Prop2 ROM code
in Propeller 2
I've got the Prop2 ROM code all optimized now.
I may add a text-only loader, in case serial and flash fail to load and/or authenticate. For now, this program takes $12E longs out of a possible $1F8. That's 60% full.
'* Propeller II ROM Booter *
'* Version 0.1 *
'* 07/16/2016 *
CON
id = $52 'version $20
' id = $8F 'version $21
' id = $BC 'version $22
' id = $61 'version $23
' id = $78 'version $24
' id = $A5 'version $25
' id = $96 'version $26
' id = $4B 'version $27
rx_pin = 63
tx_pin = 62
spi_cs = 61
spi_ck = 60
spi_di = 59
spi_do = 58
DAT org
' Read fuses
decod ptra,#11 'read 256 fuses into $800..$81F
rep @.r,#256
cogid fuse_read wc 'set fuse number
cogid fuse_read wc 'read fuse
rcr x,#1 'save fuse
add fuse_read,#1 'next fuse
test fuse_read,#$1F wz 'every 32 fuses, write to hub
if_z wrlong x,ptra++
.r
cogid #0 wc 'disable fuses
' Attempt to boot from serial
setb outb,#tx_pin 'make tx high output
setb dirb,#tx_pin
call #rx_bit 'measure low rx calibration pulses (host $F9 -> %1..010011111..)
mov threshold,delta 'and calculate threshold
call #rx_bit '(any timeout results in flash boot)
add threshold,delta
shr threshold,#1
mov count,#250 'ready to receive/verify 250 lfsr bits
.lfsrin call #rx_bit 'receive bit ($FE/$FF) into c
test lfsr,#$01 wz 'get lfsr bit into nz
if_c_eq_z jmp #boot_flash 'if mismatch, boot from flash
test lfsr,#$B2 wc 'advance lfsr
rcl lfsr,#1
djnz count,#.lfsrin 'loop for next bit in
mov count,#250+8 'ready to transmit 250 lfsr bits + 8 version bits
.lfsrout cmp count,#8 wz 'if last 8 bits, set lfsr so that version will be output
if_z mov lfsr,#id 'id results in version being sent
test lfsr,#$01 wz 'get lfsr/version bit into nz, z=1 on last iteration
call #wait_rx 'wait for rx low (convey incoming $F9 on rx_pin to $FE/$FF on tx_pin)
clrb outb,#tx_pin 'make tx low
call #wait_rx 'wait for rx high
setbnz outb,#tx_pin 'make tx lfsr/version bit
rcl lfsr,#1
djnz count,#.lfsrout 'loop for next bit out
jmp #load 'serial handshake done, attempt to load from serial (z=1)
' Receive bit (c) - compare incoming pulse to threshold
rx_bit call #wait_rx 'wait for rx low
getct y 'get time
getct delta 'get time
sub delta,y 'compare time delta to threshold
cmp delta,threshold wc
ret
' Wait for rx low/high - if timeout, attempt to boot from flash
wait_rx setedg edge 'ready edge
getct x 'wait for rx edge with timeout
add x,timeout
setq x
waitedg wc
xor edge,#%11_000000 'toggle edge
if_nc ret 'return if not timeout (boot_flash follows)
' Attempt to boot from flash
boot_flash mov count,#4 'ready for 3 resets and 1 read command
.cmd setb outb,#spi_cs 'spi_cs high
or dirb,dirb_flash
clrb outb,#spi_cs 'spi_cs low
rep @.r,#32 'ready for 32 command bits
cmpr count,#1 wc 'first three commands = $FF_FF_FF_FF (reset)
if_nc rol spi_read,#1 wc,wz 'last command = $03_00_00_00 (read from 0), z=0
setbc outb,#spi_di
setb outb,#spi_ck 'cycle spi_ck
clrb outb,#spi_ck
.r
djnz count,#.cmd 'loop for next spi command
' Load from serial (z=1) or flash (z=0)
load wrfast #0,#0 'load loader into $000..$7DF, HMAC into $7E0..$7FF
decod count,#9 'ready to input $200 longs
.long mov i,#32 'ready to input 32 data bits
.bit if_z call #rx_bit 'input serial bit (serial mode)
if_nz testb inb,#spi_do wc 'input spi_do (flash mode)
if_nz setb outb,#spi_ck 'high spi_ck (flash mode)
if_nz clrb outb,#spi_ck 'low spi_ck (flash_mode)
rcl z,#1 'shift bit into long
djnz i,#.bit 'loop, adequate time for next flash bit
wflong z 'store long in hub ram
djnz count,#.long 'loop for next long
' Authenticate loader HMAC signature
' $000..$7DF = loader ($1F8 longs)
' $7E0..$7FF = loader HMAC signature ($008 longs)
' $800..$81F = fuses, first half are HMAC key ($008 longs)
' hashx[0..7] = proper HMAC signature (endian) ($008 longs)
call #hmac 'compute proper HMAC signature, rdfast at $7E0
rep @.r,#8 'compare HMAC signatures
rflong x 'get loader HMAC long
movbyts x,#%00_01_10_11 'do endian reversal before comparison
.hash cmp x,hashx wz 'compare to proper HMAC long
if_nz clkset #%0000_00_01 'if failed, set clock to rc slow
if_nz cogstop #0 'if failed, stop cog0
add .hash,#1 'point to next proper HMAC long
.r
coginit #0,#0 'loader authenticated, relaunch cog0 with loader
' Booter constants
fuse_read long $200 '(becomes $300)
lfsr long "P"
edge long %10_000000 | rx_pin
timeout long 20_000_000 / 1000 * 150 '150ms @20MHz (rcfast)
dirb_flash long %1110 << 58
spi_read long $03_00_00_00
'* SHA-256/HMAC *
' Start HMAC
hmac call #init_hash 'init hash
decod ptra,#11 'begin HMAC using key at $800..$80F
.ipad cmp bytes,#16 wc
if_c rdbyte x,ptra++ 'get and hash ipad key (full block)
if_nc mov x,#$00 'after key bytes, hash $00's to fill block
xor x,#$36 'xor bytes with ipad ($36)
call #hash_byte '(last iteration triggers hash_block, z=1)
if_nz jmp #.ipad
setd i,#w 'save opad key
setr i,#opad_key
rep @.r,#16
alti i,#%111_111_000
xor 0,opad 'xor bytes with opad ($5C)
.r
' Hash loader
rdfast #0,#0 'hash loader at $000..$7DF
mov count,##$7E0
.byte rfbyte x
call #hash_byte
djnz count,#.byte
call #end_hash 'end hash
' End HMAC
sets i,#opad_key 'get opad key into w[0..15] (full block)
setd i,#w
call #copy8
call #copy8
call #hash_block 'hash opad key
sets i,#hashx 'get hashx[0..7] into w[0..7]
setd i,#w
call #copy8
setd hash_byte,#w+8 'account for opad key and hashx bytes
mov bytes,#64+32 '(1-1/2 blocks, 1/2 block needs end_hash)
' End Hash - hash $80, any $00's needed to get to offset $38, then 8-byte length
end_hash mov length,bytes 'get message length in bits
shl length,#3
mov x,#$80 'hash end-of-message byte ($80)
.fill call #hash_byte '(may trigger hash_block)
mov x,bytes 'hash any $00's needed to get to offset $38
and x,#$3F
cmp x,#$38 wz
mov x,#$00
if_nz jmp #.fill
.len test bytes,#$04 wc 'hash 8-byte length, big-endian
if_c rol length,#8 '(hash four $00's, then four length bytes)
if_c mov x,length
call #hash_byte '(last iteration triggers hash_block)
if_nz jmp #.len
sets i,#hash 'save hash[0..7] into hashx[0..7]
setd i,#hashx
call #copy8
init_hash sets i,#hash_init 'copy hash_init[0..7] into hash[0..7]
setd i,#hash
call #copy8
mov bytes,#0 'reset byte count
ret
' Hash Byte - add byte to w[0..15] and hash block if full (z=1)
hash_byte rolbyte w,x,#0 'store byte into w[0..15], big-endian
add bytes,#1 'increment byte count
test bytes,#$03 wz 'every 4th byte, increment w pointer
if_z alti hash_byte,#%000_011_000
test bytes,#$3F wz 'every 64th byte, reset w pointer
if_z setd hash_byte,#w
if_z call #hash_block 'every 64th byte, hash block
ret
' Hash Block - first extend w[0..15] into w[16..63] to generate schedule
hash_block mov i,#16 'i = 16..63
.hashb alts i,#w-15 's0 = (w[i-15] -> 7) ^ (w[i-15] -> 18) ^ (w[i-15] >> 3)
mov x,0
mov y,x
rol y,#18-7
xor y,x
ror y,#18
shr x,#3
xor x,y
alts i,#w-2 's1 = (w[i-2] -> 17) ^ (w[i-2] -> 19) ^ (w[i-2] >> 10)
mov y,0
mov z,y
rol z,#19-17
xor z,y
ror z,#19
shr y,#10
xor y,z
alts i,#w-16 'w[i] = s0 + w[i-16]
add x,0
alts i,#w-7 'w[i] = s0 + w[i-16] + w[i-7]
add x,0
altr i,#w 'w[i] = s0 + w[i-16] + w[i-7] + s1
add x,y
incmod i,#63 'i++
tjnz i,#.hashb
' Load variables from hash
sets i,#hash 'copy hash[0..7] into a..h
setd i,#a
call #copy8
' Do 64 hash iterations on variables
mov i,#0 'i = 0..63
.hashi mov x,g 'ch = (e & f) ^ (!e & g)
xor x,f
and x,e
xor x,g
mov y,e 's1 = (e -> 6) ^ (e -> 11) ^ (e -> 25)
rol y,#11-6
xor y,e
rol y,#25-11
xor y,e
ror y,#25
add x,y 't1 = ch + s1
alts i,#k 't1 = ch + s1 + k[i]
add x,0
alts i,#w 't1 = ch + s1 + k[i] + w[i]
add x,0
add x,h 't1 = ch + s1 + k[i] + w[i] + h
mov y,c 'maj = (a & b) ^ (b & c) ^ (c & a)
and y,b
or y,a
mov h,c
or h,b
and y,h
mov h,a 's0 = (a -> 2) ^ (a -> 13) ^ (a -> 22)
rol h,#13-2
xor h,a
rol h,#22-13
xor h,a
ror h,#22
add y,h 't2 = maj + s0
mov h,g 'h = g
mov g,f 'g = f
mov f,e 'f = e
mov e,d 'e = d
mov d,c 'd = c
mov c,b 'c = b
mov b,a 'b = a
add e,x 'e = e + t1
mov a,x 'a = t1 + t2
add a,y
incmod i,#63 'i++
tjnz i,#.hashi
' Add variables back into hash
sets i,#a 'add a..h into hash[0..7]
setd i,#hash
rep @.r,#8
alti i,#%000_111_111
add 0,0
.r
ret
' Copy 8 registers
copy8 rep @.r,#8
mov 0,0
.r
ret
' SHA-256/HMAC constants
opad long $36363636 ^ $5C5C5C5C
hash_init long $6A09E667, $BB67AE85, $3C6EF372, $A54FF53A 'fractionals of square roots of primes 2..19
long $510E527F, $9B05688C, $1F83D9AB, $5BE0CD19
k long $428A2F98, $71374491, $B5C0FBCF, $E9B5DBA5 'fractionals of cube roots of primes 2..311
long $3956C25B, $59F111F1, $923F82A4, $AB1C5ED5
long $D807AA98, $12835B01, $243185BE, $550C7DC3
long $72BE5D74, $80DEB1FE, $9BDC06A7, $C19BF174
long $E49B69C1, $EFBE4786, $0FC19DC6, $240CA1CC
long $2DE92C6F, $4A7484AA, $5CB0A9DC, $76F988DA
long $983E5152, $A831C66D, $B00327C8, $BF597FC7
long $C6E00BF3, $D5A79147, $06CA6351, $14292967
long $27B70A85, $2E1B2138, $4D2C6DFC, $53380D13
long $650A7354, $766A0ABB, $81C2C92E, $92722C85
long $A2BFE8A1, $A81A664B, $C24B8B70, $C76C51A3
long $D192E819, $D6990624, $F40E3585, $106AA070
long $19A4C116, $1E376C08, $2748774C, $34B0BCB5
long $391C0CB3, $4ED8AA4A, $5B9CCA4F, $682E6FF3
long $748F82EE, $78A5636F, $84C87814, $8CC70208
long $90BEFFFA, $A4506CEB, $BEF9A3F7, $C67178F2
' variables
vars 'start
delta res 1 'booter
threshold res 1
bytes res 1 'SHA-256/HMAC
count res 1
length res 1
opad_key res 16
hash res 8
hashx res 8
w res 64
a res 1
b res 1
c res 1
d res 1
e res 1
f res 1
g res 1
h res 1
i res 1
x res 1
y res 1
z res 1
Looks good, any ideas what size a SD or even USB loader needs ?
No. SD is possibly simple if we look for a starting string.
Is there not a way to fast-skip UART boot, eg by tie RXD low (or some other pin) with pull down ?
I think uart boot is a good idea, it lowers the barriers. Lets you load over radio devices and is easy to debug. Could even load from a 4D systems screen, or an Osborne 1. Plus if done from a terminal the prop can immediately send data back
FWIW the P1 tries the serial port first. If the RXD(SI) pin P31 is low? then serial is skipped, otherwise it waits for a period of time for a serial handshake sequence before moving on. Next, I2C EEPROM is tried. If there is no eeprom then the P1 quits (effectively locks until reset). Otherwise, the whole 32KB is loaded from EEPROM into Hub RAM, the lower few longs are verified, and if correct the cog runs the spin program.
P2 Encryption
If the P2 has the encryption fuses non-blank (because I don't know if they are 1's or 0's when blank), then a key has been programmed. In this case, IMHO, the P2 should only run from SPI (Flash or perhaps SD). IMHO it should NOT accept download serial code. This can be done by the code in Flash or SD by the user. Remember, we don't want to help any brute force attacks. We want this to be totally under user control.
Also, the user is likely to want a fast load/run P2, so no delays waiting for serial, etc.
Non-Encryption (default)
If the P2 encryption fuses are blank, then the boot process should perform..
* serial (P63/52 as RXD(SI)/TXD(SO)
* SPI Flash
* (optionally) SPI SD
* (optionally) simple monitor/loader
Miscellaneous
You may recall I suggested some years ago, that we could use a single pin with various values of pullup/pulldowns. This could accomplish a fast boot without waiting for serial. Various pullup/pulldown values could select the boot order/sequence.
It has also been suggested that Quad SPI be used. This means that the SPI Flash pins ought to be on different pins to those suggested as P61-P58. I can add a drawing later (no time currently).
We can determine if an SD card is present by testing for a pullup on the nCS line (Peter J has shown that a physical pullup is not necessary, and that the SD Card when present presents a pullup high value, and o/c which can be tested when the SD Card is absent.
Here are my thoughts...
P63 = RXD(SI) serial (or USB)
P62 = TXD(SO) serial (or USB)
P61 = nCE - SD
P60 = nCS - Flash
P59 = D3/nHLD
P58 = D2/nWP
P57 = D1/SO
P56 = D0/SI
Postedit: Forgot the CLK pin!!! see my next post
The above permits the SD and Flash to share the D0-D3 pins, permits Quad SPI operation.
P?? = Optional pullup/pulldown - various values for boot options
It depends on how well we can detect the value. ie can we detect 1K/5K/10K vs the weak pullup of an external flash chip. Perhaps we can share the pin with the nCS or the nCE or else on one of the D0-D3 pins with pullup or pulldown. Need more discussion.
Perhaps it would be sufficient to detect the nCS (Flash) being pulled low (=>10K) for not being present, and therefore skip booting from Flash.
SD Card
I suggest we go with Peter J's method of checking the MBR sector for a string, and if found, use the sector number it points to for the sector of the $200 byte/long read for the boot code.
I really can't see the need for QSPI when we are running the SD in SPI mode and any Flash device is really only a boot device and if there were any need to store files on there then they are going to be pretty darn small so what's the need for QSPI here? It seems that we get confused as to what our actual requirements are because we are sidetracked by what we might be able to do.
The original Flash SPI pinout kept pin wastage to a minimum: If now we stick with that then we could make P57 the SD chip select. I also use P60 for an I2C SCL as well and although I allow for EEPROM in my restore routines I don't see a real need for it for boot.
It seems to me that we want low latency boot so waiting around for the serial port is not on, the PC is the one that should expect to wait after a reset and the P2 needs to check for basics first, such as the SPI Flash as that is nice and simple to init and read, then the SD card which can use the SD chip select as a card detect to quickly skip that if no card is present. If a card is present then it has to go through a "relatively" lengthy initialization before reading sector zero but if the boot signature fails then on to serial etc.
btw, the simple serial loader is only a backup for when the standard serial loader fails as I understand it. I like the idea and yes, we can use it over wireless links too.
The reason I suggested the pinout for Quad SPI is if there is no SD then quad spi can be used. The same D0/D1 pins can be used for SD and D0-D3 if using the SD in the fast mode (in case it is done later.
But I forgot to allow for the CLK pin in my suggested pinout. What I thought was a bad idea is to require the D0/D1 pins to need to be reconfigured to a new location if quad mode was used. Quad mode should have the D0-D3 pins on a nibble boundary, hence the suggestion of P56-59=D0-D3.
Yes, I agree with the SD format, that we can either read a fixed number of sectors of the number of sectors as a count in the MBR sector. And the way suggested is not format restricted, as a few of us have agreed in the past.
Here is a thought. Normally I would invert the nCS output pin for selecting my SRAM vs SD. We could do the same instead for selecting FLASH or SD. However, if only one of these were present as an either/or, we could use the pin for nCS for either FLASH or SD, depending on which was fitted.
I would expect that we could interrogate for FLASH and if an SD was connected it would fail to respond since it would not recognise the protocol. We can verify that this does not cause a problem with the SD.
Here is a revised suggestion..
As for serial, it is a requirement that the serial be tried before Flash. This is because if you burn a bad program into flash, you can override it and reprogram it. If you boot into flash first, you can lockout serial downloading!
However it timing out after a minute means its still timing dependent, just on a relaxed scale
Once Flash or SD exists, then it is a simple matter to have a more thorough monitor/loader burnt into Flash or SD.
The debugger/monitor that I have been working on I thought could have been preloaded from ROM into hub so that any program could simply call it. The debugger/monitor can still be added to your code as an object, and reside in hub.
It recalibrates on the space character that is used at the start and in between hex bytes so it is constantly adjusting with every byte. Not as efficient or as fast as the binary loader but guaranteed to work with just about anything anywhere, just paste your hex file through your Bluetooth terminal on your smartphone to program the P2.
Quite a lot of P2 designs will be SPI Flash only, and those are quite cheap.
I think these days, 2MBytes sub 20c/1k TSSOP8
Boot ROM itself does not need to be QuadSPI, but it is important that it is QuadSPI tolerant.
That means the extra Data pins, which are IIRC Hold and WE, must be legally defined during SPI boot, and SPI boot does need to reset any Quad mode.
(ie a Reset may arrive from a watchdog, while the user has QuadSPI mode enabled - this needs to exit Quad, then load, reliably)
Because Boot is size-definable, the stage 1 (ROM) can be Single SPI, then flip to QuadSPI.
Maybe that's right then, I was really just concentrating on the text loader advantages as a fall-back to the binary loader.
Re boot sequence
While it is true we need the serial bootloader to override internal boot I would hate for the internal boot to be delayed because of big timeouts. If serial activity is not detected within milliseconds then I think it should move on to the Flash and SD.
Re boot pins
I was thinking too that the chip select could be used for either the Flash or the SD as Cluso99 mentioned but I wouldn't try to run both even with an inverter. Either a system has a Flash and no SD or it uses the SD for boot as it has no Flash. Otherwise the bootloader should expect an alternate chip select for the SD if one is not detected on the Flash line. But where oh where is this 4-bit SD mode? Isn't this a proprietary licensed Secure Digital mode? That's why we all use SPI mode and I'd rather not waste extra pins on QSPI just to make it boot a fraction faster when we already have boot sequence delays etc that erode any speed gains.
Also, you didn't comment on my request that you provide a tiny Forth interpreter to go in the ROM? Certainly, squirting some Forth over the serial port would allow you to effect a simple loader and would also provide a way to interactively poke at the hardware without having to load anything else. I can't remember how big Chip said the ROM would be but would it be completely impossible to provide an interactive programmable interface instead of just a dumb loader?
a) define those extra pins during boot, so it can Boot from QuadSPI, used as Simple SPI.
b) Issue enough reset/init commands to exit any possible Quad MODE
It's hard to buy a Flash device these days that is not QuadSPI, and certainly the cheapest ones are QuadSPI, so those cheapest parts need to be tolerated, in all their possible connects.
eg Someone may boot entirely in 1b SPI, but use the majority of their 2MBytes for Fonts, that they read in using QuadSPI mode.
Text loader needs three bytes for every 8-bits so 33% utilization vs binary loader typical of maybe 50%.
I replied to your request for a tiny Forth almost as if you were being tongue-in-cheek and responding in like manner. I know I would love to have a tiny Forth interpreter in ROM but there seems to be quite a number who are not just "not interested" but even anti-Forth. It's a tool that as Open Firmware has worked well for many computer makers and EFI is just the bloated and conventionalized version of that which we find in any new PC. I just really doubt I would have any support at all for such a boot Forth.
I'm just interested in using these P2 chips in production not just playing with them to see what I can get out of it. I see all this HyperRAM and QSPI etc as nice but it should not drive the base requirements. I see nothing wrong with QSPI but come on, I wouldn't expect to be loading all 512kB into RAM or have such huge fonts that require megabytes of Flash when usable video memory is going to be less than 512k of hub RAM. QSPI capable memory easily supports dual and single SPI and IIRC when coding these they require a special command to put them into QSPI mode anyway, the default is SPI.
If your desire is more about pushing the limits then you can but dedicating boot pins based on this is not being practical though. However, whatever Chip does, he does.
Likewise, if the SD used the same D0-D3 pins, it may be possible to use the SD card in the licensed mode. I thought there were some people clean-room deciphering the code for free use. Anyway, it just makes it compatible with the SPI Quad mode.
Hopefully we could boot to either SPI, and if not found, try SD. If the boot code supports SD (which I sincerely hope it does) then I would expect anyone building a board with SD would not be likely to put on a SPI Flash chip since it would not be required.
BTW I am not expecting Quad SPI to the be-all end-all as many expect.
