Good Lookin' Color Sensor
These LEDs come pre-bent/mangled to save USPS the trouble.
http://www.ebay.com/itm/GY-31-TCS230-TCS3200-Detector-Module-Color-Recognition-Sensor-for-Arduino-JL-/161928174201
2. The LEDs are semi-rigidly mounted at the proper angle to form a spot 1" from the board.
3. Additional LED fixturing is available (from me) for total rigidity.
4. It includes 1" threaded standoffs and mounting screws for repeatable positioning.
5. The LEDs are current-regulated for brightness stability and repeatability.
6. It comes packed in a static bag, with a cardboard sleeve that keeps the LEDs from getting crushed.
7. Every module is completely tested for functionality before packaging.
8. All components are purchased new from reliable suppliers. No gray-market or counterfeit stuff.
9. Modules are assembled in the U.S. by an ISO 9001-2008 certified assembly house.
10. Modules are completely lead-free and RoHS-compliant.
11. And ... you get Parallax's fantastic support.
Yes, the Parallax module is more expensive, but you get what you pay for.
Whoa, I'm not pushing any inferior foreign goods here, and I would have bought the Parallax product if I had a real use for it. Dependability and repeatability didn't justify the expense. You get what you pay for, and erco's example is what you get.
Conversely, however, it might be easy to mistake an "endorsement" for something else when it's being read from a sheet of paper at a press conference, head-down in a monotone voice. (Of course, to keep this post apolitical, I'm not naming names or referring to any particular event!)
