SPI code conversion — Parallax Forums
SPI code conversion
Hello everyone, I am using a shift register (74HC595) and I have written some code that is working perfect on the BS2, but I cant seem to figure out how to do the same on the propeller in C. the BS2 code shifts out 8 bits each being its own variable so I can change any one of them at any time without changing the rest.
Out_595:
SHIFTOUT SerData, Clock, MSBFIRST, [op7\1, op6\1, op5\1, op4\1, op3\1, op2\1, op1\1, op0\1]
PULSOUT Latch, 5
RETURN
I am able to communicate with the 595 on the propeller perfectly with the code below. but I have been unable to make it so I can simply change the value of variables like the code above. any help is greatly appreciated thanks.
shift_out(21, 22, MSBFIRST, 8, 0b00000000);
  • DavidZemonDavidZemon Posts: 2,973
    edited 2016-07-27 14:56
    Using an array for this shift_out function would be highly inefficient. But possible. You'll need to write a wrapper function because, as you might have noticed, shift_out does not accept an array. So, I encourage you to simply use the format you posted: shift_out(21, 22, MSBFIRST, 8, 0b00000000);
    But here ya go:
    // C++ version
    unsigned int flatten (const bool bits[], const unsigned int numberOfBits) {
      unsigned int result = 0;
      for (unsigned int i = 0; i < numberOfBits; ++i) {
        result |= bits[i] << (numberOfBits - i);
      return result;
    // C version
    unsigned int flatten (const int bits[], const unsigned int numberOfBits) {
        if (bits[i]) {
          result |= 1 << (numberOfBits - i);
      return result;
    shift_out(21, 22, MSBFIRST, 8, flatten({0, 0, 0, 0, 1, 1, 1, 1}, 8));
  • That's disappointing but after all my attempts i kinda figured it didn't work with a simple array, thank you for your help. each of those bits correspond to the on/off state of 8 different LED's and moters, turning them on or rotating forward/reverse. so my problem was if the first bit was on "1" and I needed to change the last bit then I would need separate 8 bit combination . and a separate 8 bits for every possible combination of 1's and 0's.
  • ElectrodudeElectrodude Posts: 1,687
    edited 2016-07-27 14:37
    Why the separate C and C++ versions? And is making a function to do that actually easier than just using regular old bitfield operations?
    Also, you forgot closing right parentheses after both of your for loops before the left curly brackets.
  • Why the separate C and C++ versions? And is making a function to do that actually easier than just using regular old bitfield operations?
    I like the C++ version because of the bool type. Makes the code a bit shorter. But he asked for C, so I thought it would be nice to include both.
    Thanks for noticing. I'll get that fixed.
  • bnikkel wrote: »
    Certainly understandable. When we have folks talking about running JavaScript on the Propeller, and using 64-bit floats for everything, I would say a little array for some bits isn't too big of a deal :P. Simply be aware of the performance issues and, if you run into problems (speed or code size), you'll know one good place to look for optimization opportunities.
  • Thanks again for all your help David, greatly appreciated
  • No problem. Happy coding!
  • just wanted to update this. i revisited an old problem and have figured out a solution to it. being able to update variables independently and then shift_out to the 595. seems easy now but 5 years ago it was beyond me.
    74HC595 com test
    include "simpletools.h" // Include simpletools lib
    long newvalue;
    int a = 1;//1;
    int b = 0;//2;
    int c = 0;//4;
    int d = 0;//8;
    int e = 0;//16;
    int f = 0;//32;
    int g = 0;//64;
    int h = 0;//128;
    int i = 1;//256
    int j = 1;//512;
    int k = 0;//1024;
    int l = 0;//2048;
    int m = 0;//4096;
    int n = 0;//8192;
    int o = 0;//16384;
    int p = 1;//32768;
    int main() // Main function
               newvalue = ((int)a << 15);   //
               newvalue += ((int)b << 14);
               newvalue += ((int)c << 13);
               newvalue += ((int)d << 12);
               newvalue += ((int)e << 11);
               newvalue += ((int)f << 10);
               newvalue += ((int)g << 9);
               newvalue += ((int)h << 8);
               newvalue += ((int)i << 7);   //
               newvalue += ((int)j << 6);
               newvalue += ((int)k << 5);
               newvalue += ((int)l << 4);
               newvalue += ((int)m << 3);
               newvalue += ((int)n << 2);
               newvalue += ((int)o << 1);
               newvalue += (int)p;
    shift_out(0, 1, LSBFIRST, 16, newvalue); // Value for MCTL register
    pulse_out(6, 1);
     print("value  %b\n", newvalue);           // Display array element & value
    pause(500);
  • Thanks for the update. You answered my question.
