Soldering question
Franny
Howdy, I have a can of CRC QD Contact Cleaner (02130) and was wondering if it's good for cleaning before applying flux and solder? I'm soldering lithium-ion batteries to pure nickel tabs with flux and silver bearing solder, I need it to be very sturdy and saw that people use Alcohol for cleaning before applying flux, what do you recommend?
http://www.homedepot.com/p/CRC-QD-11-oz-Contact-Cleaner-02130-6/202262505
But...but, that leaves a residue, lubricates the thought processes, and using it to clean surfaces is such a waste.
Been using that trick also since the 70's on copper/gold board edge fingers.
Also used a fiberglass brush:
http://www.mcmelectronics.com/product/21-13835
but it is pretty aggressive.
I have heard of the rubber thing, lots of folks use it, however, this is a lithium-ion battery for a vehicle with 156 fuses, lots of soldering points and most important lots of vibration and so because these batteries are so expensive I want to make sure I get it right
Also used a fiberglass brush:"
Tried those also until I wound up with fiberglass slivers in my fingers. Not a pleasant thing...
90% alcohol OK?
Good call Phil. I'd go for push ons myself.
Got a pic of what to want to connect?
