LUT as LUT, Streamer, Pins - supported modes & RAM
jmg
in Propeller 2
Now the LUT as RAM has settled down, I'm looking at LUT as LUT.
If we take a real example, and start simple :
800x480 is a common modern LCD display, with a choice of resolutions.
using a 4b pixel and a 32b Lookup, RAM Bytes needed are
4bp : 800*480*4/8 = 192000
8bp : 800*480*8/8 = 384000
16bp: 800*480*16/8 = 768000 (Outside current HUB budget)
From what I can see in the DOCs, 4 & 8b LUT indexing are possible, and 16b can feed direct (skip LUT)
If you want less than Digital 32b out, DOCs say
8bp is perhaps the most natural choice, but even that is not great for colour blend backgrounds - you can see the steps instead of gradient.
It also wastes half the LUT, which otherwise just sits there....
4bp is quite spartan, even with a lookup table.
Besides those simple choices, there are a couple of others, which the P2 resource might naturally support = 6 & 10 bit pixels ?
4,6,8 index the LUT easily.
10b would work well as a 1024 x 16 LUT, but DOCs are unclear if there is a 1024 x 16 mode ?
This is 4 times as many choices, as 8 bp, and it more fully uses LUT and HUB memory.
Unpacked versions of 6,10 bp simply fill the u32 and discard the leftover.
Packed versions use less RAM, but require a simple 6,10 bit collector for the left over bits.
At 10 bp, packing makes a big difference going from 12288 free bytes to 44288 free bytes.
Is it possible to add 6,10bp to Streamer to better match available / mainstream displays ?
1000 = enable output on pins 31..0 32 pins 1001 = enable output on pins 39..8 32 pins 1010 = enable output on pins 47..16 32 pins 1011 = enable output on pins 55..24 32 pins 1100 = enable output on pins 63..32 32 pins 1101 = enable output on pins 63..40 24 pins, 8 MSBs not output 1110 = enable output on pins 63..48 16 pins, 16 MSBs not output 1111 = enable output on pins 63..56 8 pins, 24 MSBs not outputWhich pins have the boot SPI & UART ? Is there a conflict in 42,16,8b modes ?
4bp : 800*480*4/8 = 192000 (std) 6bp : 800*480*6/8 = 288000 Packed 6bp : 800*480*(32/5)/8 = 307200 5 pixels per u32 8bp : 800*480*8/8 = 384000 (std) 10bp: 800*480*10/8 = 480000 Packed 2^19-800*480*10/8 = 44288 Spare 10bp: 800*480*(32/3)/8 = 512000 2^19-800*480*(32/3)/8 = 12288 Spare
I encountered this "conflict" of the upper 4 bits in a early experiment.
I was sure I posted something about this but a search fails to find any matches.
Anyhow, I suggested maybe the 24,16 & 8 bit modes be relocated to the top of PortA.
Maybe this has changed now that Chip has added 4,2 & 1 bit modes in the next release.
That much is in the data, but they slide-up, then compress.....
One SDRAM solution could need 4b + 16b+16b Streamers, not clear how that can MAP to pins either ?
Hopefully the data is just delayed relative to the design ....
For streaming: 32-/16-/8-pin groups can start at any 8-pin offset (0,8,16,24...), while nibbles can start at any 4-pin offset, twits can start at any 2-pin offset, and single pins can be anywhere.
And no bits could be called zits.
Back in Oz Wednesday so rearing to go
4b + 16b + 16b Streamers,
which looks like one way to get decent SDRAM speed.
rogloh has worked out a compact frame sequence using P1V for R/W and refresh, so it looks like SRAM.
I think that could 'play-back' in a streamer ?
