Old BASIC Stamp
in BASIC Stamp
Hi
I've found an old BASIC Stamp1 It's mounted on a pin board with PP9 battery terminals and a 25pin comms cable., presumably parallel link. All latest models show 9 pin serial. I've lost the software (replaced PC 4 years ago).
Is software still available, for Windows Vista.?
The BASIC Stamp software on the Parallax site which it says is Vista compatable returns " not Vista software" when I download it!
Regards Freddxxy
Regards Freddxxy
BTW - I'm using Win 8.1 on a plain vanilla PC. If you are having compatibility issues, I noticed there are several older versions of the IDE available. You should try one or two of those to see if you find one that "clicks" with your system. That's typically why they're made available.
I'll take a look and post the pinouts, in case you want to try making your own cable from an old USB cable... what have you got to lose?
