Problem loading Extend.fth into tachyon — Parallax Forums
Hello all-
I've encountered the attached error while trying to load extend into tachyon. I've started this thread because the tachyon thread is, well, massive!
Thanks for any help
Shawn
  • Trying the extend in the dropbox folder I get the following errors.
    BTW, I am running v3.0 juno
    1366 x 768 - 38K
  • Sounds like it might simply be a problem with line delay (NOT character delay). Set this to 25m to be safe otherwise here are the current files that I have just checked
    00:00:00  End of source code, 2484 lines processed and 0000 errors found
    Load time = 12.903secs
    MODULES LOADED:
    1780: EXTEND.fth          Primary extensions to TACHYON kernel - 160721-2200
    VER:    Propeller .:.:--TACHYON--:.:. Forth V3.0 JUNO 300160720.0000
    FREQ:   96MHZ (PLLEN OSCEN XTAL1  PLL16X)
    NAMES:  $5B01...74C7 for 6,598 bytes (+3,978)
    CODE:   $0930...3526 for 11,254 bytes (+7,590)
    RAM:    9,691 bytes free
    BUILD:  FIRMWARE BUILD DATE 000000:000000   BOOTS:  0   runtime 0
    BOOT:   EXTEND.boot ok
      ok
    IFDEF V3  ok
      ok
    ---   ok
    : SAVEROMS
             " ROMS" U@ @NAMES 3 ANDN ' TACHYON 3 ANDN
             DO I E@ OVER =                          ---
               IF I 8 + E@ OVER =                    ---
                 IF
                   CR PRINT" COPY ROMS @" I .WORD
                   PRINT"  for " I 4 + E@ .DEC
                   I roms I 4 + E@ romsz MIN ECOPY LEAVE
                 THEN
               THEN
             4 +LOOP
             DROP
             ;  ok
    SAVEROMS
    COPY ROMS @1780 for 6876 ok
    0 U@             ---   ok
    FORGET SAVEROMS  ok
    }  ok
      ok
    ?BACKUP  ok
  • Changed delay to 25 mS. Got this error
    1366 x 768 - 37K
    edited 2016-08-01 04:19
    Shawn Lowe wrote: »
    Shawn, it has been good practice on this forum in general, even with Spin, to attach a zip of the files that were used when having software problems. This might not be a bad idea just to make sure we are exactly on the same page. It sounds like an older version of software mixed up with a newer version. There are also the files that I attached that I had just tested with too.
    There is a possibility that for some other reason the 25ms is not enough although I cannot think why but it won't hurt to increase the delay BUT there would never be any need to go beyond 50ms line delay. Most of the time I just work with 15ms line delay with minicom in Linux on FT232R USB chips.
  • Looks like the OP is using Windows 10. I have built the current files with ZTerm, TeraTerm and Minicom on Window 8, and OSX 10.11. Haven't bothered installing stuff in my ubuntu VM just yet. My line delay is 23ms.
  • @DP- yes I am using windows 10, and teraterm.
    @Peter- My apologies, you are quite right. Attached is the Extend.fth I am trying to use.
  • MJBMJB Posts: 1,235
    edited 2016-08-01 21:58
    and this is loaded on top of which Tachyon?
    It is 'very old' and will not work with Tachyon3
    just use the files from latest dropbox together
  • And in case anyone is using minicom on linux, you have to use command-line options to tell ascii-xfr to put in the line delay. The normal terminal settings don't apply when sending a file. If you paste the file into the terminal they do. At least this was my experience on a Raspberry Pi running Raspbian.
    Usage: ascii-xfr -s|-r [-dvn] [-l linedelay] [-c character delay] filename
  • @MJB- I have downloaded Tachyon V3 juno. this Extend is the version on the front page of Tachyon links in Peter's links to files. Is there a more current one? Tachyon "Juno" loaded just fine with BST. I'm sorry if I am being kinda slow with this, but I'm trying to practice with these awesome tools Peter and everyone else have provided
  • Shawn Lowe wrote: »
    The Tachyon Dropbox folder is always the most current, in fact sometimes it is too current as it reflects the very documents I actively work with but I try to minimize any disruptions. I've rearranged the sig to have the dropbox link prominent. There is a README in the Tachyon root folder that I need to update but otherwise check this.
    btw, I use editors that alert me that an open file has changed and needs to be reloaded since I work on several different computers. If you do the same then you only need to reload/refresh to have the latest files (or just auto reload).
    560 x 285 - 19K
  • Peter-
    The first image is where I am getting the Extend file. I'm trying to use the file that is 102.65kb.When I paste that into tera term I get the error on the second photo. This is the version of tachyon I have loaded on my prop:
    Cold start - no user code - setting defaults
    TACHYON Propeller .:.:--TACHYON--:.:. Forth V3.0 JUNO 300160720.0000
    I am running teraterm with a 30 ms delay/line. I hope this gets us on the same page.
    Shawn
    P.S. Does anyone else loading that version of extend into juno get an error?
    1366 x 768 - 80K
    1366 x 768 - 41K
  • I did until I set the delay to 25 ms.
  • KMyers wrote: »
    I'm bewildered as to what is happening there but did you try using the zip files I sent you as they were ones I tested along with Teraterm?
    That is the error I had originally a couple of weeks ago.
    The problem was solved (and I am using W10). I have been away for nearly a week.
    I suggest you follow the Tachyon thread from here as it also discusses what the other FTH files do.
    forums.parallax.com/discussion/comment/1383443/#Comment_1383443
    edited 2016-08-03 00:41
    Shawn Lowe wrote: »
    Peter-
    Shawn
    That error is at "@word" which didn't exist in an earlier kernel which makes me think you are somehow either using a local copy of the kernel or you decided to load the binary which IS an earlier version with EXTEND already loaded. Don't use the binary if you want the latest, just compile and load the kernel with BST or PropellerIDE (apparently poor old Prop tool can't handle more than 1024 DAT symbols).
  • Yay! Success at last! Thanks so much peter and everyone for helping. Now to play with my DHT22
    Shawn
    Shawn
    Good, but what did you different this time? (remember that it's always good to share the what and why so that these problems can be avoided in future).
    Shawn
    Peter-I downloaded the version of tachyon you listed in your posting https://www.dropbox.com/s/9skb8vwk8gzjy35/Tachyon V3.0 JUNO.spin?dl=0 then I downloaded the latest version of extend in the drop box. I did forget to set delay to 25ms, but after I realizedmy error extend went through without a hitch
    edited 2016-08-12 00:52
    Okay, maybe someone can help. I have Juno and extend loaded onto my prop (from a previous session). I'm opening up teraterm and trying to connect to the prop, but I'm getting nothing when I power down the board and power it up, or when I'm connected and I hit the reset button, or when I hit alt b (break). Is there a specific methodology to reconnecting to a prop loaded with tachyon?
    Edit: I have gotten around this problem by reloading tachyon into eeprom then reloading extend, but shouldn't I be able to just connect to the prop after cycling power using teraterm?
  • Not sure why you are having this problem but please make sure you do not have any hardware handshake enabled. The norm these days for all types of serials connections (not just Tachyon) is "no handshake" as it is normally a 3-wire connect with rx, tx, and ground and soft handshake is not an option either as the PC does not support this in real time as it should.
    to get a start you don't need latest JUNO
    just load the EXPLORER image and you can play.
    building your own system is 'advanced' ;-)
    usually it just works, but sometimes ...
  • I have found that when using Teraterm on Pi's, Bones and Props any time you do a reset of the target board I must exit Tera and restart it. Seams once the connection is broke this happens.
    KMyers wrote: »
    I am using TeraTErm on different windows versions all fine.
    Ctl-C reboots as expected. (actually hate this since it is usually CUT and Prop reboots unwantedly -
    so need to patch to reboot on an other Ctl-Char ... )
  • Mine is on Win 10 with several props, pi's etc. If I reboot I just restart tera. I dont know but that happens here. Taychon works fine for me here othe then this.....
  • FYI-
    Peter solved this problem please see this thread:
    http://forums.parallax.com/discussion/164763/dht22-not-giving-correct-results#latest
    Thanks all for your help!
