Soldering question — Parallax Forums
Soldering question
Howdy, I have a can of CRC QD Contact Cleaner (02130) and was wondering if it's good for cleaning before applying flux and solder? I'm soldering lithium-ion batteries to pure nickel tabs with flux and silver bearing solder, I need it to be very sturdy and saw that people use Alcohol for cleaning before applying flux, what do you recommend?
http://www.homedepot.com/p/CRC-QD-11-oz-Contact-Cleaner-02130-6/202262505
  • LeonLeon Posts: 7,620
    Check that it doesn't contain a lubricant, which will prevent a decent joint being made. IPA (iso-propyl alcohol) would be better.
  • It says "Leaves no residue" but anyways where do you get 100% pure ISO-propyl alcohol other than online?
  • The 91 %, from CVS, Walgreens, is usually good enough. I get my drug store to order 99% for me, and I usually get it the next day.
    Electrolube sells 99.7% IPA. I've had a can of it for many years - it lasts a long time.
  • I have used a super low tech rubber eraser for years to clean metal surfaces for soldering. I clean the black buildup on the eraser by rubbing it on a denim cloth.
  • ercoerco Posts: 20,257
    edited 2016-05-22 14:05
    You guys are hardcore. My preferred IPA has an alcohol content of only about 5%.
    But...but, that leaves a residue, lubricates the thought processes, and using it to clean surfaces is such a waste.
    edited 2016-05-22 15:58
    Hal Albach wrote: »
    Been using that trick also since the 70's on copper/gold board edge fingers.
    Also used a fiberglass brush:
    http://www.mcmelectronics.com/product/21-13835
    but it is pretty aggressive.
  • Hal Albach wrote: »
    I have heard of the rubber thing, lots of folks use it, however, this is a lithium-ion battery for a vehicle with 156 fuses, lots of soldering points and most important lots of vibration and so because these batteries are so expensive I want to make sure I get it right
  • Publison: "Been using that trick also since the 70's on copper/gold board edge fingers.
    Also used a fiberglass brush:"
    Tried those also until I wound up with fiberglass slivers in my fingers. Not a pleasant thing...
  • fiber glass has so many useful uses but working with it is an itchy nightmare and also unhealthy
  • 800 grit sandpaper, alcohol clean, then flux should do it for big tabs like that.
  • Publison wrote: »
    90% alcohol OK?
    edited 2016-05-22 19:23
    Franny wrote:
    ... this is a lithium-ion battery for a vehicle with 156 fuses, lots of soldering points ...
    That raised a flag in my mind. Are absolutely sure those are soldering points and not designed for spot welding -- or even push-on connectors? Soldering directly to a lithium battery can be dangerous if the battery heats up during the process.
    Good call Phil. I'd go for push ons myself.
  • Franny wrote: »
    Publison wrote: »
    90% alcohol OK?
    Got a pic of what to want to connect?
    has to be fast, people do it all the time, some folks use coolant spray cans.
  • Alright guys, so these are my cleaning choices right now, which one would you choose?
    4320 x 2432 - 2M
    edited 2016-05-23 02:22
    Many many years ago when Lithium batteries were a rarity I had to somehow fit these tiny cylindrical batteries with a cathode body and the center pin to my production pcbs. I tried silver solder etc but you need so much heat that it damages the battery and there were no ots connector solutions. My solution was to wrap wire tightly around the body and the pin and then tin up the wrap itself with the wire ends soldered to my board. I'd probably be inclined if I did it the same way these days to use some aluminum foil first before wrapping the wire just to provide that more intimate connection although I never had any problems and they worked year after year. Anyway this is a method to solder to "unsolderable" connections whether that's because of the metal or the heat or both.
    Franny wrote: »
