Shop Learn
National Semiconductor Digitalker (DT1050 / MM54104) - alternative ROMs — Parallax Forums
The Digitalker, which dates back to around 1982, always fascinated me, but it was always too expensive. I have now finally bought one of Ebay for a nice price, and downloaded the datasheet. I always thought that all information was on board this one chip, but it seems several ROMs are needed: MM52164SSR1, MM52164SSR2 and I even read recently about a MM52164SSR5 and MM52164SSR6.
I'd say these are just (EP)ROMs and can be simulated with a microcontroller or by programming a nice 64Kbit EPROM. But then I would need to have the contents (Hexdump) of those ROMs. The chips itself, which would also be fun to have, can't be found at all: Ebay just remains blank. There might be companies like Octopart that are willing to sell 1,000 items for a very "nice" price, but that is not what I'm looking for.
But what exactly are these ROMs? Just a set of parameters that form a prefab vocabulary or are they essential for the working of the Digitalker in general. As far as I know, the Digitalker (DT1050)can be used "stand alone", but the vocabulary is then limited.
  • kwinnkwinn Posts: 8,693
    edited 2016-06-08 10:00
    The MM52164 is an 8K x 8 ROM, so based on what you posted ( As far as I know, the Digitalker (DT1050) can be used "stand alone" ) they are most likely a vocabulary extension. If that is the case there are probably several options to substitute other parts for the ROM as long as the original data is available in some form. Having that data is the crux of the matter. Any manual or info available for the DT1050?
    PS - Some info on this chip at https://sites.google.com/site/analogvocoderinfo/ic-speech/ic-advances-in
  • Thanks for your info!
    kwinn wrote: »
    I'm not sure if there is some sort of a basic vocabulary in the main chip, the MM54104, so that some basic words or sounds can be produced without any ROM, I can't really derive that from the datasheet.
    kwinn wrote: »
    Indeed. I'd say NS's ROMs could be replaced with an EPROM, but indeed it requires the hexdump. I have not been able to find that. I was actually hoping someone in this forum already played with it in the past.
    kwinn wrote: »
    The datasheet is wide available, it is a lowres scan, but readable. It's pretty brief for such a complicated IC.
    kwinn wrote: »
    Interesting, I never new that DT1050 was the name of the set (consisting of the MM54104 "engine" and the MM52164SSR1 and 52164SSR2 ROMs).
    Apart from the SSR1 and 2, there seem to have existed a SSR5 and 6 as well. I have no idea why this was sold prefab, if you know how to encode a new word (some sort of formula), you could create your own EPROM with a certain vocabulary.
    Interesting, but it's all dead old and therefore info is hard to find...
  • Boy, are you a glutton for punishment! The ROMS are just canned words, you can do the same with a cheap SPI Flash or even microSD, the Prop, and an RC DAC for speech output. Heck, I could knock something together just by recording words, saving them onto the microSD as separate files, then just playing them back as required.
    Ha,ha, that is correct, BUT... The whole fun is to get this dead old MM54104 working ;-) Why? Don't ask ;-)
    The ROMs contain indeed "just" canned words, but some smart algorithm was used and a good starting point would be a dump of those ROMs in order to populate an EPROM. As the ROM chips cannot be found.
  • A good starting is not the dump of the ROMs, it's finding the ROMs on the dump somewhere......however...
    I see W4OLF on an Arduino forum has backed up DIgitalker ROMS, so you might try contacting him for a copy.
    These ROMs are extremely hard to find. I think many people have forgotten about these ROMs, they sell the MM54104, the engine, and once threw away the ROMs because they didn'tknow what it was (my guess). Thanks for the usefull link, it seems this guy has a lot of the info needed and the contents of the ROMs. I PM'ed him, waiting for an answer...
  • Hey! I find I still have the complete set with all 4 ROMs in a little box on a dusty shelf. From Jameco vintage 1991 but the ROMs are dated 1980/81. PM me and we can make a deal either for the hardware or for an image of the ROMs. I'd built up the main 134 word set on a vectorboard with blue wires, but the SSR5 and SSR6 ROMs with the additional 131 words are still in a tube.
    Wow! Just PM'ed you.
  • A nice article showing the complete word set at,
    http://www.classiccmp.org/cini/pdf/re/Build a Speech Synthesizer (1288).pdf
    Yep, interesting link, had seen the article before. ROMs also seem to have been included as a dump in something called MAME. I need to go through it to see what it is, but for now it seems a huge collection of ROM's all concatenated to one sort of config file, that is used in a sort of "engine" software.
  • I have been watching this thread with interest. I have two old EPROM programmers , (parallel port), and I keep two 486 machines just for this purpose. Let me see if the programmers can read a MM52164. I know I have NS Data Book from that time period.
    I have an original Dectalk DTC01. A 68000 and a bunch of ROMS also.
  • Publison wrote: »
    You might want to have a look at the Arduino Forum on the abovementioned link, wiring is different, so be careful that you don't destroy your ROM or reader. I still got an old parallel port Willem Peogrammer, always interesting to keep when you're interested in older stuff and I keep a 486 and an old laptop as well. This programmer can go back to 2716 EPROMs (but not 2708's - which are nice complicated with their 3 voltages + 1 voltage for programming).
  • Tracy AllenTracy Allen Posts: 6,572
    edited 2016-06-11 17:17
    The chips are mark "copyright MOZER". I was curious about that and found that it has an interesting back story. The speech compression algorithm and codec used in the chips was the brainchild of physicist/engineer/inventor/entrepreneur Forest S. Mozer. He came up with and patented the methods back in the mid 1970s, in the days of expensive memory. He licensed the technology to National Semi for the Digitalker and to other companies as well. He capped his career as a physicist here in Berkeley at the Physics Dept. and at the Space Sciences Laboratory, contributing mightily to the measurement of electric fields in plasmas in space (as in the earth's aurora). He and his son founded a Silicon Valley company, sensory, with a patented speech recognition technology..
  • George and I struck a deal to get these chips into his hands in the Netherlands and to help me clean up my shop. Here are photos of the chips. The SSR1 and SSR2 roms are still in the board in zif sockets; the Codec is the big chip; the extra roms SSR5 and SSR6 are still in their tube. Blue wires, oh my, what a headache. Many of them are pulled loose, but no worries, George, I'm sending just the chips and you can make it talk the way you want! I hope you can play it back for us.
    320 x 115 - 15K
    320 x 240 - 46K
    320 x 240 - 64K
  • PublisonPublison Posts: 12,146
    edited 2016-06-14 18:35
    I hope this all comes together. I love when old stuff gets working again to show the youngsters how we did it "back then". :)
    Edit: wonder if the copyright is still in place on the ROMs?
    edited 2016-06-14 18:57
    I noticed there are a few of the Codec chips available, although pricey:
    http://www.electronicsurplus.com/national-semiconductor-corp-54104-ic-digitalker-speech-synthesizer
    The SC-01 is 100 dollars cheaper. :)
    http://www.gameroomrepair.com/ICparts/ICparts.htm
  • Really happy with it, can't wait to make it speak ;-)
  • Re: http://www.electronicsurplus.com/national-semiconductor-corp-54104-ic-digitalker-speech-synthesizer
    To pay $169 for the codec alone, you'd have to be pretty much up against a wall to rejuvenate your vintage cash flow widget. The $169 does not include the essential ROMs. Hurry, only 29 in stock!
    I think most individual copyright protection extends through the author's life plus 70 years, unless the author releases it. It is different for works for hire, 95 years after publication.
  • I purchased the chip set in the late 80's, and never did anything with them. I am/was about to finally hook them up, but when I saw what price was being asked for them I may sell them.
  • garyp wrote: »
    Asking Price?
  • garypgaryp Posts: 4
    edited 2017-03-05 12:55
    I keep going back and forth on whether to build or sell !
  • I think most individual copyright protection extends through the author's life plus 70 years, unless the author releases it. It is different for works for hire, 95 years after publication.
    The DigiTalker chips use Mozer compression, which recognizes, among other things, that the human ear is sensitive to frequency and amplitude, but insensitive to phase. Mr. Mozer, IIRC, was a stickler for protecting his IP and didn't suffer IP "piracy" gladly.
  • I put together a Digitalker card using the basic Vocabulary ROMs back in the early 1980s and later interfaced it to a Timex-Sinclare Z-81 computer and then later, a Commodore-64 computer in 1984. Later I purchased the second set of stored speech ROMs and added them to my wire-wrapped Digitalker card. It was fun to write simple Basic programs to select words from the Vocabulary chips. To the guy who thinks you can create your own Vocabulary chips for the Digitalker, good luck because, National Semiconductor had the only encoder for the stored human speech that was recorded onto these ROMs. The playback only processor was the only thing you could buy and if you wanted to have custom words in a special chipset, you had to pay for them to be created for you by National Semiconductor at their factory. The ROMs were of the Mask Programmable type. They were not "burned" by anyone. The ROMs were coded actually by a photomask in the manufacturing process in the semiconductor wafer fab. I sure wish someone would just post the stored speech files for free download on the Interweb. That's what I would do if I still had mine but many years ago, I was on a crazy clean-up campaign in my house because I had a new baby and my Digitalker project went in the trash. I know. What a big mistake.
  • ArizonaJoe wrote: »
    Welcome to the forums! And the walk down memory lane. :)
  • georgedbgeorgedb Posts: 21
    edited 2020-07-15 08:11
    ArizonaJoe wrote: »
    ... To the guy who thinks you can create your own Vocabulary chips for the Digitalker, good luck because, National Semiconductor had the only encoder for the stored human speech that was recorded onto these ROMs. The playback only processor was the only thing you could buy and if you wanted to have custom words in a special chipset, you had to pay for them to be created for you by National Semiconductor at their factory. ...
    Well, if you look at the data book from that era, National Semiconductor sold a CP/M application "DTSW-500", a "Digitalker Vocabulary Selection System (DVSS)". I would be willing to set up a CP/M system, if this software was anywhere to be found (but believe me, it isn't).
    Apart from the SSR1 and 2 and the SSR5 and 6, there seem to have been, according to that data book: ftp://bitsavers.informatik.uni-stuttgart.de/components/national/_dataBooks/1982_National_Linear_Databook.pdf , an SSR3 and SSR4, with just another vocabulary, as well as a MM52165SHR/L with only the numbers. I found a disassembled ROM for this SHR/L, only available through the WayBack-machine: http://web.archive.org/web/20071115000602/http://home.hiwaay.net/~jfrohwei/tech.html
    , but someone compiled it for me, but it does not result in a hex that gives a working ROM after burning it in an EPROM.
    If there is anyone who has (the contents of) whatever Digitalker ROM's, the 7 ROMs mentioned above (SSR1 - SSR6 + SHR/L) or any custom ROMs, I think there will be a few people cheering ;-) Please share!
    SSR3/4 is page 13-22
    http://bitsavers.trailing-edge.com/components/national/_dataBooks/1984_National_Linear_Supplement.pdf
    DTSW-500 CP/M software is page S14-1
    edited 2020-07-15 08:12
    Don't know what happened to the links, but I'm sure you can pull out the URL's...
    ModEdit: links repaired
  • Hello,
    I'm looking for SSR5/SSR6 rom or dumps.
    I have built an universal rom reader and got SSR1/SSR2 rom dumps, i can read other roms if needed
    Regards
  • Hello,
    Looking dump (or roms, as i can dump these) for :
    - SSR3/SSR4 used in DT1051/DT1054 evaluation board
    - MM52116 used in DT1052/DT1055 evaluation board
    - SSR5/SSR6 used in DT1056/DT1057 evaluation board
    Thank you for help !
  • Nobody ?
    Always looking for SSR3/SSR4 and SSR5/SSR6 dumps !
