5200 mAh capacity Mobile Battery Pack, two for $5 at BestBuy
tonyp12
Maybe a price mistake as you get bogo on the already low price of $4.99
http://www.bestbuy.com/site/insignia-mobile-battery-pack-blue/8599017.p?ref=199&loc=*7WaaTN6umc&acampID=1&siteID=.7WaaTN6umc-1gHz00rH.k14lqAZW9prXw
Power your development boards or small robot with this.
No "In Store Pickup"
No "Shipping"
It looks like they went real fast as BOGO or else they realzed their mistake and best way to save face (and cut losses) was to go out of stock!!
It does not look like a way to delete this thread.
Strange. erco Your robots are all at his place and listening to the radio, WQXR-FM as it happens.
but this 4400mah for $3.99 is not to shabby either:
http://www.bestbuy.com/site/duracell-pro510-power-bank-portable-charger-black/4280700.p?id=1219737856024&skuId=4280700&productCategoryId=pcmcat326000050010&u1=ebs2d0d4767d1464148404388sbe
Thanks for the update! I managed to snag two of the insignia bricks. It makes me wonder, though, if it might be possible to still get some by going to the retail locations.
Every time I went on line they were sold out but was notified that my local store would have them available today, 5/28. Headed over to the store this morning and the store had 5 left. Picked up 4 for $10.68 including sales tax. The shelf where I found 'em only listed $4.99 Limited Time. No mention of a bogo. At the register I was charged for two and got the other two free. I felt a little guilty leaving one on the shelf, so the next buyer won't be getting the bogo deal.
Just went on line and the deal is now $9.99 each.
Just change quantity to two (for the blue 5200mhA) and the Estimated Order Total remains $9.99
I guess the bogo thing is a hidden sale, since it only comes up at checkout (or when changing on line quantity to two or more.
e.g build a vehicle around its shape.
Well here, it worked. I bought two of them, and they were indeed at that price. I might check on it in Manhattan. This happened in Woodside.
erco I saw your robots buying something big at the store today.
Well yes. And the universe is not obligated to keep a straight face.
Two more today, from a Manhattan store.
I might have to... I've already broken one of the USB connectors.
And there it is...
(Edit: here's a direct link to the original picture: https://drive.google.com/open?id=1T8YkCoi3IKCWMYQ6isKLdmZdB9PZr2ZLFA.)
Two 18650s connected in parallel.
This content failed to load.
Yeah, the original link didn't work. It turns out that sharing from google drive requires a little URL manipulation. Refresh and you should be able to see it.
has anyone tested the ACTUAL capacity of these??
Dave
It was the micro end. The fail was partly my fault (I had put excess latetal strain on the connector when I plugged the cable in), but it also appeared that one of the tabs had less solder than it should have. Fortunately, I was able to solder it back down and resolder the pins to the traces (which were not damaged). It's back in working order again.
Good question. I always wonder if the rated capacity is the measured 5V output or simply the rated capacity of the internal 3.7V batteries.
Hah! Good point! And it turns out that these batteries answer that very question. On the back, there is a sticker that says:
C18650CC-1S2P
3.7V
5200mAh
19.24Wh
So, it's the rated capacity at 3.7V, not 5V!
Edit: It turns out that the back of the case tells us the same thing, though you have to do some math to discover the 3.7V part.
Edit edit: To my surprise, this appears to be standard practice! One of the first USB battery packs I ever bought is a Limeade L130X (13000mAh), which is not a cheap-o brand. It turns out that its rated capacity is 13000mAh/48.1Wh. Which works out to 3.7V!
