Adding additional analog and digital I/O
George Sutton
This offering from Maxim may be useful if you need to increase the pin count for I/O for a microcontroller project:
https://www.maximintegrated.com/en/products/analog/data-converters/analog-to-digital-converters/MAX11311.html/tb_tab0
Datasheet: https://datasheets.maximintegrated.com/en/ds/MAX11311.pdf
PSoC® Analog Coprocessor CY8C4Axx, 28pin ssop as low as $1.45
First available soon at Mouser is the $4.50 (48pad qfn) CY8C4A45LQI-483 $2.82 @1K
Analog Front End (AFE)
•4 x Opamps
•6 x Comparators
•1 x Programmable Analog Filter
•38-channel Analog Multiplexer
Analog-to-Digital Converters
•1 x 14-bit Delta-Sigma ADC*
•1 x 12-bit SAR ADC
•1 x 10-bit Single-Slope ADC
Digital-to-Analog Converters
•1 x 13-bit Voltage DAC
•2 x 7-bit Current DAC
That's an impressive chip for mixed analog/digital I/O. Thanks for sharing the info.
Also impressive, but as you say "If you're up for the task of programming". The most expensive one is on order while the MAX11311 is in stock.
I'm interested! It'd help simplify my current project tremendously.
One attraction of the MAX11311 is it delivers higher voltage IO, and any mix Analog/Digital.
Not cheap, but very flexible.
Another device that could make a useful object for Isolated Digital In, is the new Si838x series
http://www.silabs.com/products/power/isolators/Pages/si838x-isolators.aspx
Parallel ones need nothing special, but there is a SPI variant, that can cascade to 128 isolated in.
Again, not cheap, but competes with many opto couplers
