic RAM(120x52dots).
Not operating perfectly yet.
This module(LM4049:using HD66732) are sold only this shop in Nipponbashi.
Including adaptor-board for film connector.
Price is 980 Yen(including tax).
It seems there are about 100 pcs in stock.
No parts in Akihabara.
Thanks, caskaz!
I found the place on google maps. I may be able to go to Osaka again in a few months. It's much easier for me to go there than to Tokyo anyway (I have never actually been in Akihabara).
Hi.
I try to use USB-memory by using CH376S.
Using serial I/O.
I have trouble.
After opening/appending/writing file, error occur trying to open file again.
Searching files inside directory, opening file have no error.
When closing file, it seems file-pointer is file-end.
Do you have how to solve trouble?
Prop0 Cog6 ok
init_USBmemory
CMD_SET_USB_MODE operation successfull.USB device is present.
Checking USB Disk connection status:>Connection to USB -- ok
Mounting USB diskST: 0_000_000_031
ST: 0_000_000_020
>USB Mounted -- ok
20_69000_036:
20_690: 000128000001031115109105066085070070065076079032 .....smiBUFFALO
20_706: 085083066032070108097115104032068105115107032032 USB Flash Disk
20_722: 0520480480480580321001051151070811171011141210134000: diskQuery.
BUFFALO USB Flash Disk 4000
Totale Capacity:505855 kb
Logical Total Capacity:505248 kb
Free Capacity:505248 kb
FAT file system type:FAT
Prop0 Cog6 ok
dir /*
>Readable inside directory
TEST1.TXT TEST2.TXT TEST3.TXT TEST4. TEST8.TXT
Prop0 Cog6 ok
setFileName TEST1.TXT
Prop0 Cog6 ok
openFile .
>File opened successfully
20 Prop0 Cog6 ok <--- USB_INT_SUCCESS
readFile
Reading file:PropForth5.5
Prop0 Cog6 ok
0 closeFile
Closing file:>File closed successfully.
Prop0 Cog6 ok
Prop0 Cog6 ok
openFile .
>Failed to open file. Error code:6666 Prop0 Cog6 ok <-- ERR_MISS_FILE
dir /*
Prop0 Cog6 ok
Prop0 Cog6 ok
openFile .
readFile
Prop0 Cog6 ok
0 closeFile
Closing file>File closed successfully.
Prop0 Cog6 ok
CH376S code
Not complete yet.
Change directory to down is ok.
But cd to up is NG.
Createfile,Deletefile are ok.
CreateDirectory is NG.
Prop0 Cog6 ok
init_USBmemory
ST: 0_000_000_020
>USB Mounted -- ok
21_05200_036:
21_052: 000128000001031115109105066085070070065076079032 .....smiBUFFALO
21_068: 085083066032070108097115104032068105115107032032 USB Flash Disk
21_084: 0520480480480320320320320320320320320320320320324000
FAT file system type:FAT16
Prop0 Cog6 ok
dir /*
TEST1.TXT TEST3.TXT TEST4. TEST9.TXT
Prop0 Cog6 ok
readDemo /TEST1.TXT
Prop0 Cog6 ok
appendDemo /TEST1.TXT
Setting file pointer:Pointer successfully applied
Writing to fileSetting data length
Writing data to file:7
Updating file size:20
Prop0 Cog6 ok
readDemo /TEST1.TXT
Reading file:PropForth5.5-append
Prop0 Cog6 ok
createFile /TEST2.TXT
Created file
Prop0 Cog6 ok
dir /*
TEST1.TXT TEST3.TXT TEST4. TEST9.TXT TEST2.TXT
Prop0 Cog6 ok
deleteFile /TEST2.TXT
Successfully to delete file
Prop0 Cog6 ok
dir /*
Prop0 Cog6 ok
cd /TEST4
>Directory opened successfully.
.. ... TEST5.TXT TEST6.
Prop0 Cog6 ok
cd TEST6
.. ... TEST7.TXT
Prop0 Cog6 ok
Only moving.
Moving code is below;
fl { BRACCIO PropForth5.5 2016/05/08 21:10:08 QuickStart BRACCIO shield board --------- 3V3---|VCCA VCCB|----5V P8----|A0 B0|----M1 P9----|A1 B1|----M2 P10---|A2 B2|----M3 P11---|A3 B3|----M4 P12---|A4 B4|----M5 P13---|A5 B5|----M6 GND---|GND OE|----GND --------- FXMA108 } \ ------------------------------------------------------- \ Constants \ ------------------------------------------------------- \ Special register h1F8 wconstant ctra h1FA wconstant frqa h1FC wconstant phsa \ Time for servo d80 wconstant 1usec \ Max-limit and Min-limit for each servo wvariable servo_limit -2 allot d500 w, d2500 w, \ base d900 w, d2300 w, \ shoulder d600 w, d2500 w, \ elbow d500 w, d2500 w, \ vertical wrist d500 w, d2500 w, \ rotary wrist d1350 w, d2200 w, \ gripper \ top pin number of contiguous servo group 8 wconstant servo \ each servo ch 0 wconstant base 1 wconstant shoulder 2 wconstant elbow 3 wconstant vert_wrist 4 wconstant rot_wrist 5 wconstant gripper \ channel[max:8] 6 wconstant ch \ ------------------------------------------------------- \ Variables \ ------------------------------------------------------- \ target[ch],delta[ch],usec[ch]: each channel has 2byte(total 12byte) variable target 8 allot variable delta 8 allot variable usec 8 allot \ ------------------------------------------------------- \ Main \ ------------------------------------------------------- \ Get address of target for each ch \ ( n1 -- n2 ) n1:servo ch n2:target_position's variable address for each ch : tgtPos 2 u* target + ; \ Get address of delta for each ch \ ( n1 -- n2 ) n1:servo ch n2:delta's variable address for each ch : deltaVal 2 u* delta + ; \ Get address of usec for each ch \ ( n1 -- n2 ) n1:servo ch n2:current_position's variable address for each ch : curPos 2 u* usec + ; \ Set servo-motor's pin to output \ ( n1 -- ) n1:top pin number of contiguous servo group : setup ch 0 do dup pinout 1+ loop drop ; \ Check if position is inside region \ ( n1 n2 -- n3 ) \ n1:servo ch \ n2:servo position(microsecond) \ n3:Checked servo position(microsecond) : posCheck over 4 * servo_limit + W@ max \ Check Min-limit over \ ( n1 [n2 or min-limit] n1 ) 4 * 2+ servo_limit + W@ min \ Check Max-limit ; \ Set selected servo(ch) to new position \ ( n1 n2 -- ) \ n1:servo ch \ n2:newpos specified in microseconds : setpos posCheck \ ( n1 n2 ) over \ ( n1 n2 n1 ) \ delta[ch] = 0 deltaVal 0 swap W! \ ( n1 n2 ) Save delta=0 to specified ch swap 2dup \ ( n2 n1 n2 n1 ) tgtPos W! \ ( n2 n1 ) Save target_position to sprcified ch \ usec[ch] = newpos curPos W! \ ( -- ) Save new_position to specified ch ; \ Move selected servo from current position to newpos in n1 frames \ ( n1 n2 n3 -- ) \ n1:frame [1frame is 15msec(servo frame timing)] \ n2:servo ch \ n3:newpos : movpos posCheck \ ( n1 n2 n3 ) rot \ ( n2 n3 n1 ) dup 1 = if \ Moving rapidly drop \ ( n2 n3 ) setpos else \ Moving slowly through frames over \ ( n2 n3 n1 n3 ) >r \ ( n2 n3 n1 ) Push newpos >r \ ( n2 n3 ) Push frame over \ ( n2 n3 n2 ) curPos W@ - \ Calculate (difference from newpos and usec) abs d10 u* \ ( n2 n3 calc_value ) r> \ Pop frame u/ \ ( n2 n3 calc_value ) Calculate 0.1usec/frame 5 + d10 u/ 1 max \ ( n2 compared_result ) round up to 1usec/frame over \ ( n2 compared_resulte n2 ) deltaVal W! \ ( n2 ) Update delta to specified ch r> \ ( n2 n3 ) Pop newpos swap \ ( n3 n2 ) tgtPos W! \ ( -- ) Update new_position to specified ch then ; \ Returns position (current output command to servo) of channel \ ( n1 -- n2 ) \ n1:servo ch n2:ch's position(microseconds) : position curPos W@ ; \ Returns True when servo ch is at desired target \ ( n1 -- n2 ) \ n1:servo ch n2:t/f : at_target dup curPos W@ swap tgtPos W@ = ; \ Wait until servo channel reaches at target position \ ( n1 -- ) n1:ch : wait_tgt begin dup at_target until drop ; \ Runs 6 servos \ ( n1 -- ) n1:top pin number of contiguous servo group : deltaServo dup setup 1 frqa COG! 0 phsa COG! cnt COG@ d200000 + \ cnt + 2.5msec swap \ run 6 slot(15msec) begin ch 0 do \ Set PWM/NCO mode on servo pin dup i + h10000000 or ctra COG! \ Set negative value to phsa i curPos W@ 1usec u* negate phsa COG! i curPos W@ i tgtPos W@ < if i curPos W@ i deltaVal W@ + i tgtPos W@ min i curPos W! else i curPos W@ i tgtPos W@ > if i curPos W@ i deltaVal W@ - i tgtPos W@ max i curPos W! then then swap d200000 waitcnt \ cnt + 2.5msec swap 0 ctra COG! loop 0 until \ fkey? swap drop until drop ; \ Start servo cog \ ( -- ) : servo_init base d1500 setpos shoulder d1800 setpos elbow d1000 setpos vert_wrist d2500 setpos rot_wrist d1500 setpos gripper d1500 setpos c" servo deltaServo" 0 cogx ; : disp_pos ch 0 do ." ch:" i . ." target:" i tgtPos W@ . ." delta:" i deltaVal W@ . ." usec:" i curPos W@ . cr loop cr ; : demo1 d100 base d1500 movpos d100 shoulder d1600 movpos d100 elbow d1600 movpos d100 vert_wrist d1500 movpos d100 rot_wrist d1500 movpos d100 gripper d1500 movpos ; : demo2 d100 base d1500 movpos d100 shoulder d1800 movpos d100 elbow d1000 movpos d100 vert_wrist d2500 movpos d100 rot_wrist d1500 movpos d100 gripper d1500 movpos ; : demo3 d100 base d2000 movpos d50 rot_wrist 500 movpos d50 gripper d1350 movpos begin rot_wrist at_target until \ Wait until reached at desired position d50 rot_wrist 2500 movpos begin gripper at_target until \ Wait until reached at desired position d50 gripper d2200 movpos ; : wait begin base at_target until begin shoulder at_target until begin elbow at_target until begin vert_wrist at_target until begin rot_wrist at_target until begin gripper at_target until ; : test demo1 wait demo2 wait demo3 wait demo2 ;
Please check i2c_device's folder inside my github.
9224 characters overflowed Prop0 Cog6 ok CON:Prop0 Cog5 RESET - last status: 0 ok
After Loading "RAMDISK_0,1.f" , execute below;
Prop0 Cog6 ok initRAM Prop0 Cog6 ok
Loading sample.f by "flRAM"
Success loading file.
There are text of "sample.f" inside RAMDISK
Prop0 Cog6 ok 0 500 dumpDISK 00000 01F4: 00000: 0D 0D 0D 0D 0D 3A 20 65 72 72 5F 6D 73 67 20 2E .....: err_msg . 00010: 22 20 49 32 43 20 65 72 72 6F 72 22 20 3B 0D 3A " I2C error" ;.: 00020: 20 65 72 72 3F 20 69 66 20 65 72 72 5F 6D 73 67 err? if err_msg 00030: 20 63 72 20 74 68 65 6E 20 3B 0D 0D 6C 6F 63 6B cr then ;..lock 00040: 64 69 63 74 20 63 72 65 61 74 65 20 5F 65 65 73 dict create _ees 00050: 74 61 72 74 20 66 6F 72 74 68 65 6E 74 72 79 0D tart forthentry. 00060: 24 43 5F 61 5F 6C 78 61 73 6D 20 77 2C 20 68 31 $C_a_lxasm w, h1 00070: 32 32 20 20 68 31 31 33 20 20 31 2D 20 74 75 63 22 h113 1- tuc 00080: 6B 20 2D 20 68 39 20 6C 73 68 69 66 74 20 6F 72 k - h9 lshift or 00090: 20 68 65 72 65 20 57 40 20 61 6C 69 67 6E 6C 20 here W@ alignl 000A0: 68 31 30 20 6C 73 68 69 66 74 20 6F 72 20 6C 2C h10 lshift or l, 000B0: 0D 7A 31 5B 69 78 6E 57 20 6C 2C 20 7A 31 5B 69 .z1[ixnW l, z1[i 000C0: 78 6E 58 20 6C 2C 20 7A 32 57 79 50 5B 55 20 6C xnX l, z2WyP[U l 000D0: 2C 20 7A 32 30 69 50 61 6B 20 6C 2C 20 7A 33 72 , z20iPak l, z3r 000E0: 79 50 57 30 20 6C 2C 20 7A 31 62 69 78 6E 57 20 yPW0 l, z1bixnW 000F0: 6C 2C 20 7A 32 57 79 50 5B 56 20 6C 2C 20 7A 32 l, z2WyP[V l, z2 00100: 30 69 50 61 6B 20 6C 2C 0D 7A 33 72 79 50 57 30 0iPak l,.z3ryPW0 00110: 20 6C 2C 20 7A 31 62 69 78 6E 58 20 6C 2C 20 7A l, z1bixnX l, z 00120: 31 53 56 30 31 58 20 6C 2C 20 7A 6C 30 20 6C 2C 1SV01X l, zl0 l, 00130: 20 7A 43 57 20 6C 2C 20 7A 57 30 30 30 30 20 6C zCW l, zW0000 l 00140: 2C 20 7A 47 30 30 30 30 20 6C 2C 0D 66 72 65 65 , zG0000 l,.free 00150: 64 69 63 74 0D 0D 3A 20 53 72 20 5F 65 65 73 74 dict..: Sr _eest 00160: 61 72 74 20 3B 0D 0D 3A 20 5F 65 65 73 74 6F 70 art ;..: _eestop 00170: 0D 5F 73 63 6C 69 20 20 20 20 20 5C 20 52 65 6C ._scli \ Rel 00180: 65 61 73 65 20 73 63 6C 20 0D 5F 73 64 61 69 20 ease scl ._sdai 00190: 20 20 20 20 5C 20 52 65 6C 65 61 73 65 20 73 64 \ Release sd 001A0: 61 0D 3B 0D 0D 3A 20 62 75 73 5F 63 6C 72 20 64 a.;..: bus_clr d 001B0: 31 30 20 30 20 64 6F 20 5F 73 63 6C 6C 20 5F 73 10 0 do _scll _s 001C0: 63 6C 6F 20 5F 73 63 6C 69 20 6C 6F 6F 70 20 3B clo _scli loop ; 001D0: 0D 0D 0D 6C 6F 63 6B 64 69 63 74 20 63 72 65 61 ...lockdict crea 001E0: 74 65 20 5F 65 65 77 72 69 74 65 20 66 6F 72 74 te _eewrite fort 001F0: 68 65 6E 74 72 79 0D 24 43 5F 61 5F 6C 78 61 73 hentry.$C_a_lxas Prop0 Cog6 ok
I wrote code to load program for TK85.
It sound like nostalgia.
Uploded code and pdf to github(2016/9/25 11:54).
c" PropForth5.5 " setUpperStr c" May the Forth be with you." setLowerStr 2 color0 W! 1 color1 W! adafruitStr
Not displaying 7bit-code characters yet.
Using serial I/O.
I have trouble.
Prop0 Cog6 ok init_USBmemory CMD_SET_USB_MODE operation successfull.USB device is present. Checking USB Disk connection status:>Connection to USB -- ok Mounting USB diskST: 0_000_000_031 ST: 0_000_000_020 >USB Mounted -- ok 20_690 00_036: 20_690: 000 128 000 001 031 115 109 105 066 085 070 070 065 076 079 032 .....smiBUFFALO 20_706: 085 083 066 032 070 108 097 115 104 032 068 105 115 107 032 032 USB Flash Disk 20_722: 052 048 048 048 058 032 100 105 115 107 081 117 101 114 121 013 4000: diskQuery. BUFFALO USB Flash Disk 4000 Totale Capacity:505855 kb Logical Total Capacity:505248 kb Free Capacity:505248 kb FAT file system type:FAT Prop0 Cog6 ok dir /* >Readable inside directory TEST1.TXT TEST2.TXT TEST3.TXT TEST4. TEST8.TXT Prop0 Cog6 ok setFileName TEST1.TXT Prop0 Cog6 ok openFile . >File opened successfully 20 Prop0 Cog6 ok <--- USB_INT_SUCCESS readFile Reading file:PropForth5.5 Prop0 Cog6 ok 0 closeFile Closing file:>File closed successfully. Prop0 Cog6 ok setFileName TEST1.TXT Prop0 Cog6 ok openFile . >Failed to open file. Error code:66 66 Prop0 Cog6 ok <-- ERR_MISS_FILE dir /* >Readable inside directory TEST1.TXT TEST2.TXT TEST3.TXT TEST4. TEST8.TXT Prop0 Cog6 ok setFileName TEST1.TXT Prop0 Cog6 ok openFile . >File opened successfully 20 Prop0 Cog6 ok <--- USB_INT_SUCCESS readFile Reading file:PropForth5.5 Prop0 Cog6 ok 0 closeFile Closing file>File closed successfully. Prop0 Cog6 ok
: stop_CH376 0 5 cogio 2+ W! 5 cogreset ;
Today is her 13years old birthday(Jan 2).
Sending JPEG data to Processing after receiving them from LS-Y201.
Photo is a llitle dark and poor color.
This is under debug yet.
Not complete yet.
But cd to up is NG.
Prop0 Cog6 ok init_USBmemory CMD_SET_USB_MODE operation successfull.USB device is present. Checking USB Disk connection status:>Connection to USB -- ok Mounting USB diskST: 0_000_000_031 ST: 0_000_000_020 >USB Mounted -- ok 21_052 00_036: 21_052: 000 128 000 001 031 115 109 105 066 085 070 070 065 076 079 032 .....smiBUFFALO 21_068: 085 083 066 032 070 108 097 115 104 032 068 105 115 107 032 032 USB Flash Disk 21_084: 052 048 048 048 032 032 032 032 032 032 032 032 032 032 032 032 4000 BUFFALO USB Flash Disk 4000 Totale Capacity:505855 kb Logical Total Capacity:505248 kb Free Capacity:505248 kb FAT file system type:FAT16 Prop0 Cog6 ok dir /* >Readable inside directory TEST1.TXT TEST3.TXT TEST4. TEST9.TXT Prop0 Cog6 ok readDemo /TEST1.TXT >File opened successfully Reading file:PropForth5.5 Closing file>File closed successfully. Prop0 Cog6 ok appendDemo /TEST1.TXT >File opened successfully Setting file pointer:Pointer successfully applied Writing to fileSetting data length Writing data to file:7 Updating file size:20 Closing file>File closed successfully. Prop0 Cog6 ok readDemo /TEST1.TXT >File opened successfully Reading file:PropForth5.5-append Closing file>File closed successfully. Prop0 Cog6 ok createFile /TEST2.TXT Created file Prop0 Cog6 ok dir /* >Readable inside directory TEST1.TXT TEST3.TXT TEST4. TEST9.TXT TEST2.TXT Prop0 Cog6 ok deleteFile /TEST2.TXT Successfully to delete file Prop0 Cog6 ok dir /* >Readable inside directory TEST1.TXT TEST3.TXT TEST4. TEST9.TXT Prop0 Cog6 ok cd /TEST4 >Directory opened successfully. >Readable inside directory .. ... TEST5.TXT TEST6. Prop0 Cog6 ok cd TEST6 >Directory opened successfully. >Readable inside directory .. ... TEST7.TXT Prop0 Cog6 ok
Yet strange operation.
Now under debug.
test1 Reset USBbus CMD_SET_USB_MODE operation successfull.USB device is present. SOF mouse Low speed USB-address is 1 CH376-USB-address successful Configure successful over14 ST: 0 1 0 over14 ST: 0 2 0 over14 ST: 0 2 0 over14 ST: 1 7 0 over14 ST: 1 23 FD over14 ST: 0 FD 0 over14 ST: 0 E1 7 over14 ST: 0 B4 E over14 ST: 0 2E 4 over14 ST: 0 32 0 -- Y axis | | | X axis | Left button=1 Right button=2 CH376S module has been reset. Prop0 Cog6 ok CON:Prop0 Cog5 RESET - last status: 0 ok
