Still playing with my P2 CV-A9 + motherboard and testing out RS485 communications with a string of P1s sitting off it. I even tried chatting to each P1 over telnet, through the P2, and to the P1 via RS485 using the ping-pong protocol so that it emulates a full-duplex connection. I can even download new source code to the P1 via the P2 via telnet. I just made the mistake of telling it to "cat WARPEACE.TXT" and it just kept spewing the contents of the book for several minutes. BTW, I even have SD cards on some of the P1s so I suppose I could chat with one of them and get it to do the same.
Anyway, I will probably make up my little PIC serial boot emulator so I can run the P2 stand-alone. The PIC only needs to load up a serial flash routine so that I can restore my backup image from flash. It's almost the same thing for SD as well but I'm just working with Flash booting at the moment.
Here's a terminal capture of me connecting to the P2 over telnet, checking a couple of things and then chatting with a P1 on the RS485 network in full-duplex mode. (10 CHAT is when I connect to a P1)
peter@peter-XPS-15-9550 ~ $ telnet tachyonforth.com 10001
Trying 58.161.247.42...
Connected to tachyonforth.com.
Escape character is '^]'.
WELCOME TO THE IoT5500 TELNET SESSION
Use Forth commands, for help type QWORDS
Try ls or DIR for directory
Session time is unlimited but all other network ports
will be blocked until Telnet is disconnected
ok
TF2# q
CODE MEMORY @ $00.8026 for 28,710
NAME MEMORY @ $00.B3BA for 9,995
DATA MEMORY @ $00.E2FB for 290
FREE MEMORY = 13,204
MODULES LOADED:
7041: EASYNET.fth WIZNET NETWORK SERVERS 151111.08006405: W5500.fth WIZNET W5500 driver for TF2 151110.1500
4E44: SDFAT.fth P2 SDFAT FILE SYSTEM - 160619.0000
4C59: EEPROM.fth EEPROM UTILIES - 160625.0000
2D80: EXTEND.fth TACHYON FORTH EXTENSIONS for the P2 - 151121-1400
POLL #0 ?EASYNET
2016/07/06 WED 23:56:15
-------------------------------------------------------------------------------- ok
TF2# ls
NO NAME
WARPEACE.TXT EXTEND .FTH EEWORDS .FTH VGA .FTH CLOCK .FTH
EASYFILE.FTH BREAKOUT.FTH SDCARD .FTH W5500 .FTH LIFE .FTH
EASYNET .FTH IOT5500 .HTM WELCOME .TEL POPCORN .MP3 HOME .HTM
P8CPU .JPG IOTPINS .JPG LOVE .WAV HELP .TXT P8 .H
IOT5500H.JPG DRAGON .JPG IOT5500 .JPG 128K .BIN 256K .BIN
W5200 .FTH PREVIOUS.ROM DEBUG .ROM POPCORN .WAV P8X32A .PDF
IMAGE3 FRED .PNG FSRSCH .PNG FSRPCB .PNG IMAGE
HTTP404 .HTM IMAGE2 IMAGE1 LOGON .HTM TACHYON .HTM
WELCOME .FTP P2BOOT .IMG POWERMAX.LOG SITE0002.LOG SITE0001.LOG
CE1372 .JPG CE1372 .PDF CHARLCD .JPG ECOLCD .PDF LOVE .MP3
FIRMWARE.ROM ok
TF2# 10 CHAT
ok
qw
qw
QV ?AUTOLOAD FCRC (LOADROM) LOADIMG LOADROM SAVEIMG SAVEROM FIXBIN ROMSZ .FILES
.FX .FILE ls .LIST (.LIST) (ls) lscnt .UTIME .FNAME (SLIST) (DIR) DIR udir (.DIR)
.DIR .ATR PROMPT .PATH pwd cd$ cd cwd$ cat (cat) FPRINT$ FRUN FLOAD DELETE RENAME
RENAME$ RW APPEND APPEND.BLK eof -FERASE @RCD >|RCDSZ RCDSZ FCREATE$ FOPEN FOPEN$
FOPEN# FCLOSE FOUTPUT >FILE FINPUT FILE> FPUTB FPUT FGET fkey FREM @FWRITE @FREAD
fstat fwrite fread FFC@ FC@ FC! FILE@ FSECT@ FSIZE@ StartCluster CLUSTERS? ROUNDUP/
CLUSTER@ @CLUSTER NextFreeDir .FTIME .FDATE .FYEAR FSTAMP FTIME! +DIR! FDATE! DECS
DIR! DIR? dir$ @DIRBUF @FSIZE @FCLST @FDATE @FTIME @FCLSTH @ADATE @CDATE @CTIME
@CMS @ATR @FEXT @FNAME >F83 fname$ FILE$ file$ ?SDCARD ?MOUNT MOUNT .FAT READFAT32
CLUST>SECT FAT2 FAT1 @FAT @BOOT cwdsect @ROOT fboot dirbuf file diradr rootdir clshift
mounted fatname ok
.PPCFG
.PPCFG #10 @1,000,000 TR/TE=14/15 ok
$7F BL DO I EMIT LOOP
$7F BL DO I EMIT LOOP !"#$%&'()*+,-./0123456789:;<=>?@ABCDEFGHIJKLMNOPQRSTUVWXYZ[\]^_`abcdefghijklmnopqrstuvwxyz{|}~ ok
'C .
'C . 29 ok
ls
ls *No Card inserted!* *Card Error* *Card Error*
ok
.VER
.VER Propeller .:.:--TACHYON--:.:. Forth V29160613.0000
ok
^Q
ok
TF2# ok
TF2#
Neat, I'm on the list for a couple MB's and any booter boards you make work up for the CV-A9.
A few of those discontinued flash parts would be nice to boot. Couldn't help it. Very quiet in P2 land.
I think the forum in terms of actual P1 or P2 stuff is extremely quiet and has been for years now. P2 has been a long long time coming, I wonder if we will ever get that forum energy back again.
Here is a TF2 decompiler I cobbled together quickly, I will probably enhance it bit by bit. I've now included it in EXTEND.fth although you will find the SEE.fth in the P2 folder.
(Updated 8th July 2016)
TF2# SEE ?FTP
7D65: 7350 FTP
7D67: 6A1B SOCKET
7D69: 7520 CONNECTED?
7D6B: 00EA IF $7DBC
7D6F: 009D $0046 (70) 'F'
7D73: 75E4 constat
7D75: 0087 C!
7D77: 28E8 CON
7D79: 152D CR
7D7B: 0181ON7D7D: 7413 QUIET
7D7F: 6DB7 autosend
7D81: 319A C~~
7D83: 6EE7 LANCON
7D85: 1D87 PRINT" 220 WELCOME TO THE TACHYON WIZNET FTP SESSION!"7DB6: 152D CR
7DB8: 74FE KEEPALIVE
7DBA: 74D8 LANSKT
THEN7DBC: 7570 DSCTD?
7DBE: 00EA IF $7DCC
7DC2: 009D $0066 (102) 'f'
7DC6: 75E4 constat
7DC8: 0087 C!
7DCA: 351D CONIO
THEN7DCC: 000D ; ok
Nice work as usual Peter. I probably should have invested the time to learn your Tachyon but I prefer assembler.
The forums are extremely quiet. Makes me wonder if there will be a volume market for P2 when it finally arrives.
I use assembler all the time on small micros but with anything that has enough resources I usually implement a Forth so that I can be more productive and develop and debug interactively at a much higher level. I also like my assemblers "flat" in that I can control what goes where and how which is also how Forth operates too as you can discern from a decompilation that there is a one-to-one correspondence with the compiled code and the source code, in fact I can fancy up my decompiler so that it reconstructs the source code along with indentation etc in a compilation ready form. So I see Forth much like I see assembler language, it gives me full control over the hardware and compilation while still running close to the metal but providing that interactive hands-on hardware feel.
BTW, Forth is just the assembler, along with directives and macros of the virtual stack machine, so there wouldn't be much for you to learn then seeing it is "just another assembler language"
Peter,
I love the way the prop works. It makes assembler easy without interrupts. I know we now have these too, but they are quite simple when you need them. What also helps is that you can throw more cogs at a job to keep the assembly separate.
I also like spin because its also quite simple and easy to learn. No point in everything being in assembler. But we don't have this yet on P2.
So I am concentrating on a debugger for now. I want it to be able to be called from within a cog, or from another cog.
Once I am happy, I might give Tachyon2 a go to work with my debugger. We will see.
Anyway, you have proven Tachyon to be a fantastic tool to work with !!!
Peter,
Well I agree with Spin being easy to use and it's a pity that it is no longer promoted. If I had to wrangle with a C compiler and its "red tape" I might not have developed a fondness for the Prop in the first place but with just a few lines of Spin and an F11 the Prop comes to life.
However the Tachyon VM is all assembler under the hood, it would be good if you had a look at the source to see if you could offer any suggestions too, as I have not delved too deeply into the newer P2 instructions just quite yet
My worries are more immediate - I wonder if there is enough P2 testing going down, for release sign-off
USB (host & device?) seems to have gone quiet, and getting working HyperRAM with some bandwidth numbers, and comparison with working SDRAM & even SRAM looks to have also paused...
I've taken some time off over the last few weeks, mainly because summer is happening and there are lots of outdoor things to be done.
Lately, I've been getting back into the documentation, as it needs to be more complete. I was starting to work on the ROM code, but realized that lack of documentation was holding me up. It took me a while to re-figure out what ALTI does, as it's needed by the SHA-256 code. So, I got that documented for, at least, my own use. It's in the main doc file. I think I will document the pixel instructions next, as people have been asking about them.
I have TF2 running on the 1-2-3 FPGA (P2 Vs 10a). I am working through EXTEND . However, I noted that after loading TF2, I found #421 on the data stack. After clearing the stack and loading EXTEND.fth, -#59038737 & #421 were on the stack. I am using the latest EXTEND version.
TF2# .s 0000 [ 0000.00000000.00000000.00000000.01A5 ]TOP ok
TF2# .VER Parallax Propeller 2 .:.:--TACHYON--:.:. Forth V11160702.1400 PIONEER
ok
TF2# IFDEF VOCAB: ok
TF2# ok
TF2# P2 TACHYON 1 flags CLR Parallax Propeller 2 .:.:--TACHYON--:.:. Forth V11160702.1400 PIONEER
ok
<snip>
10:10:26End of source code, 0471 lines processed and0000 errors found
Load time = 609114733 cycles or @160MHZ 7.613sec
CODE MEMORY @ $00.4F9A for 16,282
NAME MEMORY @ $00.C4B9 for 5,644
DATA MEMORY @ $00.E000 for 202
FREE MEMORY = 29,983
MODULES LOADED:
2D80: EXTEND.fth TACHYON FORTH EXTENSIONS for the P2 - 160707-15002016/07/18 MON 10:10:26
TF2# ok
TF2# .S
DATA x1 DEAD.BEEF
BRANCH x0
LOOP x0
RETURN x3 0000.26C7 0000.4F9C 0000.37EB ok
TF2#
I note too that 7.6 seconds is my actual not projected load time so I will have to fix that reporting but otherwise it seems fine. Can you post your screen copy in a similar manner.
btw, there is no need for any delays or extra stop bits, just let it rip. I'm running at TeraTerm's maximum rate of 921,600 baud.
That's really strange but it is as if there is a delay in the TeraTerm line delay settings or something. It's easy enough to check the speed of the unit:
TF2# 1,000,000 LAP FOR NEXT LAP .LAP 32000096 cycles or @160MHZ 200.0ms ok
I wonder if the 123 needs to have a clock setup. This is the A9 version of the board isn't it?
I am using the A9 version. I also get 200 ms when I checked the speed.
What is "$Dead.BEEF" ?
Nick
decimal 4728199954159
It is used as a unique signature or as a special terminator or indicator with some morbid humor attached along the way. It is easy to spot in a HEX dump if your first language is english.
$CAFE.BABE is another one I could also use and do but traditionally $DEAD.BEEF is used for diagnostics as it is easily recognizable in a hex dump. I use it on the stack as a unique value to look for stack corruption. If I do a !!SP it leaves a single $DEAD.BEEF on the stack which should still be there after I test functions as some functions may drop too many items but the stack will not pop beyond zero items and this dropping may be missed otherwise.
The use of hex numbers in this manner is referred to as Hexspeak but here are some combos I can think of (updated)
It's been a while since I have bothered to update Tachyon Forth for the P2 but now I'm thinking I'd like to use it as a development system since I already have FAT32 and FTP working etc and I can write macroassemblers for ARM and P2 in Forth itself which I have done before. There are three ways I can edit text files on the P2, one is to use an ANSI terminal as the screen, the second is to edit files over FTP, and the third is to make the system stand-alone with VGA. But VGA is problematic since there are many different FPGA configurations so I was thinking I would just use a simple bit-bashed graphic driver that would work on any system, using simple 4 or 8-bit color. That way I can get everything up and running, write my text editor and macroassemblers, and be able to reuse a lot of the code on the target systems too. Since the macroassembler would be running on top of Tachyon it can host very powerful macros since we simply extend the language to suit.
So I'll put my ARM stuff on hold for a couple of weeks to test out the latest image, upgrade Tachyon to work with that, maybe introduce some of the new instructions, but concentrate on making it a stand-alone system. Later on I can add VGA support for those boards loaded with DACs perhaps.
The implementation itself will be a good test of the P2 but I can also have CODE definitions so that we could test out PASM interactively too.
That's great news, Peter. I'm anxious to hear how it goes. Hopefully, you'll have a good time with it.
Had to make a few minor changes but Tachyon is up and running for V16. Now off to load the V16a image and double check and then load EASYFILE and EASYNET. If that works then I will concentrate on writing a macroassembler for the P2 to run interactively on the P2. So we will be able to exercise P2 instructions from the terminal (or VGA). Then a screen editor that will work with an ANSI terminal or a bit-bashed P2 VGA. Then after all this I can add Cortex M0 ARM, M4, M7, and other targets including P1. If P2 turns up on my doorstep in the meantime I will throw my ARMy buddies out into the street!
I think I will simply call it MACRO rather than another ???ASM. How does that sound?
TF2#ParallaxPropeller2.:.:--TACHYON--:.:.ForthV12170228.1940BOYSCOUT----------------------------------------------------------------TF2#SEESEEIMMEDIATE4F8D:4CC9ex4F8F:009D$0016(22)4F93:013DERASE4F95:0162 44F97:4CD1ind4F99:0087 C!4F9B:1A4FNFA'4F9D:1A7FGRAB4F9F:0017?DUP4FA1:00D5IF$4FCC4FA5:0018 DUP4FA7:007CC@++4FA9:0033+4FAB:007FC@4FAD:0158 BL4FAF:0045 AND4FB1:00D5IF$4FC24FB5:1D8FPRINT"IMMEDIATE"THEN4FC2:23DENFA>CFA4FC4:23F0>PFA4FC6:4F17SEE?4FC8:00D3GOTO$4FDATHEN4FCC:1D8FPRINT"notfound"
4FDA: 000D ; ok
4FDA: 000D ; ok
There is no v16a image, only PNut_v16a.exe and instructions_v16a.txt.
I'm having a rather busier than usual week so I haven't had much time at all to look at TF2 but I did introduce wordcode decoding similar to TF1 V4. In this case I encode byte literals as $FFxx and test for this in my address interpreter loop. Normally a byte literal would take two words, one for the wordcode and one for the literal. Before I did have instructions for some selected fast constants such as 0, 1, 2, 16 etc. This took up cog memory but ran faster and only needed a single wordcode for these fast constants. As in V4, I did away with fixed fast constants and introduced encoded byte constants. That is any "address" that is $FFxx is not executed but the low byte is pushed onto the stack instead. Does this run faster?
The fast constant 16 takes 400ns yet an encoded byte constant only takes 300ns, so it is faster and I don't need to allocate any cog memory for a limited number of fast constants. This decompilation here still referred to fast constants which have since been removed except for -1.
TF2# LAP 16 LAP .LAP 64 cycles or @160MHZ 400ns ok
TF2# LAP 87 LAP .LAP 48 cycles or @160MHZ 300ns ok
TF2# LAP 255 LAP .LAP 48 cycles or @160MHZ 300ns ok
TF2# LAP 256 LAP .LAP 81 cycles or @160MHZ 506ns ok
TF2# : TEST 0116872541234 $12345678 ; ok
TF2# SEE TEST
4E32: 016B 04E34: 016A 14E36: 015E 164E38: FF574E3A: FFFE
4E3C: 00A2 $04D2 (1234)
4E40: 00A0 $$1234.5678 (305419896)
4E46: 0012 ; ok
I need to look at locking TF2 into Flash though via the bootloader.
peter@peter-XPS-15-9550 ~ $ telnet tachyonforth.com 10001 Trying 58.161.247.42... Connected to tachyonforth.com. Escape character is '^]'. WELCOME TO THE IoT5500 TELNET SESSION Use Forth commands, for help type QWORDS Try ls or DIR for directory Session time is unlimited but all other network ports will be blocked until Telnet is disconnected ok TF2# q -------------------------------------------------------------------------------- CODE MEMORY @ $00.8026 for 28,710 NAME MEMORY @ $00.B3BA for 9,995 DATA MEMORY @ $00.E2FB for 290 FREE MEMORY = 13,204 MODULES LOADED: 7041: EASYNET.fth WIZNET NETWORK SERVERS 151111.0800 6405: W5500.fth WIZNET W5500 driver for TF2 151110.1500 4E44: SDFAT.fth P2 SDFAT FILE SYSTEM - 160619.0000 4C59: EEPROM.fth EEPROM UTILIES - 160625.0000 2D80: EXTEND.fth TACHYON FORTH EXTENSIONS for the P2 - 151121-1400 POLL #0 ?EASYNET 2016/07/06 WED 23:56:15 -------------------------------------------------------------------------------- ok TF2# ls NO NAME WARPEACE.TXT EXTEND .FTH EEWORDS .FTH VGA .FTH CLOCK .FTH EASYFILE.FTH BREAKOUT.FTH SDCARD .FTH W5500 .FTH LIFE .FTH EASYNET .FTH IOT5500 .HTM WELCOME .TEL POPCORN .MP3 HOME .HTM P8CPU .JPG IOTPINS .JPG LOVE .WAV HELP .TXT P8 .H IOT5500H.JPG DRAGON .JPG IOT5500 .JPG 128K .BIN 256K .BIN W5200 .FTH PREVIOUS.ROM DEBUG .ROM POPCORN .WAV P8X32A .PDF IMAGE3 FRED .PNG FSRSCH .PNG FSRPCB .PNG IMAGE HTTP404 .HTM IMAGE2 IMAGE1 LOGON .HTM TACHYON .HTM WELCOME .FTP P2BOOT .IMG POWERMAX.LOG SITE0002.LOG SITE0001.LOG FAVICON .ICO PARALLAX.PNG HOME1 .HTM SYSLOG .TXT HCB4208 .JPG CE1372 .JPG CE1372 .PDF CHARLCD .JPG ECOLCD .PDF LOVE .MP3 FIRMWARE.ROM ok TF2# 10 CHAT ok qw qw QV ?AUTOLOAD FCRC (LOADROM) LOADIMG LOADROM SAVEIMG SAVEROM FIXBIN ROMSZ .FILES .FX .FILE ls .LIST (.LIST) (ls) lscnt .UTIME .FNAME (SLIST) (DIR) DIR udir (.DIR) .DIR .ATR PROMPT .PATH pwd cd$ cd cwd$ cat (cat) FPRINT$ FRUN FLOAD DELETE RENAME RENAME$ RW APPEND APPEND.BLK eof -FERASE @RCD >|RCDSZ RCDSZ FCREATE$ FOPEN FOPEN$ FOPEN# FCLOSE FOUTPUT >FILE FINPUT FILE> FPUTB FPUT FGET fkey FREM @FWRITE @FREAD fstat fwrite fread FFC@ FC@ FC! FILE@ FSECT@ FSIZE@ StartCluster CLUSTERS? ROUNDUP/ CLUSTER@ @CLUSTER NextFreeDir .FTIME .FDATE .FYEAR FSTAMP FTIME! +DIR! FDATE! DECS DIR! DIR? dir$ @DIRBUF @FSIZE @FCLST @FDATE @FTIME @FCLSTH @ADATE @CDATE @CTIME @CMS @ATR @FEXT @FNAME >F83 fname$ FILE$ file$ ?SDCARD ?MOUNT MOUNT .FAT READFAT32 CLUST>SECT FAT2 FAT1 @FAT @BOOT cwdsect @ROOT fboot dirbuf file diradr rootdir clshift mounted fatname ok .PPCFG .PPCFG #10 @1,000,000 TR/TE=14/15 ok $7F BL DO I EMIT LOOP $7F BL DO I EMIT LOOP !"#$%&'()*+,-./0123456789:;<=>?@ABCDEFGHIJKLMNOPQRSTUVWXYZ[\]^_`abcdefghijklmnopqrstuvwxyz{|}~ ok 'C . 'C . 29 ok ls ls *No Card inserted!* *Card Error* *Card Error* ok .VER .VER Propeller .:.:--TACHYON--:.:. Forth V29160613.0000 ok ^Q ok TF2# ok TF2#A few of those discontinued flash parts would be nice to boot. Couldn't help it. Very quiet in P2 land.
TF2# SEE ?FTP 7D65: 7350 FTP 7D67: 6A1B SOCKET 7D69: 7520 CONNECTED? 7D6B: 00EA IF $7DBC 7D6F: 009D $0046 (70) 'F' 7D73: 75E4 constat 7D75: 0087 C! 7D77: 28E8 CON 7D79: 152D CR 7D7B: 0181 ON 7D7D: 7413 QUIET 7D7F: 6DB7 autosend 7D81: 319A C~~ 7D83: 6EE7 LANCON 7D85: 1D87 PRINT" 220 WELCOME TO THE TACHYON WIZNET FTP SESSION!" 7DB6: 152D CR 7DB8: 74FE KEEPALIVE 7DBA: 74D8 LANSKT THEN 7DBC: 7570 DSCTD? 7DBE: 00EA IF $7DCC 7DC2: 009D $0066 (102) 'f' 7DC6: 75E4 constat 7DC8: 0087 C! 7DCA: 351D CONIO THEN 7DCC: 000D ; okThe forums are extremely quiet. Makes me wonder if there will be a volume market for P2 when it finally arrives.
Nick
TF2# .s 0000 [ 0000.0000 0000.0000 0000.0000 0000.01A5 ]TOP ok TF2# .VER Parallax Propeller 2 .:.:--TACHYON--:.:. Forth V11160702.1400 PIONEER ok TF2# IFDEF VOCAB: ok TF2# ok TF2# P2 TACHYON 1 flags CLR Parallax Propeller 2 .:.:--TACHYON--:.:. Forth V11160702.1400 PIONEER ok <snip> 10:10:26 End of source code, 0471 lines processed and 0000 errors found Load time = 609114733 cycles or @160MHZ 7.613sec -------------------------------------------------------------------------------- CODE MEMORY @ $00.4F9A for 16,282 NAME MEMORY @ $00.C4B9 for 5,644 DATA MEMORY @ $00.E000 for 202 FREE MEMORY = 29,983 MODULES LOADED: 2D80: EXTEND.fth TACHYON FORTH EXTENSIONS for the P2 - 160707-1500 2016/07/18 MON 10:10:26 -------------------------------------------------------------------------------- ok TF2# ok TF2# .S DATA x1 DEAD.BEEF BRANCH x0 LOOP x0 RETURN x3 0000.26C7 0000.4F9C 0000.37EB ok TF2#I note too that 7.6 seconds is my actual not projected load time so I will have to fix that reporting but otherwise it seems fine. Can you post your screen copy in a similar manner.btw, there is no need for any delays or extra stop bits, just let it rip. I'm running at TeraTerm's maximum rate of 921,600 baud.
TF2# .S 0000 [ 0000.0000 0000.0000 0000.0000 0000.01A5 ]TOP ok TF2# .VER Parallax Propeller 2 .:.:--TACHYON--:.:. Forth V11160702.1400 PIONEER ok TF2# IFDEF VOCAB: ok TF2# ok TF2# P2 TACHYON 1 flags CLR Parallax Propeller 2 .:.:--TACHYON--:.:. Forth V11160702.1400 PIONEER ok 00:00:45 End of source code, 0475 lines processed and 0000 errors found Load time = 2004125361 cycles or @160MHZ 25.51sec -------------------------------------------------------------------------------- CODE MEMORY @ $00.4FA9 for 16,297 NAME MEMORY @ $00.C4B9 for 5,644 DATA MEMORY @ $00.E000 for 202 FREE MEMORY = 29,968 MODULES LOADED: 2D80: EXTEND.fth TACHYON FORTH EXTENSIONS for the P2 - 160707-1500 2000/00/00 Þ 00:00:03 -------------------------------------------------------------------------------- ok TF2# ok TF2# .S DATA x1 DEAD.BEEF BRANCH x0 LOOP x0 RETURN x3 0000.26C7 0000.4FAB 0000.37E6 ok TF2# ok TF2# ok TF2# $1A5 . 421 ok TF2# $DEAD.BEEF . -559038737 ok TF2# [spoiler][/spoiler][/color]I note that loading EXTEND is significantly longer on the 1-2-3.
Nick
Nick
DEADBEEF CAFEBABE CAFED00D DEADBABE DEADD00D DEADDEAD DEADD0D0 DEADC0DE DEADFACE DEAFD00D D0BED0BE ABADDEED F0BED0FF C0DEFADE C0DED00D FADED0FF C0FFEE42 DABBAD00 D00GF00D FEEDFACE DEFACED1 EFFACED1 BADDECAFetcI often use $DEADC0DE
It's good to use the DEAD words as they can be picked out easily but FEEDFACE is a good reminder that I need to take a break
TF2# .S DATA x2 FEED.FACE D00D.F00D BRANCH x0 LOOP x0 RETURN x3 0000.26C7 0000.8154 0000.37EB ok TF2#So I'll put my ARM stuff on hold for a couple of weeks to test out the latest image, upgrade Tachyon to work with that, maybe introduce some of the new instructions, but concentrate on making it a stand-alone system. Later on I can add VGA support for those boards loaded with DACs perhaps.
DEADBEEF
TF2# Parallax Propeller 2 .:.:--TACHYON--:.:. Forth V12170228.1940 BOYSCOUT ---------------------------------------------------------------- TF2# SEE SEE IMMEDIATE 4F8D: 4CC9 ex 4F8F: 009D $0016 (22) 4F93: 013D ERASE 4F95: 0162 4 4F97: 4CD1 ind 4F99: 0087 C! 4F9B: 1A4F NFA' 4F9D: 1A7F GRAB 4F9F: 0017 ?DUP 4FA1: 00D5 IF $4FCC 4FA5: 0018 DUP 4FA7: 007C C@++ 4FA9: 0033 + 4FAB: 007F C@ 4FAD: 0158 BL 4FAF: 0045 AND 4FB1: 00D5 IF $4FC2 4FB5: 1D8F PRINT" IMMEDIATE" THEN 4FC2: 23DE NFA>CFA 4FC4: 23F0 >PFA 4FC6: 4F17 SEE? 4FC8: 00D3 GOTO $4FDA THEN 4FCC: 1D8F PRINT" not found " 4FDA: 000D ; okThere is no v16a image, only PNut_v16a.exe and instructions_v16a.txt.
Great progress. Did you use the recent bytecode/wordcode opcodes yet, and what gains did they give ?
Just shows how flexible you have made Tachyon.
I will be interested to see some timing comparisons.
TF2# LAP 16 LAP .LAP 64 cycles or @160MHZ 400ns ok TF2# LAP 87 LAP .LAP 48 cycles or @160MHZ 300ns ok TF2# LAP 255 LAP .LAP 48 cycles or @160MHZ 300ns ok TF2# LAP 256 LAP .LAP 81 cycles or @160MHZ 506ns ok TF2# : TEST 0 1 16 87 254 1234 $12345678 ; ok TF2# SEE TEST 4E32: 016B 0 4E34: 016A 1 4E36: 015E 16 4E38: FF57 4E3A: FFFE 4E3C: 00A2 $04D2 (1234) 4E40: 00A0 $$1234.5678 (305419896) 4E46: 0012 ; okI need to look at locking TF2 into Flash though via the bootloader.
