1024K I2C serial eeprom
in Propeller 1
Hello,
Is it posible to connect the Propeller chip with a 1024K I2C serial EEPROM?
In general, talking to any I2C device should be possible, but I'm not sure how flexible the prop is regarding what devices it can boot from.
-joe
I have however used 24M01 devices which are fine. If you connect multiple devices you can just change the address on pin2&3 of successive devices and in the case of Tachyon it will just look like one big eeprom. Bear in mind that eeproms are slow and if you want a lot of memory in a chip it is best to add a little 8-pin SPI flash memory as they start at megabytes not megabits.
I asked in the past a similar question here:
http://forums.parallax.com/discussion/137141/128k-eeprom-for-data-storage
Massimo
