PropellerIDE locks up. (solved, kind of)
I am finding that the "terminal" built into PropellerIDE is broken. When it's window opens it will no longer respond to mouse clicks, or text typed within it. In order to get it to respond I must click the control I want, or type the text I want and then drag the window by the title bar to get it to respond. This is very strange behavior. After opening the terminal the entire program then behaves this way. Even after the terminal is closed.
Windows 7 Pro
PropellerIDE v0.33.3
Any way to fix this?
Windows 7 Pro
I'd not worry about PropellerIDE having a specific bug so much as it being resource heavy in certain borderline cases.
